2 Replies Latest reply on Jul 22, 2015 4:17 PM by WobertC
    how do you resize your photo
    takavulla Level 1
      I am working with a photo in Lightroom and I need to resize it for the size of paper I am using.  But I don't seem to be able to do it.
      I am sure there is a way, just not seeing it.  Is there a video on this
      tim
        • 1. Re: how do you resize your photo
          ManiacJoe Adobe Community Professional
          Resizing is done in the export dialog settings.
          Use the crop tool to get the correct aspect ratio (shape) for the print if you don't want margins on the paper.
          • 2. Re: how do you resize your photo
            WobertC Adobe Community Professional
            If you are printing to your own printer-
            There is no necessity to re-size or crop!
            In the Print module-
            In the Print / Layout Style Panel- Choose  "Single Image / Contact Sheet"
            Choose your paper size in "Page Setup"
            In the Print / Image Settings panel-
            A check tick in "Zoom to Fill" will crop your image to the paper format.  (Drag the image to re-position)
            No tick in "Zoom to Fill" will print your image as you cropped it in the Develop module (if you did a crop).
            In the Print / Layout Panel-
            Set the cell size as required (Sliders at Maximum will fill the Paper format)
            Set an change to margins (Sliders at all Minimum will fill the Paper format)
