18 Replies Latest reply on Aug 9, 2018 3:10 PM by Dov Isaacs
    How to print a booklet at 100%
    Document Geek Adobe Community Professional
      How can I print a booklet at 100%? When I print a booklet from Acrobat, it shrinks it slightly, about 5% or so (which I guessing is scale to fit). But I need the booklet printed at exactly 100%. Is this possible?
      I have every version of Acrobat from version 9 all the way up to DC, so I can use whichever one that will get the job done. I am on a mac.
        • 1. Re: How to print a booklet at 100%
          Anubha Goel Adobe Employee
          Hey Document Geek,
          Please refer the below mentioned KB doc to make sure that the PDF size is set to printable area.
          Scale or resize printed pages | Acrobat, Reader
          Let me know if that helps.
          Regards,
          Anubha
          • 2. Re: How to print a booklet at 100%
            Thanks for that, but the option for page scaling is not available when printing a booklet. See below. Am I missing something?
            • 3. Re: How to print a booklet at 100%
              MrTIFF Level 3
              Try:
              1. In the Print dialog, click "Page Setup..."
              2. In the "Page Setup..." dialog, you may have to create a 'Custom' 'paper size' that has "no margins", or set the margins to zero.
              ("Margins" here really means "the edges of the printable area".)
              3. Back in the main Acrobat Print dialog, click on the 'Size' button, and set the size to "Actual Size" or 100%.
              4. Click on the Booklet button, and print your Booklet.
              5. Oh, and make sure that there is enough space for your crop marks and bleeds. If not, make sure that marks and bleeds are turned off.
              Cheers,
              Stephen
              4 people found this helpful
              • 4. Re: How to print a booklet at 100%
                sdinweoinasd9384152 Level 1
                I'm having the same problem.  When I try to print a PDF in Acrobat as a booklet in the print dialog, the preview shows a huge margin and also on the printed pages.  There is a button "Page Setup" at the bottom of the dialog box, and clicking this opens another box that has paper size and margins.  However, margins is always 1 inch, and the field is grayed out and cannot be changed.  I tried selecting other paper sizes, creating custom sizes in both Adobe PDF printer and my HP printer, but the 1 inch margins are still grayed out.
                There are no other areas in the print menu that allows changing of the margins or selecting 100 % scaling when using the booklet function.
                Any ideas how to fix this?
                The PDF is in page format (instead of spread format), and page size of the PDF is A6 and I'm printing on A5 paper.  Since booklet puts 2 pages side by side, 2 A6 pages should fit perfectly on A5.  However, Acrobat keeps scaling them down with 1 inch margins.
                On the other hand, InDesign prints booklets fine, but I can't keep opening the InDesign files. I prefer to print the PDF from Acrobat.
                • 5. Re: How to print a booklet at 100%
                  MLSCHW
                  Did you find a solution? I have this problem as well both with print "booklet" and "multiple". Both options scale and add extra margins. I am using Acrobat DC 15.020.20042. I did not have this problem with the earlier licensed non-subscription versions of Acrobat.
                  • 6. Re: How to print a booklet at 100%
                    Dov Isaacs Adobe Employee
                    Unfortunately, the Print Booklet feature in Acrobat was designed to fit the logical pages of the booklet into the printable region of the physical pages. That means that unless your printer supports edge-to-edge printing (most toner and inkjet desktop and enterprise printers don't support this), the pages are shrunk into that printable region.
                    For PostScript printers, the printable region is determined by entries in the PPD file. You could conceivably edit the PostScript printer's PPD file to force the imageable area to match the physical page sizes, although this is a fairly non-trivial task. For non-PostScript printers, the imageable area may in fact be hard coded into the printer driver.
                              - Dov
                    • 7. Re: How to print a booklet at 100%
                      MLSCHW Level 1
                      Thank you for responding. InDesign's Print Booklet feature seems does not scale so I would have thought for consistency that Acrobat would be have been design the same. It seems Acrobat's multiple pages feature also was designed to fit the printable area despite the fact it claims to be doing n-up printing which I would interpret to include no scaling.
