12 Replies Latest reply on Jul 29, 2015 3:58 AM by Brucgovn
    exit code 15 / ERROR DW051
    stubery
      Cannot update/install from CC2014 to 2015.
      "Update fehlgeschlagen" (error occured) > more info:
      Exit Code: 15
      Please see specific errors below for troubleshooting. For example, ERROR: DW051 ...
      -------------------------------------- Summary --------------------------------------
      - 0 fatal error(s), 1 error(s)
      ERROR: DW051: Dependency of session payload {3E7FC757-D497-4C89-A935-7D38E2164E85} Shared Technology Photoshop Camera Raw 8 8.0 has changed.
      Bildschirmfoto 2015-07-27 um 18.56.43.pngBildschirmfoto 2015-07-27 um 18.57.33.png
      I did:
      1. Logged off. Uninstall Creative Cloud // Reinstalled. > tried again. > stil not working/same error.
      2. Both recommended solutions here https://helpx.adobe.com/creative-suite/kb/exit-code-15-installing-ccm.html
      > still not working/same error.
      Log File of One Try:
      07/27/15 15:53:53:176 | [INFO] |  | OOBE | DE |  |  |  | 96264 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
      07/27/15 15:53:53:176 | [INFO] |  | OOBE | DE |  |  |  | 96264 | Visit http://www.adobe.com/go/loganalyzer/ for more information
      07/27/15 15:53:53:176 | [INFO] |  | OOBE | DE |  |  |  | 96264 | START - Installer Session
      07/27/15 15:53:53:176 | [INFO] |  | OOBE | DE |  |  |  | 96264 | RIBS version: 9.0.0.21
      07/27/15 15:53:53:176 | [INFO] |  | OOBE | DE |  |  |  | 96264 | OSX version: 10.10.3
      07/27/15 15:53:53:176 | [INFO] |  | OOBE | DE |  |  |  | 96264 | ::START TIMER:: [Total Timer]
      07/27/15 15:53:53:176 | [INFO] |  | OOBE | DE |  |  |  | 96264 | CHECK: Single instance running
      07/27/15 15:53:53:176 | [INFO] |  | OOBE | DE |  |  |  | 96264 | CHECK : Credentials
      07/27/15 15:53:53:176 | [INFO] |  | OOBE | DE |  |  |  | 96264 | Load Deployment File
      07/27/15 15:53:53:176 | [INFO] |  | OOBE | DE |  |  |  | 96264 | CHECK : Another Native OS installer already running
      07/27/15 15:53:53:176 | [INFO] |  | OOBE | DE |  |  |  | 96264 | Create Required Folders
      07/27/15 15:53:53:176 | [INFO] |  | OOBE | DE |  |  |  | 96264 | Assuming install mode
      07/27/15 15:53:53:176 | [INFO] |  | OOBE | DE |  |  |  | 96264 | Looking up install source path
      07/27/15 15:53:53:176 | [INFO] |  | OOBE | DE |  |  |  | 96264 | Sync Media DB ...
      07/27/15 15:53:53:176 | [INFO] |  | OOBE | DE |  |  |  | 96264 | ::START TIMER:: [Sync Media DB]
      07/27/15 15:53:53:176 | [INFO] |  | OOBE | DE |  |  |  | 96264 | Pre check media db sync
      07/27/15 15:53:53:176 | [INFO] |  | OOBE | DE |  |  |  | 96264 | DW051: Dependency of session payload {3E7FC757-D497-4C89-A935-7D38E2164E85} Shared Technology Photoshop Camera Raw 8 8.0 has changed.
      07/27/15 15:53:53:176 | [INFO] |  | OOBE | DE |  |  |  | 96264 |        Installed payload|Session payload
      07/27/15 15:53:53:176 | [INFO] |  | OOBE | DE |  |  |  | 96264 |        |Shared Technology:Camera Profiles Installer
      07/27/15 15:53:53:176 | [INFO] |  | OOBE | DE |  |  |  | 96264 | End of Pre check media db sync. Exit code: 2
      07/27/15 15:53:53:176 | [INFO] |  | OOBE | DE |  |  |  | 96264 | :: END TIMER :: [Sync Media DB] took 44 milliseconds (0.044 seconds)
      07/27/15 15:53:53:176 | [INFO] |  | OOBE | DE |  |  |  | 96264 | :: END TIMER :: [Total Timer] took 282 milliseconds (0.282 seconds)
      07/27/15 15:53:53:176 | [INFO] |  | OOBE | DE |  |  |  | 96264 | -------------------------------------- Summary --------------------------------------
      07/27/15 15:53:53:176 | [INFO] |  | OOBE | DE |  |  |  | 96264 |  - 0 fatal error(s), 1 error(s)
      07/27/15 15:53:53:176 | [INFO] |  | OOBE | DE |  |  |  | 96264 | ERROR: DW051: Dependency of session payload {3E7FC757-D497-4C89-A935-7D38E2164E85} Shared Technology Photoshop Camera Raw 8 8.0 has changed.
      07/27/15 15:53:53:176 | [INFO] |  | OOBE | DE |  |  |  | 96264 | Please search the above error string(s) to find when the error occurred.
      07/27/15 15:53:53:176 | [INFO] |  | OOBE | DE |  |  |  | 96264 | These errors resulted in installer Exit Code mentioned below.
      07/27/15 15:53:53:176 | [INFO] |  | OOBE | DE |  |  |  | 96264 | -------------------------------------------------------------------------------------
      07/27/15 15:53:53:176 | [INFO] |  | OOBE | DE |  |  |  | 96264 | Exit Code: 15 - Media DB Sync failed.
      07/27/15 15:53:53:177 | [INFO] |  | OOBE | DE |  |  |  | 96264 | -------------------- BEGIN - Updating Media Sources - BEGIN --------------------
      07/27/15 15:53:53:177 | [INFO] |  | OOBE | DE |  |  |  | 96264 | Updated source path: /private/tmp/10B1A3E1-79E1-4A9B-8A53-861753E34533/Photoshop_16_LS20/Adobe Photoshop CC 2015
      07/27/15 15:53:53:177 | [INFO] |  | OOBE | DE |  |  |  | 96264 | Updating media info for: {036D83B4-B185-438C-A160-A35D5C69F851}
      07/27/15 15:53:53:178 | [INFO] |  | OOBE | DE |  |  |  | 96264 |   Type: 1, Volume Order: 1, Media Name: Adobe Photoshop CC 2015
      07/27/15 15:53:53:178 | [INFO] |  | OOBE | DE |  |  |  | 96264 |   Path: /private/tmp/10B1A3E1-79E1-4A9B-8A53-861753E34533/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobeExportAssets2.0All/AdobeExportAssets2.0All.zip
      07/27/15 15:53:53:178 | [INFO] |  | OOBE | DE |  |  |  | 96264 | Updating media info for: {04E6495C-B47B-4717-A66B-42464D4587C4}
      07/27/15 15:53:53:178 | [INFO] |  | OOBE | DE |  |  |  | 96264 |   Path: /private/tmp/10B1A3E1-79E1-4A9B-8A53-861753E34533/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-pt_BR/AdobePhotoshop16-pt_BR.zip
      07/27/15 15:53:53:178 | [INFO] |  | OOBE | DE |  |  |  | 96264 | Updating media info for: {12FB4804-C605-4618-8A5B-1106E079BEA7}
      07/27/15 15:53:53:179 | [INFO] |  | OOBE | DE |  |  |  | 96264 |   Path: /private/tmp/10B1A3E1-79E1-4A9B-8A53-861753E34533/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-ja_JP/AdobePhotoshop16-ja_JP.zip
      07/27/15 15:53:53:179 | [INFO] |  | OOBE | DE |  |  |  | 96264 | Updating media info for: {1A25FAAD-B4A7-4BD7-9351-3B0016F82433}
