Following this security patch, several purchased fonts are no longer in my font folder.
I've tried re-installing, and they're not showing as valid font types. I am using Windows 7.
Is this something Adobe are aware of and looking into? Any solution?
Moving the discussion to Adobe Type
We know of no “issues” such as you describe.
And in fact, I just tried installing Adobe's version of the VAGRoundedStd-Black font on my system with no problems whatsoever.
That having been said, the message on your screen may be the key to the problem!!!
The file name for the font should be VAGRoundedStd-Black.otf and not VAGRoundedStd-Black_0.otf as shown in your error dialog box. Did you modify the font in any way and save it with a new name because that is not the file name of the font if in fact you sourced it from Adobe.
- Dov
Hi Dov,
Well I guess now you do know about the issue As you can see below, I've not altered the fonts in any way (I don't know why the error message shows it in a different way. But whether I double click, or right click and Install, or move the files into my Fonts folder - all the same outcome I'm afraid.)
Just to be clear, following last week's Windows Update, the font no longer shows in my list of fonts. I've tried re-installing but to no avail. Now as the update specifically related to fonts - I thought it was a reasonable assumption it was the cause. My IT Company asked that in the first case I speak to who I purchased the font from, because it was highly likely this was a known issue with a fix.
In some ways I suppose I'm hoping now many others have a similar issue, so there can be a fix found...
Hi there. Having now examined and tested your specific Adobe font file (thank you for sending it), we here on the Adobe Type team are still unable to identify any technical problem with the font -- or reproduce what you are seeing in the specific Windows environment you've described and various other environments we've tried. A number of theories we've discussed here have been tested and ruled out.
Answering Dov's questions, above, might help our investigation. Without more information from you, and/or without reports about the same problem from other users, I'm afraid there's not much more we can do. Please let us know if you're interested in sharing more details about your own environment.
Regards,
Christopher
Oh, and just to show this has been purchased from Adobe.
I certainly believe that you acquired the fonts from Adobe. It was the name on the message you first showed that was very unusual.
I have the same Windows Update 3079904 installed on all four of my Windows 7 sp1 x64-based computers. I installed the same font you are having problems with on all four systems without any issue.
I suspect that something else is at play here. Do you have any third party “font managers” installed? Did you ever attempt to install a program called ATM - Adobe Type Manager - on this system? (That software, long since discontinued, will wreck font handling on current Windows versions.) Are you running 32-bit Windows or 64-bit Windows?
Finally, is this problem reproducible on any other system you have access to?
Otherwise, I'm stumped since we cannot reproduce the symptoms you describe here.
- Dov
Hi guys The problem has definitely been caused by the fix Windows pushed for the vulnerability in the OpenType manager module (atmfd.dll) which is provided by Adobe. I've been able to duplicate the issue on some of our PCs but not others - all of them are running Windows 7. Restoring a previous version of atmfd.dll enables us to reinstall/see/use the fonts, but I'm not keen to do so and potentially leave myself or our users compromised. What do you suggest, please?
Please be assured that we are taking your report very seriously.
However, for your information, although the module atmfd.dll was originally code developed by Adobe, it was given over to Microsoft for subsequent development and maintenance. We haven’t had any responsibility for that code for many years now.
It is interesting that you can duplicate the issue on some of your systems, but not on others. That does mean that there is something different about one set of systems versus the others.
Our staff would like for you to run an experiment on one of the systems showing the wayward symptoms. We have seen in the past where there are issues due to duplicate fonts with the same font name (but not exactly the same file name) in the Windows font directory. The fact that one of the messages you initially displayed showed the file name VAGRoundedStd-Black_0.otf makes that issue a possibility for the root cause of this problem on some but not all systems.
I have sent you an e-mail with directions as to what we would like you to try and again requesting some critical system configuration information such that we can try to figure out what is going on with your systems and if necessary, get Microsoft involved.
- Dov
