1 Reply Latest reply on Jul 25, 2015 12:14 AM by andrewfreeman
    Inverted Radial Filter Issues
    Sapien
      I am using Lightroom 5.7.1 with IMAC OS X  Yosemite 10.10.4 and have encountered an issue using the radial filter in inverted mode.  I am using it on a small object (moon) so the centre dot hides the detail I need to see. Thus, I need to make multiple incremental adjustments and turn the filter on and off in order to the results.  In the first instance the tool works fine but after I turn it off and then back on again the adjustments do not do anything.  The only way I can get it to work is to use the Reset button and I am back to square one.
      It was working but I was having an issue with the Brush not working.  Adjustments did nothing.  I followed Adobe's advise and deleted the preference file and restarted my computer.  That fixed the Brush issue but it is either a coincidence or the fix created a new issue.  This is very frustrating.  I will very much appreciate advice.