      07/27/15 15:53:53:179 | [INFO] |  | OOBE | DE |  |  |  | 96264 |   Type: 1, Volume Order: 1, Media Name: Adobe Photoshop CC 2015
      07/27/15 15:53:53:179 | [INFO] |  | OOBE | DE |  |  |  | 96264 |   Path: /private/tmp/10B1A3E1-79E1-4A9B-8A53-861753E34533/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-tr_TR/AdobePhotoshop16-tr_TR.zip
      07/27/15 15:53:53:179 | [INFO] |  | OOBE | DE |  |  |  | 96264 | Updating media info for: {1AEB0FE2-94F8-4FB3-B1E3-F249DAD88A54}
      07/27/15 15:53:53:179 | [INFO] |  | OOBE | DE |  |  |  | 96264 |   Path: /private/tmp/10B1A3E1-79E1-4A9B-8A53-861753E34533/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-nl_NL/AdobePhotoshop16-nl_NL.zip
      07/27/15 15:53:53:179 | [INFO] |  | OOBE | DE |  |  |  | 96264 | Updating media info for: {24575604-BE64-481B-8FA4-386D22E128D8}
      07/27/15 15:53:53:180 | [INFO] |  | OOBE | DE |  |  |  | 96264 |   Type: 1, Volume Order: 1, Media Name: Adobe Photoshop CC 2015
      07/27/15 15:53:53:180 | [INFO] |  | OOBE | DE |  |  |  | 96264 |   Path: /private/tmp/10B1A3E1-79E1-4A9B-8A53-861753E34533/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-pl_PL/AdobePhotoshop16-pl_PL.zip
      07/27/15 15:53:53:180 | [INFO] |  | OOBE | DE |  |  |  | 96264 | Updating media info for: {2470E2BA-0C76-4FB8-9951-6A8C8006E879}
      07/27/15 15:53:53:180 | [INFO] |  | OOBE | DE |  |  |  | 96264 |   Path: /private/tmp/10B1A3E1-79E1-4A9B-8A53-861753E34533/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-da_DK/AdobePhotoshop16-da_DK.zip
      07/27/15 15:53:53:180 | [INFO] |  | OOBE | DE |  |  |  | 96264 | Updating media info for: {25138CDB-0110-42B4-9210-CCB6382D498F}
      07/27/15 15:53:53:180 | [INFO] |  | OOBE | DE |  |  |  | 96264 |   Path: /private/tmp/10B1A3E1-79E1-4A9B-8A53-861753E34533/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-ru_RU/AdobePhotoshop16-ru_RU.zip
      07/27/15 15:53:53:180 | [INFO] |  | OOBE | DE |  |  |  | 96264 | Updating media info for: {2614BC86-757D-4293-9E25-E4E16F370A9E}
      07/27/15 15:53:53:181 | [INFO] |  | OOBE | DE |  |  |  | 96264 |   Type: 1, Volume Order: 1, Media Name: Adobe Photoshop CC 2015
      07/27/15 15:53:53:181 | [INFO] |  | OOBE | DE |  |  |  | 96264 |   Path: /private/tmp/10B1A3E1-79E1-4A9B-8A53-861753E34533/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-Core/AdobePhotoshop16-Core.zip
      07/27/15 15:53:53:181 | [INFO] |  | OOBE | DE |  |  |  | 96264 | Updating media info for: {2A8D5184-32DE-431E-9E75-751D01300349}
      07/27/15 15:53:53:181 | [INFO] |  | OOBE | DE |  |  |  | 96264 |   Path: /private/tmp/10B1A3E1-79E1-4A9B-8A53-861753E34533/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-en_AE/AdobePhotoshop16-en_AE.zip
      07/27/15 15:53:53:181 | [INFO] |  | OOBE | DE |  |  |  | 96264 | Updating media info for: {2C0EA9DC-EC03-4B9A-8340-9412E1A7C91A}
      07/27/15 15:53:53:182 | [INFO] |  | OOBE | DE |  |  |  | 96264 |   Type: 1, Volume Order: 1, Media Name: Adobe Photoshop CC 2015
      07/27/15 15:53:53:182 | [INFO] |  | OOBE | DE |  |  |  | 96264 |   Path: /private/tmp/10B1A3E1-79E1-4A9B-8A53-861753E34533/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-es_MX/AdobePhotoshop16-es_MX.zip
      07/27/15 15:53:53:182 | [INFO] |  | OOBE | DE |  |  |  | 96264 | Updating media info for: {2CA9270E-4869-4E28-AC8A-42156340D608}
      07/27/15 15:53:53:182 | [INFO] |  | OOBE | DE |  |  |  | 96264 |   Path: /private/tmp/10B1A3E1-79E1-4A9B-8A53-861753E34533/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-uk_UA/AdobePhotoshop16-uk_UA.zip
      07/27/15 15:53:53:182 | [INFO] |  | OOBE | DE |  |  |  | 96264 | Updating media info for: {3774910E-19EF-4220-86D1-EC1CBD9AC2E9}
      07/27/15 15:53:53:182 | [INFO] |  | OOBE | DE |  |  |  | 96264 |   Path: /private/tmp/10B1A3E1-79E1-4A9B-8A53-861753E34533/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-de_DE/AdobePhotoshop16-de_DE.zip
      07/27/15 15:53:53:182 | [INFO] |  | OOBE | DE |  |  |  | 96264 | Updating media info for: {37CDAC6E-35D7-47E4-8463-A7C5553A5ED7}
      07/27/15 15:53:53:183 | [INFO] |  | OOBE | DE |  |  |  | 96264 |   Type: 1, Volume Order: 1, Media Name: Adobe Photoshop CC 2015
      07/27/15 15:53:53:183 | [INFO] |  | OOBE | DE |  |  |  | 96264 |   Path: /private/tmp/10B1A3E1-79E1-4A9B-8A53-861753E34533/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-zh_CN/AdobePhotoshop16-zh_CN.zip
      07/27/15 15:53:53:183 | [INFO] |  | OOBE | DE |  |  |  | 96264 | Updating media info for: {3971EECB-2A4B-416C-90E1-DF0626B412C8}
      07/27/15 15:53:53:183 | [INFO] |  | OOBE | DE |  |  |  | 96264 |   Path: /private/tmp/10B1A3E1-79E1-4A9B-8A53-861753E34533/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-fr_MA/AdobePhotoshop16-fr_MA.zip
      07/27/15 15:53:53:183 | [INFO] |  | OOBE | DE |  |  |  | 96264 | Updating media info for: {3C297E82-A8EC-4001-B267-5756C48ACA17}
      07/27/15 15:53:53:183 | [INFO] |  | OOBE | DE |  |  |  | 96264 |   Path: /private/tmp/10B1A3E1-79E1-4A9B-8A53-861753E34533/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-fr_CA/AdobePhotoshop16-fr_CA.zip
      07/27/15 15:53:53:183 | [INFO] |  | OOBE | DE |  |  |  | 96264 | Updating media info for: {3E7FC757-D497-4C89-A935-7D38E2164E85}
      07/27/15 15:53:53:184 | [INFO] |  | OOBE | DE |  |  |  | 96264 |   Type: 1, Volume Order: 1, Media Name: Adobe Photoshop CC 2015
      07/27/15 15:53:53:184 | [INFO] |  | OOBE | DE |  |  |  | 96264 |   Path: /private/tmp/10B1A3E1-79E1-4A9B-8A53-861753E34533/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobeCameraRaw8.0All/AdobeCameraRaw8.0All.zip
      07/27/15 15:53:53:184 | [INFO] |  | OOBE | DE |  |  |  | 96264 | Updating media info for: {3FB7A108-368A-4849-A3F3-69571BAAC457}
      07/27/15 15:53:53:184 | [INFO] |  | OOBE | DE |  |  |  | 96264 |   Path: /private/tmp/10B1A3E1-79E1-4A9B-8A53-861753E34533/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-Support/AdobePhotoshop16-Support.zip
