• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Autonumbered lists conversion issues
New Here ,
Jul 21, 2015 Jul 21, 2015
Hi all
I've had a number of poor results with autonumbered lists during conversion from Frame to RoboHelp in Technical Communication Suite 2015. First it didn't seem to matter which option I chose, convert to HTML list, multilevel list or convert to text, all my list items were returned with the number 1. Each list item was starting over again at the beginning. Then I finally removed a property from my numbered paragraph style that RoboHelp had placed, unknown to me, into my CSS. Unfortunately I can't remember exactly what it was as I was desperately trying many options at the time, but it did have something to do with x-list. This is not a CSS property as far as I know, so it's some RoboHelp command. Since I removed it my lists are now numbering correctly, but there are now two sets of numbers as follows:
This is the code I see:
<?rh-list_start start="1" style="list-style: rh-list; list-style: rh-list;" ?><p
  class="Numbered" style="margin-left: 17.712pt;"><span class="FM_StepNumber">1.<span
  class="FMAutoNumber_1" style="padding-left: 7pt;">&#160;</span></span>Go
to the IT Asset Management workspace and expand the Finance and Organization
Management &gt; Organizations folder.</p><?rh-list_end ?>
It's the same for every step. It appears RoboHelp still thinks it needs to number the steps even though I've changed the option to convert to text. I have updated the FM files, which are linked to my project, not imported. I have regenerated output. I even created a new project, with the same Frame files, but the results were the same.
Not sure what the next step is so I would appreciate some advice.
Gerry
Views
604
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert ,
Do you have 2 FM paragraph tags for the numbered lists in FM? Like one starting at “1” and the rest just adding “+1” onto the last one? If so, how did you map them in your RH Conversion Settings screen?
Votes
Translate
Translate
Report
Report
New Here ,
Yes I have two styles in Frame as you mentioned and they are both mapped to the same paragraph in the conversion settings. Is that the issue?
Gerry
Votes
Translate
Translate
Report
Report
Community Expert ,
They’re mapped to the same RH Style? Or just to “[Source]”?
Votes
Translate
Translate
Report
Report
New Here ,
They're both mapped to the same paragraph style in my CSS.
Votes
Translate
Translate
Report
Report
Community Expert ,
Can you post a couple of screen shots of your Conversion Settings screen for each of them?
Votes
Translate
Translate
Report
Report
New Here ,
Thanks that's what it was. As soon as I mapped the Numbered1 style in Frame (that first step =1) to its own style in RoboHelp, then the numbering corrected itself. No duplicates and correct sequential numbering. In my mind it shouldn't have been necessary since it was suppose to just use FM numbering and not try and create a list.
Gerry
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
I used to set all my lists to be converted as text, but that made me lose control over their alignment and appearance, so I started mapping each type as an HTML list – that gave me more control in the CSS to mess around with them.
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
