4 Replies Latest reply on Jul 23, 2015 7:04 AM by Johnwhite
    How to add a character style in active doc
    Johnwhite Level 1
      Hi experts
      How to create a character style in active doc.
      how to make the script as be works.
      Regard
      John
      var myCharacterStyle;
      var myDocument = app.activeDocument;
      var myCharacterStyle = myDocument.characterStyles.add({name:"c"});
      myCharacterStyle.strikeThru = true;
      myCharacterStyle.strokeColor = "Black";
          myCharacterStyle.add()
        • 1. Re: How to add a character style in active doc
          Loic.Aigon Adobe Community Professional
          There isn't much to say about your code. Only the last line would cause an issue. Also a possible hiccup lies on the fact that the style may already exist when you want to add it.
          var myCharacterStyle = myDocument.characterStyles.item ("c" );
          !myCharacterStyle.isValid && myCharacterStyle = myDocument.characterStyles.add({name:"c"});
          • 2. Re: How to add a character style in active doc
            Johnwhite Level 1
            Thank you Loic.Aigon
            thank you so much
            but how to create 2 character styles
            script as below how to make it work?
            !myCharacterStyle.isValid && myCharacterStyle myCharacterStyle = myDocument.characterStyles.add({name:"StrikeThru"});
            myCharacterStyle.strikeThroughColor = "Black";
            myCharacterStyle.strikeThroughWeight = 0.75;
            !myCharacterStyle.isValid && myCharacterStyle = myDocument.characterStyles.add({name:"Underline"});
            myCharacter.underline = true
            myCharacterStyle.underline = "Black";
            myCharacter.underlineWeight = 0.75;
            Regard
            John
            • 3. Re: How to add a character style in active doc
              Your problem is that you override the same character style reference while trying to add a new one. You have to understand the concept or references and variable declaration here:
              function doStyle ( doc, styleProps ) {
                   var cs = doc.characterStyles.item ( styleProps.name );
                   !cs.isValid && cs = doc.characterStyles.add();
                   cs.properties = styleProps;
              function main() {
                   var doc;
                   if ( !app.documents.length) return;
                   doc  =app.activeDocument;
                   var cs1 = {
                             strikeThru:true,
                             strikeThroughColor:"Black",
                             strikeThroughWeight :0.75,
                   var cs2 = {
                             underline:true,
                             underlineColor:"Black",
                             underlineWeight :0.75,
                   doStyle (doc,  cs1 );
                   doStyle (doc, cs2 );
              main();
              • 4. Re: How to add a character style in active doc
                Johnwhite Level 1
                thank you so much
                John
