3 Replies Latest reply on Jul 28, 2015 3:08 AM by mani@pixel
    how to remove or delete empty line space between paragraphs
    mani@pixel
      i want to remove or delete empty line space between paragraphs.
      and in each page contents should be end in same line at the bottom..
      like books...
        • 1. Re: how to remove or delete empty line space between paragraphs
          mani@pixel Level 1
          this is my code... but its not working ..
          pagefoot();
          function pagefoot()
             var doc = app.activeDocument;
             var allpage = doc.pages.everyItem();
             var i;
             //alert(allpage);
             doc.pages.everyItem().marginPreferences.bottom = "3";
             doc.pages.everyItem().marginPreferences.top = "3";
             doc.pages.everyItem().marginPreferences.left = "3";
             doc.pages.everyItem().marginPreferences.right = "3";
             const height = doc.documentPreferences.pageHeight;
               //alert(height);
             var custheight = 66.5;
             if(height != custheight)
             doc.documentPreferences.pageHeight = custheight;
             var allpara = doc.textFrames.everyItem().paragraphs;
             //alert(allpara.length);
             for(i=0;i<allpara.length;i++)
                 //alert(allpara[i].contents);
                 try
                 if(allpara[i].contents == "\r")
                     //alert("null");
                    allpara[i].remove();
             catch(e)
                 try
                 if(allpara[i].contents == " ")
                     //alert("hello");
                else
                     allpara[i].spaceBefore = 0;
             catch(e)
             //doc.documentPreferences.pageWidth = "51";
             //doc.documentPreferences.documentBleedBottomOffset ="3" ;
             // doc.documentPreferences.documentBleedLeftOffset ="3" ;
          • 2. Re: how to remove or delete empty line space between paragraphs
            Level 1
            #target indesign
            app.scriptPreferences.userInteractionLevel = UserInteractionLevels.interactWithAll;
            clean_up (app.activeDocument, true);
            var myDocument = app.activeDocument;
            //var inddFile = new File ( myDocument.filePath + "/Gardner.indd" );
            app.activeDocument.save();
            alert ("Clean_up Completed !!!!!!!!!!!!!")
            //exit();
            function clean_up (scope, caps)
            app.findGrepPreferences = app.changeGrepPreferences = null;
            app.findChangeGrepOptions.includeFootnotes = true;
            app.findChangeGrepOptions.includeHiddenLayers = true;
            app.findChangeGrepOptions.includeLockedLayersForFind = true;
            app.findChangeGrepOptions.includeLockedStoriesForFind = true;
            app.findChangeGrepOptions.includeMasterPages = true;
            //app.documents.everyItem().xmlElements.item(0).xmlElements.everyItem().untag();
            // series of tabs
            change_grep (scope, '\\t\\t+', '\\t');
            // series of returns
            change_grep (scope, '~b~b+', '~b');
            // series of spaces
            change_grep (scope, '\\x{20}\\x{20}+', '\\x{20}');
            // trailing spaces and tabs
            change_grep (scope, '\\s+$', "");
            // leading spaces/tabs
            change_grep (scope, '^\\s+', "");
            change_grep (scope, '~e+', '.~S.~S.');
            change_grep (scope, ' . . .', ' .~S.~S.~S.');
            function change_grep (obj, f, r)
            app.findGrepPreferences.findWhat = f;
            app.changeGrepPreferences.changeTo = r;
            obj.changeGrep()
            • 3. Re: how to remove or delete empty line space between paragraphs
              mani@pixel Level 1
              above code is working fine . but i want , each page contents should be end in same line at the bottom..