      07/27/15 15:53:53:184 | [INFO] |  | OOBE | DE |  |  |  | 96264 | Updating media info for: {52D57F95-000A-4922-BB31-C6A936F4FD7D}
      07/27/15 15:53:53:185 | [INFO] |  | OOBE | DE |  |  |  | 96264 |   Type: 1, Volume Order: 1, Media Name: Adobe Photoshop CC 2015
      07/27/15 15:53:53:185 | [INFO] |  | OOBE | DE |  |  |  | 96264 |   Path: /private/tmp/10B1A3E1-79E1-4A9B-8A53-861753E34533/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobeColorJA_Recommended5_0-mul/AdobeColorJA_Recommended5_0-mul.zip
      07/27/15 15:53:53:185 | [INFO] |  | OOBE | DE |  |  |  | 96264 | Updating media info for: {5310A323-84E1-4957-8AF3-454921295D9D}
      07/27/15 15:53:53:185 | [INFO] |  | OOBE | DE |  |  |  | 96264 |   Path: /private/tmp/10B1A3E1-79E1-4A9B-8A53-861753E34533/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-hu_HU/AdobePhotoshop16-hu_HU.zip
      07/27/15 15:53:53:185 | [INFO] |  | OOBE | DE |  |  |  | 96264 | Updating media info for: {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}
      07/27/15 15:53:53:185 | [INFO] |  | OOBE | DE |  |  |  | 96264 |   Path: /private/tmp/10B1A3E1-79E1-4A9B-8A53-861753E34533/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobeCameraRawProfile8.0All/AdobeCameraRawProfile8.0All.zip
      07/27/15 15:53:53:185 | [INFO] |  | OOBE | DE |  |  |  | 96264 | Updating media info for: {5C5D62C9-91C6-415E-857E-9130C0F52C66}
      07/27/15 15:53:53:186 | [INFO] |  | OOBE | DE |  |  |  | 96264 |   Type: 1, Volume Order: 1, Media Name: Adobe Photoshop CC 2015
      07/27/15 15:53:53:186 | [INFO] |  | OOBE | DE |  |  |  | 96264 |   Path: /private/tmp/10B1A3E1-79E1-4A9B-8A53-861753E34533/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobeColorPhotoshop5_0-mul/AdobeColorPhotoshop5_0-mul.zip
      07/27/15 15:53:53:186 | [INFO] |  | OOBE | DE |  |  |  | 96264 | Updating media info for: {67759AA1-0FD6-47FE-B449-492DC8B26D89}
      07/27/15 15:53:53:186 | [INFO] |  | OOBE | DE |  |  |  | 96264 |   Path: /private/tmp/10B1A3E1-79E1-4A9B-8A53-861753E34533/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-en_US/AdobePhotoshop16-en_US.zip
      07/27/15 15:53:53:186 | [INFO] |  | OOBE | DE |  |  |  | 96264 | Updating media info for: {6B3589E5-D734-4AF1-9C13-A2D7C67ACE7E}
      07/27/15 15:53:53:187 | [INFO] |  | OOBE | DE |  |  |  | 96264 |   Path: /private/tmp/10B1A3E1-79E1-4A9B-8A53-861753E34533/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-fr_FR/AdobePhotoshop16-fr_FR.zip
      07/27/15 15:53:53:187 | [INFO] |  | OOBE | DE |  |  |  | 96264 | Updating media info for: {72405B80-A3DD-4BB2-A8C4-A90BC7BA50FF}
      07/27/15 15:53:53:187 | [INFO] |  | OOBE | DE |  |  |  | 96264 |   Type: 1, Volume Order: 1, Media Name: Adobe Photoshop CC 2015
      07/27/15 15:53:53:187 | [INFO] |  | OOBE | DE |  |  |  | 96264 |   Path: /private/tmp/10B1A3E1-79E1-4A9B-8A53-861753E34533/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobeColorNA_ExtraSettings5_0-mul/AdobeColorNA_ExtraSettings5_0-mul.zip
      07/27/15 15:53:53:187 | [INFO] |  | OOBE | DE |  |  |  | 96264 | Updating media info for: {7421A999-B08C-4A4B-B659-AD752AE330A5}
      07/27/15 15:53:53:187 | [INFO] |  | OOBE | DE |  |  |  | 96264 |   Path: /private/tmp/10B1A3E1-79E1-4A9B-8A53-861753E34533/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-it_IT/AdobePhotoshop16-it_IT.zip
      07/27/15 15:53:53:187 | [INFO] |  | OOBE | DE |  |  |  | 96264 | Updating media info for: {7F847394-8F78-4A5E-9936-4522CFBA8BD4}
      07/27/15 15:53:53:188 | [INFO] |  | OOBE | DE |  |  |  | 96264 |   Type: 1, Volume Order: 1, Media Name: Adobe Photoshop CC 2015
      07/27/15 15:53:53:188 | [INFO] |  | OOBE | DE |  |  |  | 96264 |   Path: /private/tmp/10B1A3E1-79E1-4A9B-8A53-861753E34533/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-en_IL/AdobePhotoshop16-en_IL.zip
      07/27/15 15:53:53:188 | [INFO] |  | OOBE | DE |  |  |  | 96264 | Updating media info for: {946BF592-2F57-4810-8D1D-EDAA7F49F1C6}
      07/27/15 15:53:53:188 | [INFO] |  | OOBE | DE |  |  |  | 96264 |   Path: /private/tmp/10B1A3E1-79E1-4A9B-8A53-861753E34533/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-cs_CZ/AdobePhotoshop16-cs_CZ.zip
      07/27/15 15:53:53:188 | [INFO] |  | OOBE | DE |  |  |  | 96264 | Updating media info for: {9579E86C-CF60-43F3-A2DF-331D411D8270}
      07/27/15 15:53:53:188 | [INFO] |  | OOBE | DE |  |  |  | 96264 |   Path: /private/tmp/10B1A3E1-79E1-4A9B-8A53-861753E34533/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-zh_TW/AdobePhotoshop16-zh_TW.zip
      07/27/15 15:53:53:188 | [INFO] |  | OOBE | DE |  |  |  | 96264 | Updating media info for: {9E9EB9FD-FDE8-487A-A41C-7713DA91AC89}
      07/27/15 15:53:53:189 | [INFO] |  | OOBE | DE |  |  |  | 96264 |   Type: 1, Volume Order: 1, Media Name: Adobe Photoshop CC 2015
      07/27/15 15:53:53:189 | [INFO] |  | OOBE | DE |  |  |  | 96264 |   Path: /private/tmp/10B1A3E1-79E1-4A9B-8A53-861753E34533/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobeColorEU_Recommended5_0-mul/AdobeColorEU_Recommended5_0-mul.zip
      07/27/15 15:53:53:189 | [INFO] |  | OOBE | DE |  |  |  | 96264 | Updating media info for: {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}
      07/27/15 15:53:53:189 | [INFO] |  | OOBE | DE |  |  |  | 96264 |   Path: /private/tmp/10B1A3E1-79E1-4A9B-8A53-861753E34533/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobeColorJA_ExtraSettings5_0-mul/AdobeColorJA_ExtraSettings5_0-mul.zip
      07/27/15 15:53:53:189 | [INFO] |  | OOBE | DE |  |  |  | 96264 | Updating media info for: {AB955DCF-69CD-4840-B7FB-F318CDD0AE44}
      07/27/15 15:53:53:190 | [INFO] |  | OOBE | DE |  |  |  | 96264 |   Type: 1, Volume Order: 1, Media Name: Adobe Photoshop CC 2015
      07/27/15 15:53:53:190 | [INFO] |  | OOBE | DE |  |  |  | 96264 |   Path: /private/tmp/10B1A3E1-79E1-4A9B-8A53-861753E34533/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobeColorNA_Recommended5_0-mul/AdobeColorNA_Recommended5_0-mul.zip
      07/27/15 15:53:53:190 | [INFO] |  | OOBE | DE |  |  |  | 96264 | Updating media info for: {ABD0FB37-08A2-4B4F-8AD7-88A6C03330CB}
