8 Replies Latest reply on Jul 21, 2015 2:10 PM by resdesign
    Position symbol by code
    ryan_pu Level 1
      i got a square that pulses yellow to serve as a highlighter. It will be reused so I made it a symbol.
      i have it inserted and playing by code but can't figure out how to position it. Using .css(left: 10) does nothing and 10% throws an error. How do I move a symbol with code?
      ALso tried -WebKit-transform-origin with no luck.
        • 1. Re: Position symbol by code
          Zoze Level 1
          try
          .css({left:"10px"});
          or
          .css({ "left":"10px"});
          • 2. Re: Position symbol by code
            ryan_pu Level 1
            nope, didn't work.
            • 3. Re: Position symbol by code
              Zoze Level 1
              sym.$("yoursymbol").css({ "left":"10px"});
              and doesn't work?
              • 4. Re: Position symbol by code
                ryan_pu Level 1
                no... I may have found an issue with the way i built it.
                var highlight1 = sym.createChildSymbol("highlight", "Stage");
                //highlight1.stop(1000);
                //alert(highlight1);
                highlight1.animate({
                  transform: 'translateX(50px)'
                so it creates, stop works and delete works but when I do the alert it comes back empty. I'm wondering if I am telling nothing to do something. Do I need to declare a symbol name or something?
                • 5. Re: Position symbol by code
                  ryan_pu Level 1
                  I started digging into the html and found
                  My next button has an ID of:
                  id="Stage_Next"
                  My code made Symbol has an ID of:
                  id="eid_1437510791584"
                  I'm thinking this may be the break.
                  • 6. Re: Position symbol by code
                    resdesign Adobe Community Professional & MVP
                    Hi there! A little tip about created symbols. If you give them an id or a class name, it is very easy to use them later.
                    here is how to do it:
                    var NewSymbolInstance = sym.createChildSymbol("mySymbol", "Stage");
                    NewSymbolInstance.element.addClass("newClassName");
                    NewSymbolInstance.element.attr("id","idnew");
                    to use with new id - make sure you add the # tag:
                    sym.getSymbol("#idnew")
                    to sure with class name:
                    sym.$('.colorIt').css({'left':100});  // any css on the symbol - if you need to change something inside, use the new class name and the correct scope
                    sym.getSymbol('.newClassName').play();
                    • 7. Re: Position symbol by code
                      ryan_pu Level 1
                      So I finally got it. I was close the whole time but slightly off with syntax. Also had to add getSymbolElement()
                      var highlight1 = sym.createChildSymbol("highlight", "Stage").getSymbolElement();
                      highlight1.css({"left":500 + 'px'});
                      resDesign,
                      Would your way be the more standard way of doing it? I am learning this software to build a workflow for our artist and would prefer to stick close to industry standards as possible.
                      • 8. Re: Position symbol by code
                        either way is industry standard. It depends how much you want to manipulate
                        your symbols and how deep. i think the id or classes much more versatils.
