Nothing happens.
Running on Windows Server 2012 - looking at the server events, I see this:
The ColdFusion 11 .NET Service service is marked as an interactive service. However, the system is configured to not allow interactive services. This service may not function properly.
This is an existing server, how do I get past this?
NALEX
Could you please try the following steps:
No change - I did as you said, restarted the service, then re-ran the CF Admin login page - just spins.
Turns out the server is "Windows Server 2012 Standard" and does not appear to have been updated. Does that version make a difference?
Thanks.
Version should not be an issue. Can you stop .net services from services.msc page and try again?
Is this server in a domain?
You can check this reg key to see if it has interactive services disabled..
NoInteractiveServices under HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Windows
I would try and update it as much as you can to start with though.
I re-installed CF11, and un-clicked the .Net integration checkbox. I ensured it was attached to the IIS on the server, and completed the re-install. It appears fine - until I get to the "Configuration and Settings Migration Wizard" and it tells me to login.
I login - and it never finishes. Just sits and spins. No errors show up in the events on the Server Manager. I'm fishing around looking for a configuration log file,but not sure where that is..
Are you trying to migrate? If not then you can skip that part and once you are able to log in to admin then we can go ahead and migrate later
Clean install. CF was never on this server. I've installed CF11 four times on other servers - 3 windows and 1 Linux, and never had this problem. I guess I'll do the updates to the server and get that out of the way. This particular server was installed in late 2012, and not touched since ( currently just runs a database ).
In that case, please go to {CF_root}ColdFusion11\cfusion\lib and open the adminconfig.xml and change the runsetupwizard to false and restart ColdFusion services and check