      07/27/15 15:53:53:190 | [INFO] |  | OOBE | DE |  |  |  | 96264 |   Path: /private/tmp/10B1A3E1-79E1-4A9B-8A53-861753E34533/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePreview1.0All-osx10/AdobePreview1.0All-osx10.zip
      07/27/15 15:53:53:190 | [INFO] |  | OOBE | DE |  |  |  | 96264 | Updating media info for: {ACC1C515-792E-4CD0-98B7-ED65BB20BC6B}
      07/27/15 15:53:53:190 | [INFO] |  | OOBE | DE |  |  |  | 96264 |   Path: /private/tmp/10B1A3E1-79E1-4A9B-8A53-861753E34533/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-sv_SE/AdobePhotoshop16-sv_SE.zip
      07/27/15 15:53:53:190 | [INFO] |  | OOBE | DE |  |  |  | 96264 | Updating media info for: {B06BF9B2-FB59-475A-9F9E-1FDFE48E828B}
      07/27/15 15:53:53:191 | [INFO] |  | OOBE | DE |  |  |  | 96264 |   Type: 1, Volume Order: 1, Media Name: Adobe Photoshop CC 2015
      07/27/15 15:53:53:191 | [INFO] |  | OOBE | DE |  |  |  | 96264 |   Path: /private/tmp/10B1A3E1-79E1-4A9B-8A53-861753E34533/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-fi_FI/AdobePhotoshop16-fi_FI.zip
      07/27/15 15:53:53:191 | [INFO] |  | OOBE | DE |  |  |  | 96264 | Updating media info for: {BCA6D2ED-0ACF-4A36-A617-EDF6B133B732}
      07/27/15 15:53:53:191 | [INFO] |  | OOBE | DE |  |  |  | 96264 |   Path: /private/tmp/10B1A3E1-79E1-4A9B-8A53-861753E34533/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-nb_NO/AdobePhotoshop16-nb_NO.zip
      07/27/15 15:53:53:191 | [INFO] |  | OOBE | DE |  |  |  | 96264 | Updating media info for: {C22A37BD-D19A-4AEA-BF17-EAD1FA824D62}
      07/27/15 15:53:53:192 | [INFO] |  | OOBE | DE |  |  |  | 96264 |   Type: 1, Volume Order: 1, Media Name: Adobe Photoshop CC 2015
      07/27/15 15:53:53:192 | [INFO] |  | OOBE | DE |  |  |  | 96264 |   Path: /private/tmp/10B1A3E1-79E1-4A9B-8A53-861753E34533/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-ko_KR/AdobePhotoshop16-ko_KR.zip
      07/27/15 15:53:53:192 | [INFO] |  | OOBE | DE |  |  |  | 96264 | Updating media info for: {C4196275-B11A-40A1-8727-3C145C8F7D95}
      07/27/15 15:53:53:192 | [INFO] |  | OOBE | DE |  |  |  | 96264 |   Path: /private/tmp/10B1A3E1-79E1-4A9B-8A53-861753E34533/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobeColorCommonSetCMYK5_0-mul/AdobeColorCommonSetCMYK5_0-mul.zip
      07/27/15 15:53:53:192 | [INFO] |  | OOBE | DE |  |  |  | 96264 | Updating media info for: {C8DEBB29-3EB0-4B97-B652-4DE482B111BC}
      07/27/15 15:53:53:192 | [INFO] |  | OOBE | DE |  |  |  | 96264 |   Path: /private/tmp/10B1A3E1-79E1-4A9B-8A53-861753E34533/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobeColorCommonSetRGB5_0-mul/AdobeColorCommonSetRGB5_0-mul.zip
      07/27/15 15:53:53:192 | [INFO] |  | OOBE | DE |  |  |  | 96264 | Updating media info for: {CE9B1B00-0421-4701-9698-1C14646D6D94}
      07/27/15 15:53:53:193 | [INFO] |  | OOBE | DE |  |  |  | 96264 |   Type: 1, Volume Order: 1, Media Name: Adobe Photoshop CC 2015
      07/27/15 15:53:53:193 | [INFO] |  | OOBE | DE |  |  |  | 96264 |   Path: /private/tmp/10B1A3E1-79E1-4A9B-8A53-861753E34533/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobeVideoProfilesCS5_0-mul/AdobeVideoProfilesCS5_0-mul.zip
      07/27/15 15:53:53:193 | [INFO] |  | OOBE | DE |  |  |  | 96264 | Updating media info for: {DCC00639-486F-45AF-9E32-666B754DB49E}
      07/27/15 15:53:53:193 | [INFO] |  | OOBE | DE |  |  |  | 96264 |   Path: /private/tmp/10B1A3E1-79E1-4A9B-8A53-861753E34533/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-en_GB/AdobePhotoshop16-en_GB.zip
      07/27/15 15:53:53:193 | [INFO] |  | OOBE | DE |  |  |  | 96264 | Updating media info for: {E01A53CC-3419-4F62-A758-7ACF940BA008}
      07/27/15 15:53:53:193 | [INFO] |  | OOBE | DE |  |  |  | 96264 |   Path: /private/tmp/10B1A3E1-79E1-4A9B-8A53-861753E34533/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-es_ES/AdobePhotoshop16-es_ES.zip
      07/27/15 15:53:53:194 | [INFO] |  | OOBE | DE |  |  |  | 96264 | Updating media info for: {F6DED2DA-1D20-497E-8810-E745B45DCD28}
      07/27/15 15:53:53:194 | [INFO] |  | OOBE | DE |  |  |  | 96264 |   Type: 1, Volume Order: 1, Media Name: Adobe Photoshop CC 2015
      07/27/15 15:53:53:194 | [INFO] |  | OOBE | DE |  |  |  | 96264 |   Path: /private/tmp/10B1A3E1-79E1-4A9B-8A53-861753E34533/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobeColorEU_ExtraSettings5_0-mul/AdobeColorEU_ExtraSettings5_0-mul.zip
      07/27/15 15:53:53:194 | [INFO] |  | OOBE | DE |  |  |  | 96264 | --------------------  END  - Updating Media Sources -  END  --------------------
      07/27/15 15:53:53:204 | [ERROR] |  | OOBE | DE |  |  |  | 96264 | ASU has quit unexpectedly.
      07/27/15 16:09:32:098 | [INFO] |  | OOBE | DE |  |  |  | 188307 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
      07/27/15 16:09:32:098 | [INFO] |  | OOBE | DE |  |  |  | 188307 | Visit http://www.adobe.com/go/loganalyzer/ for more information
      07/27/15 16:09:32:098 | [INFO] |  | OOBE | DE |  |  |  | 188307 | START - Installer Session
      07/27/15 16:09:32:098 | [INFO] |  | OOBE | DE |  |  |  | 188307 | RIBS version: 9.0.0.21
      07/27/15 16:09:32:099 | [INFO] |  | OOBE | DE |  |  |  | 188307 | OSX version: 10.10.3
      07/27/15 16:09:32:099 | [INFO] |  | OOBE | DE |  |  |  | 188307 | ::START TIMER:: [Total Timer]
      07/27/15 16:09:32:099 | [INFO] |  | OOBE | DE |  |  |  | 188307 | CHECK: Single instance running
      07/27/15 16:09:32:099 | [INFO] |  | OOBE | DE |  |  |  | 188307 | CHECK : Credentials
      07/27/15 16:09:32:099 | [INFO] |  | OOBE | DE |  |  |  | 188307 | Load Deployment File
      07/27/15 16:09:32:099 | [INFO] |  | OOBE | DE |  |  |  | 188307 | CHECK : Another Native OS installer already running
      07/27/15 16:09:32:099 | [INFO] |  | OOBE | DE |  |  |  | 188307 | Create Required Folders
      07/27/15 16:09:32:099 | [INFO] |  | OOBE | DE |  |  |  | 188307 | Assuming install mode
      07/27/15 16:09:32:099 | [INFO] |  | OOBE | DE |  |  |  | 188307 | Looking up install source path
      07/27/15 16:09:32:099 | [INFO] |  | OOBE | DE |  |  |  | 188307 | Sync Media DB ...
