7 Replies Latest reply on Sep 1, 2015 2:06 AM by christianbrugeron
    default resolution when exporting as png
    christianbrugeron Level 1
      Hi
      We are using cc2014 and cc2015 and both have not a way for setting PNG export resolution. We must rely on a previous export by the user. If not set, it takes a long time to export ununusable 112bytes PNG files!
      Any way to avoid that?
      Christian
        • 1. Re: default resolution when exporting as png
          Toto RoToTO Level 3
          Which method of which suite are you actually using for making your export?
          There is definitely a way to set resolution parameter depending on how you do that.
          Best regards,
          Thomas.
          • 2. Re: default resolution when exporting as png
            Hi
            Here is my code:
            err = sAIActionManager->AINewActionParamValue(&fActionParamValueRef);
            //ne doit pas être null,
            https://forums.adobe.com/thread/915571?start=0&tstart=0
                     err =
            sAIActionManager->AIActionSetStringUS(fActionParamValueRef,
            kAIExportDocumentNameKey, ai::UnicodeString(exportPath));
                     err =
            kAIExportDocumentFormatKey, ai::UnicodeString("Adobe PNG Format"));
                     err = sAIActionManager->AIActionSetString(fActionParamValueRef,
            kAIExportDocumentExtensionKey, "png");
                     err =
            sAIActionManager->AIActionSetBoolean(fActionParamValueRef,
            kAIExportDocumentSaveAllKey, false);
                     err =
            kAIExportDocumentSaveMultipleArtboardsKey, true);
            kAIExportDocumentSaveRangeKey, range);
                     err =
            kAIPDFRoundTripKey, false);
                     err =
            sAIActionManager->PlayActionEvent(kAIExportDocumentAction, kDialogOff,
            Without a proper manual initialisation by exporting a PNG (and
            correcting default values), exporting fails.
            The same is true with a fresh installation of Illustrator.
            Thank you for your help
            cb
            created by Toto RoToTO <https://forums.adobe.com/people/Toto+RoToTO>
            in /Illustrator SDK/ - View the full discussion
            <https://forums.adobe.com/message/7892014#7892014>
            • 3. Re: default resolution when exporting as png
              LeoTaro Level 4
              Have you had a look at AIImageOptimization.h, which includes AIImageOptSuite::AsPNG and AIImageOptSuite::MakePNG24. I haven't used them myself, but they include arguments for setting parameters like resolution.
              • 4. Re: default resolution when exporting as png
                I have heard of this suite but I think it is note related to the export actions.
                Do I have to rewrite the export code?
                cb
                • 5. Re: default resolution when exporting as png
                  Toto RoToTO Level 3
                  As leoTaro said, you should definitely take a look at AIImageOptimization.h and use MakePNG24 method.
                  Take a look at AIImageOptPNGParams2 and AIImageOptPNGParams structs, which are used by MakePNG24.
                  This way you could set the image resolution
                  AIErr result = kNoErr;
                  AIDataFilter* dstFilter = 0;
                  AIDataFilter* filter = 0;
                  result = sAIDataFilter->NewFileDataFilter(fileP, "write", 'prw', 'PNGf', &filter);
                  aisdk::check_ai_error(result);
                  result = sAIDataFilter->LinkDataFilter(dstFilter, filter);
                  dstFilter = filter;
                  AIImageOptPNGParams2 params;
                  params.versionOneSuiteParams.interlaced = ...;
                  params.versionOneSuiteParams.numberOfColors = ....;
                  params.versionOneSuiteParams.transparentIndex = ...;
                  params.versionOneSuiteParams.resolution = 300;
                  params.versionOneSuiteParams.outAlpha = ...;
                  params.antialias = ConfigurationManager::GetAntialias();
                  /* A cropping box for the art. If empty or degenerate, do not crop. */
                  params.cropBox = bounds;
                  params.backgroundIsTransparent = ConfigurationManager::GetBackgroundIsTransparentProperty();
                  result = sAIImageOpt->MakePNG24 (art, dstFilter, params, MyRasterizeProgressProc);
                  if (dstFilter)
                    result = sAIDataFilter->UnlinkDataFilter (dstFilter, &dstFilter);
                  I hope this will be helpful.
                  Thomas.
                  • 6. Re: default resolution when exporting as png
                    Toto RoToTO Level 3
                    So, is it working?
                    Did you use MakePNG24 ?
                    • 7. Re: default resolution when exporting as png
                      I was on another project, i'll try this afternoon (Paris time).
                      Christian Brugeron
                      christian@docinfo.fr
                      <https://forums.adobe.com/message/7918383#7918383>
