• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Topic Missing in Printed Documentation
Community Beginner ,
Jul 23, 2015 Jul 23, 2015
I'm generating Printed Documentation from RoboHelp 10 HTMLHelp and I'm missing a topic.
The log shows that it is starts to process the file, but doesn't finish, and therefore no explanation of why.
I looked at the source for the file and it's identical to the file processed immediately prior, which is processed correctly.
Any suggestions?
-m
Here's the log.  I bolded the text that I referred to earlier:
Starting to build Printed Documentation...
Printed Documentation processor 10.0.0.287
Building C:\build\SyncDoc_src\syncDoc\mergedProjects\Syncref\all\!SSL!\BookTOC\File\BookTOC.doc ...
Preparing to create Printed Documentation...
Clearing output folder...
Preparing files for Print Document...
Copying files...
Updating files...
Finished preparing in 2 seconds.
Preparing environment...
Printed Document Generator Environment: Word 14.0.7151,  OS 6.1.7601, RAM 0 M Bytes
Building Printed Documentation 'BookTOC'...
Building Single Document 'BookTOC.doc'...
Building 'Title Page'...
Building 'Table of Contents'...
Preparing to build chapters...
Building 'Enterprise Object Viewing and Synchronization'...
Building 'entobject'...
Processing 'entobj'...
Building 'entobject show'...
Processing 'entobj show'...
Building 'entobject synchronize'...
Completed building chapters...
Building 'Index'...
Updating list paragraphs...
Updating images...
Updating page numbers...
Updating page headers...
Updating Table of Contents...
Updating Index...
Views
315
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert ,
Jul 24, 2015 Jul 24, 2015
LATEST
There is a topic causing the process to hang and it's usually not the one you think it is. However, first thing to do is exclude from the layout the topic you suspect. Either delete the topic from the print layout for now or tag it.
If that confirms it is some other topic, then divide and conquer is usually the quickest way to track down the offending topic.
Zip up the project so you have a copy that cannot accidentally be opened and worked on. That gives you a copy that you can safely revert to later if needed. Save the zip file somewhere safe.
Then create another copy of the project so that you have two copies that can be worked on.
Open Copy 1 and delete half the topics. Ignore any broken links reported. Generate the help from that copy.
Open Copy 2 and delete the other half of the topics. Generate the help from that copy.
It should be the case that one copy is now OK and one still has the problem.
Trash the good copy and then create a second copy of the copy with the problem.
Repeat the process until you have located the topic that is causing the problem.
The process takes less time than you might think.
@petergrainge
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
