10 Replies Latest reply on May 13, 2006 6:44 PM by Newsgroup_User
    Erasing a specific color
    Gu-man
      Hello,
      I would like to erase a specific color from a graphic, like a white background, without using the eraser tool. Does anyone know oh to accomplish this in a simple/fast manner?
      Thanks!
      Gustavo
        • 1. Re: Erasing a specific color
          Level 7
          Here is an excellent read on the subject:
          Gu-man wrote:
          > Hello,
          > Thanks!
          > Gustavo
          • 2. Re: Erasing a specific color
            Level 7
            Ok ... one more time:
            http://www.pixelyzed.com/pixelforge/removebackgrounds/
            alex
            > Gu-man wrote:
            >> Hello,
            >> Thanks!
            >> Gustavo
            • 3. Re: Erasing a specific color
              Gu-man Level 1
              That is a good read. Thanks.
              However, I remember reading somewehere about a yet even simpler method that used the color pallete to delete the color from the graphic (in my case, a white background). Do oyu know about this approach.
              Gustavo
              • 4. Re: Erasing a specific color
                Level 7
                hmmmm .... use the wand tool to select the white area and hit Delete?
                > Gustavo
                • 5. Re: Erasing a specific color
                  Level 7
                  If you're talking color palettes then perhaps it had to do with
                  exporting the file as a Gif and setting that color as transparent.
                  Otherwise, The Magic wand (as Alex said) should do the job nicely.
                  Jim Babbage - .:CMX:. & .:ACE:.
                  Community MX
                  Extending Knowledge, Daily
                  http://www.communityMX.com/
                  .:Adobe Community Expert for Fireworks:.
                  news://forums.macromedia.com/macromedia.fireworks
                  news://forums.macromedia.com/macromedia.dreamweaver
                  >> approach.
                  >> Gustavo
                  • 6. Re: Erasing a specific color
                    Gu-man Level 1
                    The magic wand does not work as good as the method described in Pixelyzed (hence the method described there )
                    Jim: how do I set the 'white', let' say, to transparent when exporting as a GIF?
                    Thanks.
                    Gustavo
                    • 7. Re: Erasing a specific color
                      Level 7
                      Gustavo,
                      You would use the Optimization Panel for that. Use Index Transparency.
                      Jim
                      > GIF?
                      > Thanks.
                      > Gustavo
                      • 8. Re: Erasing a specific color
                        Level 7
                        Gu-man wrote:
                        > Hello,
                        > Thanks!
                        > Gustavo
                        hello gustavo
                        or just use a psp filter like eraser clasic from medhi
                        http://www.mehdiplugins.com/
                        hope that help
                        bretz
                        • 9. Re: Erasing a specific color
                          Gu-man Level 1
                          First: thanks very much to everyone for all the contributions. I find these forums "life-saving". What a great learning resource.
                          1) Eraser classic plugin: very nice. I am adding it to my bag of tricks . It seems that you do need to spend some time playing with the controls and going back and forth to check results (like anything else, no?).
                          2) I also tried playing with "interlace transparency" when saving the file as a GIF in FW. Works to some extent.
                          3) I think I have the best luck going around and deleting colors from the GIF palette. It took a bit of time but the results where better (at least with the logo I am working with) than the two previous methods.
                          I have not tried the masking method yet in http://www.pixelyzed.com/pixelforge/removebackgrounds/. After a quick read, sounds like it may still be the approach that produces the cleanest results, though there are a number of steps involved.
                          Thanks again to everyone. Keep up the good work out there.
                          Best,
                          Gustavo
                          Santa Fe, NM
                          • 10. Re: Erasing a specific color
                            Level 7
                            Thanks Alex! My apologies, Gustavo, for not responding sooner. Alex and
                            others have taken good care of you though. :-)
                            Community MX
                            > Gustavo,
                            > Jim
                            >> exporting as a GIF?
                            >> Thanks.
                            >> Gustavo