      07/27/15 16:09:32:099 | [INFO] |  | OOBE | DE |  |  |  | 188307 | ::START TIMER:: [Sync Media DB]
      07/27/15 16:09:32:099 | [INFO] |  | OOBE | DE |  |  |  | 188307 | Pre check media db sync
      07/27/15 16:09:32:099 | [INFO] |  | OOBE | DE |  |  |  | 188307 | DW051: Dependency of session payload {3E7FC757-D497-4C89-A935-7D38E2164E85} Shared Technology Photoshop Camera Raw 8 8.0 has changed.
      07/27/15 16:09:32:099 | [INFO] |  | OOBE | DE |  |  |  | 188307 |        Installed payload|Session payload
      07/27/15 16:09:32:099 | [INFO] |  | OOBE | DE |  |  |  | 188307 |        |Shared Technology:Camera Profiles Installer
      07/27/15 16:09:32:099 | [INFO] |  | OOBE | DE |  |  |  | 188307 | End of Pre check media db sync. Exit code: 2
      07/27/15 16:09:32:099 | [INFO] |  | OOBE | DE |  |  |  | 188307 | :: END TIMER :: [Sync Media DB] took 40 milliseconds (0.04 seconds)
      07/27/15 16:09:32:099 | [INFO] |  | OOBE | DE |  |  |  | 188307 | :: END TIMER :: [Total Timer] took 525 milliseconds (0.525 seconds) DTR = 21668.6 KBPS (21.1607 MBPS)
      07/27/15 16:09:32:099 | [INFO] |  | OOBE | DE |  |  |  | 188307 | -------------------------------------- Summary --------------------------------------
      07/27/15 16:09:32:099 | [INFO] |  | OOBE | DE |  |  |  | 188307 |  - 0 fatal error(s), 1 error(s)
      07/27/15 16:09:32:099 | [INFO] |  | OOBE | DE |  |  |  | 188307 | ERROR: DW051: Dependency of session payload {3E7FC757-D497-4C89-A935-7D38E2164E85} Shared Technology Photoshop Camera Raw 8 8.0 has changed.
      07/27/15 16:09:32:099 | [INFO] |  | OOBE | DE |  |  |  | 188307 | Please search the above error string(s) to find when the error occurred.
      07/27/15 16:09:32:099 | [INFO] |  | OOBE | DE |  |  |  | 188307 | These errors resulted in installer Exit Code mentioned below.
      07/27/15 16:09:32:099 | [INFO] |  | OOBE | DE |  |  |  | 188307 | -------------------------------------------------------------------------------------
      07/27/15 16:09:32:099 | [INFO] |  | OOBE | DE |  |  |  | 188307 | Exit Code: 15 - Media DB Sync failed.
      07/27/15 16:09:32:099 | [INFO] |  | OOBE | DE |  |  |  | 188307 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
      07/27/15 16:09:32:099 | [INFO] |  | OOBE | DE |  |  |  | 188307 | Visit http://www.adobe.com/go/loganalyzer/ for more information
      07/27/15 16:09:32:099 | [INFO] |  | OOBE | DE |  |  |  | 188307 | START - Installer Session
      07/27/15 16:09:32:099 | [INFO] |  | OOBE | DE |  |  |  | 188307 | RIBS version: 9.0.0.21
      07/27/15 16:09:32:099 | [INFO] |  | OOBE | DE |  |  |  | 188307 | -------------------- BEGIN - Updating Media Sources - BEGIN --------------------
      07/27/15 16:09:32:099 | [INFO] |  | OOBE | DE |  |  |  | 188307 | Updated source path: /private/tmp/66AAC771-CFF5-4571-A5E0-04C520EADD21/Photoshop_16_LS20/Adobe Photoshop CC 2015
      07/27/15 16:09:32:099 | [INFO] |  | OOBE | DE |  |  |  | 188307 | Updating media info for: {036D83B4-B185-438C-A160-A35D5C69F851}
      07/27/15 16:09:32:100 | [INFO] |  | OOBE | DE |  |  |  | 188307 |   Type: 1, Volume Order: 1, Media Name: Adobe Photoshop CC 2015
      07/27/15 16:09:32:100 | [INFO] |  | OOBE | DE |  |  |  | 188307 |   Path: /private/tmp/66AAC771-CFF5-4571-A5E0-04C520EADD21/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobeExportAssets2.0All/AdobeExportAssets2.0All.zip
      07/27/15 16:09:32:100 | [INFO] |  | OOBE | DE |  |  |  | 188307 | Updating media info for: {04E6495C-B47B-4717-A66B-42464D4587C4}
      07/27/15 16:09:32:101 | [INFO] |  | OOBE | DE |  |  |  | 188307 |   Path: /private/tmp/66AAC771-CFF5-4571-A5E0-04C520EADD21/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-pt_BR/AdobePhotoshop16-pt_BR.zip
      07/27/15 16:09:32:101 | [INFO] |  | OOBE | DE |  |  |  | 188307 | Updating media info for: {12FB4804-C605-4618-8A5B-1106E079BEA7}
      07/27/15 16:09:32:101 | [INFO] |  | OOBE | DE |  |  |  | 188307 |   Type: 1, Volume Order: 1, Media Name: Adobe Photoshop CC 2015
      07/27/15 16:09:32:101 | [INFO] |  | OOBE | DE |  |  |  | 188307 |   Path: /private/tmp/66AAC771-CFF5-4571-A5E0-04C520EADD21/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-ja_JP/AdobePhotoshop16-ja_JP.zip
      07/27/15 16:09:32:101 | [INFO] |  | OOBE | DE |  |  |  | 188307 | Updating media info for: {1A25FAAD-B4A7-4BD7-9351-3B0016F82433}
      07/27/15 16:09:32:101 | [INFO] |  | OOBE | DE |  |  |  | 188307 |   Path: /private/tmp/66AAC771-CFF5-4571-A5E0-04C520EADD21/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-tr_TR/AdobePhotoshop16-tr_TR.zip
      07/27/15 16:09:32:101 | [INFO] |  | OOBE | DE |  |  |  | 188307 | Updating media info for: {1AEB0FE2-94F8-4FB3-B1E3-F249DAD88A54}
      07/27/15 16:09:32:102 | [INFO] |  | OOBE | DE |  |  |  | 188307 |   Type: 1, Volume Order: 1, Media Name: Adobe Photoshop CC 2015
      07/27/15 16:09:32:102 | [INFO] |  | OOBE | DE |  |  |  | 188307 |   Path: /private/tmp/66AAC771-CFF5-4571-A5E0-04C520EADD21/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-nl_NL/AdobePhotoshop16-nl_NL.zip
      07/27/15 16:09:32:102 | [INFO] |  | OOBE | DE |  |  |  | 188307 | Updating media info for: {24575604-BE64-481B-8FA4-386D22E128D8}
      07/27/15 16:09:32:102 | [INFO] |  | OOBE | DE |  |  |  | 188307 |   Path: /private/tmp/66AAC771-CFF5-4571-A5E0-04C520EADD21/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-pl_PL/AdobePhotoshop16-pl_PL.zip
      07/27/15 16:09:32:102 | [INFO] |  | OOBE | DE |  |  |  | 188307 | Updating media info for: {2470E2BA-0C76-4FB8-9951-6A8C8006E879}
      07/27/15 16:09:32:102 | [INFO] |  | OOBE | DE |  |  |  | 188307 |   Path: /private/tmp/66AAC771-CFF5-4571-A5E0-04C520EADD21/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-da_DK/AdobePhotoshop16-da_DK.zip
      07/27/15 16:09:32:102 | [INFO] |  | OOBE | DE |  |  |  | 188307 | Updating media info for: {25138CDB-0110-42B4-9210-CCB6382D498F}
      07/27/15 16:09:32:103 | [INFO] |  | OOBE | DE |  |  |  | 188307 |   Type: 1, Volume Order: 1, Media Name: Adobe Photoshop CC 2015