                      Given the number of people who I've seen trying to print both booklets and multiple page without scaling, could Adobe kindly:
                      1) Improve their existing documentation to include statements that "Print booklet will scale the pages to the printable region" and "Print Multiple will scale resulting pages to the printable region"
                      2) Add an "actual size" option to the print booklet and multiple page features in a future release. If InDesign can do this, I don't see why Acrobat cannot.
                      • 8. Re: How to print a booklet at 100%
                        Actually, I submitted an internal request for an option for the booklet printing to ignore imageable area considerations internally within Adobe a few times already. I'll see whether I can get some action on this.
                                  - Dov
                        2 people found this helpful
                        • 9. Re: How to print a booklet at 100%
                          koenraadm80162338 Level 1
                          Thank you Dov for this answer.
                          We are many persons waiting an excellent issue of your request. I wish you succes.
                          • 10. Re: How to print a booklet at 100%
                            howieb67625922
                            Hi, I want to print a booklet but the only binding options are left and right. I need a middle binding option otherwise I end up with two pages on page side by side that will not bind in the centre and fold up to make a booklet.
                            any ideas?
                            • 11. Re: How to print a booklet at 100%
                              Abambo Adobe Community Professional
                              Left binding: when the booklet is closed, the binding will be to the left.
                              Right binding: ..., the binding will be to the left.
                              It's about page placement not about stitching.
                              • 12. Re: How to print a booklet at 100%
                                jacquesg80657695
                                Hello Stephen,
                                Your method works perfectly !
                                Both pages expand on a wider space, but a problem persists...
                                I would like the gutter to be consistent with this enlargement because after binding it is difficult to read the middle part of the sheets of the booklet. Can you help me again ?
                                Thank you ;o)
                                Jacques
                                • 13. Re: How to print a booklet at 100%
                                  MrTIFF Level 3
                                  Hello Jacques,
                                  You are creeping further into the domain of generalized page imposition. I don't think that this can be done in Acrobat unless you buy one of the imposition extensions for Acrobat.
                                  If you're using InDesign, you can create extra space between logical pages, using either InDesign's "Print Booklet" command (File menu) or using my IDImposer extension.
                                  With Print Booklet, you would probably choose Booklet type = 2-up Consecutive, and a nonzero Space Between Pages, to do the type of job that I think you are doing.  If you are actually doing 'Saddle-Stitch' (folded and stapled in the middle), you would choose Booklet type = Saddle, and a nonzero Creep setting.
                                  Using IDImposer, you would choose Imposition Type = Consecutive, and a nonzero Horizontal Spacing value; or, if doing Saddle, choose Imposition Type = Saddle, and either Horizontal Spacing or Creep or both, to shift the page contents whichever way you require.
                                  Cheers,
                                  Stephen
                                  • 14. Re: How to print a booklet at 100%
                                    jacquesg80657695 Level 1
                                    Thank you very much, Stephen for this detailed answer !!!
                                    With your precious advice I will try to get what I'm looking for.
                                    Jacques
                                    • 15. Re: How to print a booklet at 100%
                                      RobinClay
                                      It seems to me that it's the printer at fault - its "printable area" is asymmetric, so you get a wider margin on one side than on the other.  I suppose the answer is to set the right hand margin of even numbered pages manually to a bigger value (No, I haven't tried it - yet)
                                      • 16. Re: How to print a booklet at 100%
                                        rolfek
                                        Thanks Stephen, Legend, This worked for me.
                                        I was printing from Mac, booklet layout from Adobe acrobat, in the print dialog I went to "Page Setup" > "Paper Size" > "Manage custom sizes" and turned all margins to zero.
                                        It meant that the centre lines of all the pages lined up again so I could fold and then trim one side.
                                        Rolfe Kolbe
                                        • 17. Re: How to print a booklet at 100%
                                          scottlininger
                                          This answer is not correct, at least on my printer and mac. Please see below. You can create a new page size *without margins* in the page setup dialog. No need to edit PPDs.
                                          • 18. Re: How to print a booklet at 100%
                                            That is the equivalent of editing PPDs for printable area on the MacOS side although it doesn't always work in my experiences.
                                                      - Dov
