1 Reply Latest reply on Jul 22, 2015 11:09 PM by Willi Adelberger
    dim text?
    marziab98084978
      Hi, When I add an image either jpeg or png, the text in the background dims. When i delete the image the text brightens up. It is white text on a black background. Any ideas?
        • 1. Re: dim text?
          You should inform us.
          1. What version of ID?
          2. What OS?
          3. Do you work with layers?
          4. Do you use transparency?
          5. Why are you using PNG files? If you have images, use PSD files, if you have graphics or drawings, use AI or PDF/X-4 files.
          6. Where do you see the problem? In InDesign or in an exported PDF? If in InDesign, how does it look like with Overprint Preview, if in PDF, which PDF viewer program are you using?