      07/27/15 16:09:32:103 | [INFO] |  | OOBE | DE |  |  |  | 188307 |   Path: /private/tmp/66AAC771-CFF5-4571-A5E0-04C520EADD21/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-ru_RU/AdobePhotoshop16-ru_RU.zip
      07/27/15 16:09:32:103 | [INFO] |  | OOBE | DE |  |  |  | 188307 | Updating media info for: {2614BC86-757D-4293-9E25-E4E16F370A9E}
      07/27/15 16:09:32:103 | [INFO] |  | OOBE | DE |  |  |  | 188307 |   Path: /private/tmp/66AAC771-CFF5-4571-A5E0-04C520EADD21/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-Core/AdobePhotoshop16-Core.zip
      07/27/15 16:09:32:103 | [INFO] |  | OOBE | DE |  |  |  | 188307 | Updating media info for: {2A8D5184-32DE-431E-9E75-751D01300349}
      07/27/15 16:09:32:104 | [INFO] |  | OOBE | DE |  |  |  | 188307 |   Type: 1, Volume Order: 1, Media Name: Adobe Photoshop CC 2015
      07/27/15 16:09:32:104 | [INFO] |  | OOBE | DE |  |  |  | 188307 |   Path: /private/tmp/66AAC771-CFF5-4571-A5E0-04C520EADD21/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-en_AE/AdobePhotoshop16-en_AE.zip
      07/27/15 16:09:32:104 | [INFO] |  | OOBE | DE |  |  |  | 188307 | Updating media info for: {2C0EA9DC-EC03-4B9A-8340-9412E1A7C91A}
      07/27/15 16:09:32:104 | [INFO] |  | OOBE | DE |  |  |  | 188307 |   Path: /private/tmp/66AAC771-CFF5-4571-A5E0-04C520EADD21/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-es_MX/AdobePhotoshop16-es_MX.zip
      07/27/15 16:09:32:104 | [INFO] |  | OOBE | DE |  |  |  | 188307 | Updating media info for: {2CA9270E-4869-4E28-AC8A-42156340D608}
      07/27/15 16:09:32:104 | [INFO] |  | OOBE | DE |  |  |  | 188307 |   Path: /private/tmp/66AAC771-CFF5-4571-A5E0-04C520EADD21/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-uk_UA/AdobePhotoshop16-uk_UA.zip
      07/27/15 16:09:32:104 | [INFO] |  | OOBE | DE |  |  |  | 188307 | Updating media info for: {3774910E-19EF-4220-86D1-EC1CBD9AC2E9}
      07/27/15 16:09:32:105 | [INFO] |  | OOBE | DE |  |  |  | 188307 |   Type: 1, Volume Order: 1, Media Name: Adobe Photoshop CC 2015
      07/27/15 16:09:32:105 | [INFO] |  | OOBE | DE |  |  |  | 188307 |   Path: /private/tmp/66AAC771-CFF5-4571-A5E0-04C520EADD21/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-de_DE/AdobePhotoshop16-de_DE.zip
      07/27/15 16:09:32:105 | [INFO] |  | OOBE | DE |  |  |  | 188307 | Updating media info for: {37CDAC6E-35D7-47E4-8463-A7C5553A5ED7}
      07/27/15 16:09:32:105 | [INFO] |  | OOBE | DE |  |  |  | 188307 |   Path: /private/tmp/66AAC771-CFF5-4571-A5E0-04C520EADD21/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-zh_CN/AdobePhotoshop16-zh_CN.zip
      07/27/15 16:09:32:105 | [INFO] |  | OOBE | DE |  |  |  | 188307 | Updating media info for: {3971EECB-2A4B-416C-90E1-DF0626B412C8}
      07/27/15 16:09:32:106 | [INFO] |  | OOBE | DE |  |  |  | 188307 |   Type: 1, Volume Order: 1, Media Name: Adobe Photoshop CC 2015
      07/27/15 16:09:32:106 | [INFO] |  | OOBE | DE |  |  |  | 188307 |   Path: /private/tmp/66AAC771-CFF5-4571-A5E0-04C520EADD21/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-fr_MA/AdobePhotoshop16-fr_MA.zip
      07/27/15 16:09:32:106 | [INFO] |  | OOBE | DE |  |  |  | 188307 | Updating media info for: {3C297E82-A8EC-4001-B267-5756C48ACA17}
      07/27/15 16:09:32:106 | [INFO] |  | OOBE | DE |  |  |  | 188307 |   Path: /private/tmp/66AAC771-CFF5-4571-A5E0-04C520EADD21/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-fr_CA/AdobePhotoshop16-fr_CA.zip
      07/27/15 16:09:32:106 | [INFO] |  | OOBE | DE |  |  |  | 188307 | Updating media info for: {3E7FC757-D497-4C89-A935-7D38E2164E85}
      07/27/15 16:09:32:106 | [INFO] |  | OOBE | DE |  |  |  | 188307 |   Path: /private/tmp/66AAC771-CFF5-4571-A5E0-04C520EADD21/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobeCameraRaw8.0All/AdobeCameraRaw8.0All.zip
      07/27/15 16:09:32:106 | [INFO] |  | OOBE | DE |  |  |  | 188307 | Updating media info for: {3FB7A108-368A-4849-A3F3-69571BAAC457}
      07/27/15 16:09:32:107 | [INFO] |  | OOBE | DE |  |  |  | 188307 |   Type: 1, Volume Order: 1, Media Name: Adobe Photoshop CC 2015
      07/27/15 16:09:32:107 | [INFO] |  | OOBE | DE |  |  |  | 188307 |   Path: /private/tmp/66AAC771-CFF5-4571-A5E0-04C520EADD21/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-Support/AdobePhotoshop16-Support.zip
      07/27/15 16:09:32:107 | [INFO] |  | OOBE | DE |  |  |  | 188307 | Updating media info for: {52D57F95-000A-4922-BB31-C6A936F4FD7D}
      07/27/15 16:09:32:107 | [INFO] |  | OOBE | DE |  |  |  | 188307 |   Path: /private/tmp/66AAC771-CFF5-4571-A5E0-04C520EADD21/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobeColorJA_Recommended5_0-mul/AdobeColorJA_Recommended5_0-mul.zip
      07/27/15 16:09:32:107 | [INFO] |  | OOBE | DE |  |  |  | 188307 | Updating media info for: {5310A323-84E1-4957-8AF3-454921295D9D}
      07/27/15 16:09:32:107 | [INFO] |  | OOBE | DE |  |  |  | 188307 |   Path: /private/tmp/66AAC771-CFF5-4571-A5E0-04C520EADD21/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-hu_HU/AdobePhotoshop16-hu_HU.zip
      07/27/15 16:09:32:108 | [INFO] |  | OOBE | DE |  |  |  | 188307 | Updating media info for: {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}
      07/27/15 16:09:32:108 | [INFO] |  | OOBE | DE |  |  |  | 188307 |   Type: 1, Volume Order: 1, Media Name: Adobe Photoshop CC 2015
      07/27/15 16:09:32:108 | [INFO] |  | OOBE | DE |  |  |  | 188307 |   Path: /private/tmp/66AAC771-CFF5-4571-A5E0-04C520EADD21/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobeCameraRawProfile8.0All/AdobeCameraRawProfile8.0All.zip
      07/27/15 16:09:32:108 | [INFO] |  | OOBE | DE |  |  |  | 188307 | Updating media info for: {5C5D62C9-91C6-415E-857E-9130C0F52C66}
      07/27/15 16:09:32:108 | [INFO] |  | OOBE | DE |  |  |  | 188307 |   Path: /private/tmp/66AAC771-CFF5-4571-A5E0-04C520EADD21/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobeColorPhotoshop5_0-mul/AdobeColorPhotoshop5_0-mul.zip
      07/27/15 16:09:32:108 | [INFO] |  | OOBE | DE |  |  |  | 188307 | Updating media info for: {67759AA1-0FD6-47FE-B449-492DC8B26D89}
      07/27/15 16:09:32:109 | [INFO] |  | OOBE | DE |  |  |  | 188307 |   Type: 1, Volume Order: 1, Media Name: Adobe Photoshop CC 2015
