1. Re: Indesign CC PDF Export fails - Indesign is running but the export funktion fails (sometimes)
Eugene Tyson Jul 22, 2015 3:20 AM (in response to deckal)See if any of these help to resolve the issue File Crashing on Output - printing/PDF/other
2. Re: Indesign CC PDF Export fails - Indesign is running but the export funktion fails (sometimes)
deckal Jul 22, 2015 4:13 AM (in response to Eugene Tyson)thats not my Problem at all. i know what to do when Export Fails and indesign reports a failure. My Problem is that nothing happens...
and it only stucks when im exporting some files at once.
3. Re: Indesign CC PDF Export fails - Indesign is running but the export funktion fails (sometimes)
Eugene Tyson Jul 22, 2015 4:19 AM (in response to deckal)I understand your problem - and the link I pointed to will help you narrow down the issue.
What's happening is that you're trying to cancel a PDF export and it's not canceling. So there is something preventing the canceling of the export.
IDML would remove any potential corruption and might fix your issue.
Halving the PDF export and trying to cancel could narrow the problem down - for instance Page 1-10 File>Export and try to Cancel, if it cancels it's not in page 1-10, try 11-20 and so on until you find the problem page(s) that's stopping it from canceling.
And applying the same logic to problem files is recommended for the other tips in that thread.
Hope that helps.
4. Re: Indesign CC PDF Export fails - Indesign is running but the export funktion fails (sometimes)
deckal Jul 29, 2015 2:41 AM (in response to Eugene Tyson)Hi,
I've tried that, but don't work. Background Task stucks while exporting some large files at once. Max. one large and a smaller file at once works...
5. Re: Indesign CC PDF Export fails - Indesign is running but the export funktion fails (sometimes)
Peter Spier Jul 29, 2015 2:46 AM (in response to deckal)Sounds like either insufficient memory or swap file space.
6. Re: Indesign CC PDF Export fails - Indesign is running but the export funktion fails (sometimes)
kitty84 Jul 29, 2015 6:07 PM (in response to deckal)I think there is a plugin/script you can download which allows you to Enable or Disable Background Export. This might solve your problem?
It has helped me at work where I am exporting huge documents with many links that will often crash InDesign while trying to save a PDF.
The script is here: How to Disable Adobe InDesign Background Tasks
7. Re: Indesign CC PDF Export fails - Indesign is running but the export funktion fails (sometimes)
Willi Adelberger Jul 29, 2015 9:55 PM (in response to deckal)Did you use EPS? Try to use AI or PDF instead. Recently one of the main reasons of failures were EPS. (EPS should not be used anyway because of several good reasons!)
8. Re: Indesign CC PDF Export fails - Indesign is running but the export funktion fails (sometimes)
Eugene Tyson Jul 30, 2015 12:38 AM (in response to kitty84)Could just export to PDF and use PDF interactive.
Or place the file into a new book file and export from the book panel.
File>New Book
OPens the book panel
Add your document
Then use the panels menu to export to pdf.
