2 Replies Latest reply on Jan 21, 2018 3:43 AM by johannesh86789092
    Is there a way to render a premiere project from the command line?
    mettam Level 1
      I render my cinematic sequences out of a game engine, I have a premiere project that is setup to source my rendered images and audio files are all assembled in the project as well.
      If there was a way to command line render the premiere project then I could execute that command right after the source images have been rendered.
        • 1. Re: Is there a way to render a premiere project from the command line?
          fsdafs
          I have basically the same question, so want to bump this thread to the top.
          In my case, I want to benchmark premiere elements with different numbers of cores.  I know how to set affinity when starting premiere, but is there a command line way to open Premiere, open a specific file and render it with specific settings?
          • 2. Re: Is there a way to render a premiere project from the command line?
            johannesh86789092
            Me too.
            I prepare my projects in advance and I want to run rendering over night.
            I need to find out how to run the program with command line arguments.
            This is my script so far.
                @echo off
                shutdown -a
                SET PATH=%PATH%;"C:\Program Files\Adobe\Adobe Premiere Elements 2018"
                SET "Target=Y:\CaptureData\BlenderOutput\Aypahyo\"
                FOR /F %%i IN ('dir /b *.prel') DO ( CALL :MAKEVIDEO %%i )
                GOTO :END
                :MAKEVIDEO
                REM HOW DO I USE THE COMMAND LINE
                REM PremiereElementsEditor.exe -RENDER -%1 -%Target%%1
                ECHO -RENDER -%1 -%Target%%1
                EXIT /B
                :END
                pause