      07/27/15 16:09:32:109 | [INFO] |  | OOBE | DE |  |  |  | 188307 |   Path: /private/tmp/66AAC771-CFF5-4571-A5E0-04C520EADD21/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-en_US/AdobePhotoshop16-en_US.zip
      07/27/15 16:09:32:109 | [INFO] |  | OOBE | DE |  |  |  | 188307 | Updating media info for: {6B3589E5-D734-4AF1-9C13-A2D7C67ACE7E}
      07/27/15 16:09:32:109 | [INFO] |  | OOBE | DE |  |  |  | 188307 |   Path: /private/tmp/66AAC771-CFF5-4571-A5E0-04C520EADD21/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-fr_FR/AdobePhotoshop16-fr_FR.zip
      07/27/15 16:09:32:109 | [INFO] |  | OOBE | DE |  |  |  | 188307 | Updating media info for: {72405B80-A3DD-4BB2-A8C4-A90BC7BA50FF}
      07/27/15 16:09:32:109 | [INFO] |  | OOBE | DE |  |  |  | 188307 |   Path: /private/tmp/66AAC771-CFF5-4571-A5E0-04C520EADD21/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobeColorNA_ExtraSettings5_0-mul/AdobeColorNA_ExtraSettings5_0-mul.zip
      07/27/15 16:09:32:109 | [INFO] |  | OOBE | DE |  |  |  | 188307 | Updating media info for: {7421A999-B08C-4A4B-B659-AD752AE330A5}
      07/27/15 16:09:32:110 | [INFO] |  | OOBE | DE |  |  |  | 188307 |   Type: 1, Volume Order: 1, Media Name: Adobe Photoshop CC 2015
      07/27/15 16:09:32:110 | [INFO] |  | OOBE | DE |  |  |  | 188307 |   Path: /private/tmp/66AAC771-CFF5-4571-A5E0-04C520EADD21/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-it_IT/AdobePhotoshop16-it_IT.zip
      07/27/15 16:09:32:110 | [INFO] |  | OOBE | DE |  |  |  | 188307 | Updating media info for: {7F847394-8F78-4A5E-9936-4522CFBA8BD4}
      07/27/15 16:09:32:110 | [INFO] |  | OOBE | DE |  |  |  | 188307 |   Path: /private/tmp/66AAC771-CFF5-4571-A5E0-04C520EADD21/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-en_IL/AdobePhotoshop16-en_IL.zip
      07/27/15 16:09:32:110 | [INFO] |  | OOBE | DE |  |  |  | 188307 | Updating media info for: {946BF592-2F57-4810-8D1D-EDAA7F49F1C6}
      07/27/15 16:09:32:111 | [INFO] |  | OOBE | DE |  |  |  | 188307 |   Type: 1, Volume Order: 1, Media Name: Adobe Photoshop CC 2015
      07/27/15 16:09:32:111 | [INFO] |  | OOBE | DE |  |  |  | 188307 |   Path: /private/tmp/66AAC771-CFF5-4571-A5E0-04C520EADD21/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-cs_CZ/AdobePhotoshop16-cs_CZ.zip
      07/27/15 16:09:32:111 | [INFO] |  | OOBE | DE |  |  |  | 188307 | Updating media info for: {9579E86C-CF60-43F3-A2DF-331D411D8270}
      07/27/15 16:09:32:111 | [INFO] |  | OOBE | DE |  |  |  | 188307 |   Path: /private/tmp/66AAC771-CFF5-4571-A5E0-04C520EADD21/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-zh_TW/AdobePhotoshop16-zh_TW.zip
      07/27/15 16:09:32:111 | [INFO] |  | OOBE | DE |  |  |  | 188307 | Updating media info for: {9E9EB9FD-FDE8-487A-A41C-7713DA91AC89}
      07/27/15 16:09:32:111 | [INFO] |  | OOBE | DE |  |  |  | 188307 |   Path: /private/tmp/66AAC771-CFF5-4571-A5E0-04C520EADD21/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobeColorEU_Recommended5_0-mul/AdobeColorEU_Recommended5_0-mul.zip
      07/27/15 16:09:32:111 | [INFO] |  | OOBE | DE |  |  |  | 188307 | Updating media info for: {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}
      07/27/15 16:09:32:112 | [INFO] |  | OOBE | DE |  |  |  | 188307 |   Type: 1, Volume Order: 1, Media Name: Adobe Photoshop CC 2015
      07/27/15 16:09:32:112 | [INFO] |  | OOBE | DE |  |  |  | 188307 |   Path: /private/tmp/66AAC771-CFF5-4571-A5E0-04C520EADD21/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobeColorJA_ExtraSettings5_0-mul/AdobeColorJA_ExtraSettings5_0-mul.zip
      07/27/15 16:09:32:112 | [INFO] |  | OOBE | DE |  |  |  | 188307 | Updating media info for: {AB955DCF-69CD-4840-B7FB-F318CDD0AE44}
      07/27/15 16:09:32:112 | [INFO] |  | OOBE | DE |  |  |  | 188307 |   Path: /private/tmp/66AAC771-CFF5-4571-A5E0-04C520EADD21/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobeColorNA_Recommended5_0-mul/AdobeColorNA_Recommended5_0-mul.zip
      07/27/15 16:09:32:112 | [INFO] |  | OOBE | DE |  |  |  | 188307 | Updating media info for: {ABD0FB37-08A2-4B4F-8AD7-88A6C03330CB}
      07/27/15 16:09:32:112 | [INFO] |  | OOBE | DE |  |  |  | 188307 |   Path: /private/tmp/66AAC771-CFF5-4571-A5E0-04C520EADD21/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePreview1.0All-osx10/AdobePreview1.0All-osx10.zip
      07/27/15 16:09:32:113 | [INFO] |  | OOBE | DE |  |  |  | 188307 | Updating media info for: {ACC1C515-792E-4CD0-98B7-ED65BB20BC6B}
      07/27/15 16:09:32:113 | [INFO] |  | OOBE | DE |  |  |  | 188307 |   Type: 1, Volume Order: 1, Media Name: Adobe Photoshop CC 2015
      07/27/15 16:09:32:113 | [INFO] |  | OOBE | DE |  |  |  | 188307 |   Path: /private/tmp/66AAC771-CFF5-4571-A5E0-04C520EADD21/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-sv_SE/AdobePhotoshop16-sv_SE.zip
      07/27/15 16:09:32:113 | [INFO] |  | OOBE | DE |  |  |  | 188307 | Updating media info for: {B06BF9B2-FB59-475A-9F9E-1FDFE48E828B}
      07/27/15 16:09:32:113 | [INFO] |  | OOBE | DE |  |  |  | 188307 |   Path: /private/tmp/66AAC771-CFF5-4571-A5E0-04C520EADD21/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-fi_FI/AdobePhotoshop16-fi_FI.zip
      07/27/15 16:09:32:113 | [INFO] |  | OOBE | DE |  |  |  | 188307 | Updating media info for: {BCA6D2ED-0ACF-4A36-A617-EDF6B133B732}
      07/27/15 16:09:32:114 | [INFO] |  | OOBE | DE |  |  |  | 188307 |   Type: 1, Volume Order: 1, Media Name: Adobe Photoshop CC 2015
      07/27/15 16:09:32:114 | [INFO] |  | OOBE | DE |  |  |  | 188307 |   Path: /private/tmp/66AAC771-CFF5-4571-A5E0-04C520EADD21/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-nb_NO/AdobePhotoshop16-nb_NO.zip
      07/27/15 16:09:32:114 | [INFO] |  | OOBE | DE |  |  |  | 188307 | Updating media info for: {C22A37BD-D19A-4AEA-BF17-EAD1FA824D62}
      07/27/15 16:09:32:114 | [INFO] |  | OOBE | DE |  |  |  | 188307 |   Path: /private/tmp/66AAC771-CFF5-4571-A5E0-04C520EADD21/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-ko_KR/AdobePhotoshop16-ko_KR.zip
      07/27/15 16:09:32:114 | [INFO] |  | OOBE | DE |  |  |  | 188307 | Updating media info for: {C4196275-B11A-40A1-8727-3C145C8F7D95}
