3 Replies Latest reply on Jul 27, 2015 4:29 PM by Todd_Kopriva
    audio shortcut not working as expected ( . on keypad )
    TED-Ed
      Hi, I'm running After Effects CC 2015.0 Version 13.5.0.347 on a mid-2011 27" iMac that is running OS X 10.10.4 with 32 gigs of RAM and 3.4GHz core i7 processor.
      And I'm having an audio preview issue that I'm trying to figure out.
      When I just want to preview the audio, mainly to find out exactly where a word begins I use the . key on the keypad.
      In previous versions, when I used this shortcut, the audio would play from where the cursor was and when I pressed the . key a second time, the audio would stop and the playhead would return to where it was when I first pressed the . key.
      In the current version, I press the . key and the audio starts (and not exactly, e.g. the audio should say, "Over 20 million years,..." what it does play is, " r 20 million years,..." cutting off the first couple frames.). When I press the . key the second time, the playhead stops where it is and doesn't jump back to the previous point.
      Is there a way to bring back the old workflow?
      Franz
