0 Replies Latest reply on Jul 22, 2015 1:45 AM by darrenten
    Memory leak while exporting indd to pdf file
    darrenten Level 1
      I found memory leak while converting indd file to pdf.
      I export a 2.21 MB indd file and it will leak about 200kb per time.
      I have reset some 'big' variables null to release and even called $.gc() but it doesn't work at all.
      What's the problem.
      Code is below:
      var result = "No documents are open................";
      // var argsNames=app.scriptArgs.getValue("Name").split(";")
      argsNames = arguments;
      var fileName = argsNames[0];
      var argPreset;
      var storeLocation;
      if (argsNames && argsNames[1]) {
          argPreset = argsNames[1];
      if (argsNames && argsNames[2]) {
          storeLocation = argsNames[2];
      Log("Params:" + fileName + ";" + argPreset + ";" + storeLocation)
      //OpenOptions.DEFAULT_VALUE
      //OpenOptions.OPEN_ORIGINAL
      //OpenOptions.OPEN_COPY
      var myDocument = app.open(new File(fileName),OpenOptions.OPEN_COPY);
      //Fill in a valid file path on your system.
      var myFolder = new Folder(storeLocation);
      var result = "saved to folder:  " + myFolder.fullName;
      if (!myFolder.exists && !myFolder.create()) {
          result = "Not saved.  Unable to create the folder:  " + myFile.parent.fullName;
      } else {
          //myExport2SepratedPages(myDocument, myFolder.fullName, argPreset);
          myExportAllPages(myDocument, myFolder.fullName, argPreset);
      //myDocument.close();
      myDocument = null;
      //var endMark=app.performanceMetric(PerformanceMetricOptions.currentMemoryMark);
      //app.dumpBetweenMemoryMarks(startMark,endMark);
      result+=($.summary());
      $.gc();
      //export to a single pdf file
      function myExportAllPages(myDocument, myFolderName, presetFile) {
          var start = new Date();
          var myBaseName = myDocument.name;
          myPageName = myDocument.pages.item(0).name;
          app.pdfExportPreferences.pageRange = PageRange.ALL_PAGES;
          app.importFile(ExportPresetFormat.DOCUMENT_PRESETS_FORMAT, presetFile);
          //Generate a file path from the folder name, the base document name, and the page name.
          //Replace the colons in the page name (e.g., "Sec1:1") wtih underscores.
          var myRegExp = new RegExp(":", "gi");
          myPageName = myPageName.replace(myRegExp, "_");
        //test
        var sufix=Math.random()*100000;
          myFilePath = myFolderName + "/" + myBaseName + "_" + myPageName +sufix+ ".pdf";
          myFile = new File(myFilePath);
          myDocument.exportFile(ExportFormat.pdfType, myFile);
        myDocument.close(SaveOptions.NO);
          myDocument = null;//delete document
          var end = new Date();
          Log("Start:" + start + ";End:" + end)
      function GetScriptPath() {
          // This function returns the path to the active script, even when running ESTK
          try {
              return app.activeScript.parent.fsName;
          } catch (e) {
              return File(e.filePath.parent.fsName);
      function Log(message) {
          var today = new Date();
          var logFile = new File(GetScriptPath() + "/myLog.txt");
          if (!logFile.exists) {
              // make new log file
              logFile.open("w");
              logFile.write(String(today) + "\nThe following messages were logged:\n");
              logFile.close();
          logFile.open("e");
          logFile.seek(0, 2);
          logFile.write("\n" + message);
          logFile.close();
           logFile=null;