      07/27/15 16:09:32:114 | [INFO] |  | OOBE | DE |  |  |  | 188307 |   Path: /private/tmp/66AAC771-CFF5-4571-A5E0-04C520EADD21/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobeColorCommonSetCMYK5_0-mul/AdobeColorCommonSetCMYK5_0-mul.zip
      07/27/15 16:09:32:114 | [INFO] |  | OOBE | DE |  |  |  | 188307 | Updating media info for: {C8DEBB29-3EB0-4B97-B652-4DE482B111BC}
      07/27/15 16:09:32:115 | [INFO] |  | OOBE | DE |  |  |  | 188307 |   Type: 1, Volume Order: 1, Media Name: Adobe Photoshop CC 2015
      07/27/15 16:09:32:115 | [INFO] |  | OOBE | DE |  |  |  | 188307 |   Path: /private/tmp/66AAC771-CFF5-4571-A5E0-04C520EADD21/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobeColorCommonSetRGB5_0-mul/AdobeColorCommonSetRGB5_0-mul.zip
      07/27/15 16:09:32:115 | [INFO] |  | OOBE | DE |  |  |  | 188307 | Updating media info for: {CE9B1B00-0421-4701-9698-1C14646D6D94}
      07/27/15 16:09:32:115 | [INFO] |  | OOBE | DE |  |  |  | 188307 |   Path: /private/tmp/66AAC771-CFF5-4571-A5E0-04C520EADD21/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobeVideoProfilesCS5_0-mul/AdobeVideoProfilesCS5_0-mul.zip
      07/27/15 16:09:32:115 | [INFO] |  | OOBE | DE |  |  |  | 188307 | Updating media info for: {DCC00639-486F-45AF-9E32-666B754DB49E}
      07/27/15 16:09:32:115 | [INFO] |  | OOBE | DE |  |  |  | 188307 |   Path: /private/tmp/66AAC771-CFF5-4571-A5E0-04C520EADD21/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-en_GB/AdobePhotoshop16-en_GB.zip
      07/27/15 16:09:32:115 | [INFO] |  | OOBE | DE |  |  |  | 188307 | Updating media info for: {E01A53CC-3419-4F62-A758-7ACF940BA008}
      07/27/15 16:09:32:116 | [INFO] |  | OOBE | DE |  |  |  | 188307 |   Type: 1, Volume Order: 1, Media Name: Adobe Photoshop CC 2015
      07/27/15 16:09:32:116 | [INFO] |  | OOBE | DE |  |  |  | 188307 |   Path: /private/tmp/66AAC771-CFF5-4571-A5E0-04C520EADD21/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-es_ES/AdobePhotoshop16-es_ES.zip
      07/27/15 16:09:32:116 | [INFO] |  | OOBE | DE |  |  |  | 188307 | Updating media info for: {F6DED2DA-1D20-497E-8810-E745B45DCD28}
      07/27/15 16:09:32:116 | [INFO] |  | OOBE | DE |  |  |  | 188307 |   Path: /private/tmp/66AAC771-CFF5-4571-A5E0-04C520EADD21/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobeColorEU_ExtraSettings5_0-mul/AdobeColorEU_ExtraSettings5_0-mul.zip
      07/27/15 16:09:32:116 | [INFO] |  | OOBE | DE |  |  |  | 188307 | --------------------  END  - Updating Media Sources -  END  --------------------
      07/27/15 16:09:32:127 | [ERROR] |  | OOBE | DE |  |  |  | 188307 | ASU has quit unexpectedly.
      07/27/15 18:12:02:825 | [INFO] |  | OOBE | DE |  |  |  | 584582 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
      07/27/15 18:12:02:825 | [INFO] |  | OOBE | DE |  |  |  | 584582 | Visit http://www.adobe.com/go/loganalyzer/ for more information
      07/27/15 18:12:02:825 | [INFO] |  | OOBE | DE |  |  |  | 584582 | START - Installer Session
      07/27/15 18:12:02:825 | [INFO] |  | OOBE | DE |  |  |  | 584582 | RIBS version: 9.0.0.23
      07/27/15 18:12:02:826 | [INFO] |  | OOBE | DE |  |  |  | 584582 | OSX version: 10.10.3
      07/27/15 18:12:02:826 | [INFO] |  | OOBE | DE |  |  |  | 584582 | ::START TIMER:: [Total Timer]
      07/27/15 18:12:02:826 | [INFO] |  | OOBE | DE |  |  |  | 584582 | CHECK: Single instance running
      07/27/15 18:12:02:826 | [INFO] |  | OOBE | DE |  |  |  | 584582 | CHECK : Credentials
      07/27/15 18:12:02:826 | [INFO] |  | OOBE | DE |  |  |  | 584582 | Load Deployment File
      07/27/15 18:12:02:826 | [INFO] |  | OOBE | DE |  |  |  | 584582 | CHECK : Another Native OS installer already running
      07/27/15 18:12:02:826 | [INFO] |  | OOBE | DE |  |  |  | 584582 | Create Required Folders
      07/27/15 18:12:02:826 | [INFO] |  | OOBE | DE |  |  |  | 584582 | Assuming install mode
      07/27/15 18:12:02:826 | [INFO] |  | OOBE | DE |  |  |  | 584582 | Looking up install source path
      07/27/15 18:12:02:826 | [INFO] |  | OOBE | DE |  |  |  | 584582 | Sync Media DB ...
      07/27/15 18:12:02:826 | [INFO] |  | OOBE | DE |  |  |  | 584582 | ::START TIMER:: [Sync Media DB]
      07/27/15 18:12:02:826 | [INFO] |  | OOBE | DE |  |  |  | 584582 | Pre check media db sync
      07/27/15 18:12:02:826 | [INFO] |  | OOBE | DE |  |  |  | 584582 | DW051: Dependency of session payload {3E7FC757-D497-4C89-A935-7D38E2164E85} Shared Technology Photoshop Camera Raw 8 8.0 has changed.
      07/27/15 18:12:02:826 | [INFO] |  | OOBE | DE |  |  |  | 584582 |        Installed payload|Session payload
      07/27/15 18:12:02:826 | [INFO] |  | OOBE | DE |  |  |  | 584582 |        |Shared Technology:Camera Profiles Installer
      07/27/15 18:12:02:826 | [INFO] |  | OOBE | DE |  |  |  | 584582 | End of Pre check media db sync. Exit code: 2
      07/27/15 18:12:02:826 | [INFO] |  | OOBE | DE |  |  |  | 584582 | :: END TIMER :: [Sync Media DB] took 50 milliseconds (0.05 seconds)
      07/27/15 18:12:02:826 | [INFO] |  | OOBE | DE |  |  |  | 584582 | :: END TIMER :: [Total Timer] took 270 milliseconds (0.27 seconds) DTR = 14.8148 KBPS (0.0144676 MBPS)
      07/27/15 18:12:02:826 | [INFO] |  | OOBE | DE |  |  |  | 584582 | -------------------------------------- Summary --------------------------------------
      07/27/15 18:12:02:826 | [INFO] |  | OOBE | DE |  |  |  | 584582 |  - 0 fatal error(s), 1 error(s)
      07/27/15 18:12:02:826 | [INFO] |  | OOBE | DE |  |  |  | 584582 | ERROR: DW051: Dependency of session payload {3E7FC757-D497-4C89-A935-7D38E2164E85} Shared Technology Photoshop Camera Raw 8 8.0 has changed.
      07/27/15 18:12:02:826 | [INFO] |  | OOBE | DE |  |  |  | 584582 | Please search the above error string(s) to find when the error occurred.
      07/27/15 18:12:02:826 | [INFO] |  | OOBE | DE |  |  |  | 584582 | These errors resulted in installer Exit Code mentioned below.
      07/27/15 18:12:02:826 | [INFO] |  | OOBE | DE |  |  |  | 584582 | -------------------------------------------------------------------------------------
      07/27/15 18:12:02:826 | [INFO] |  | OOBE | DE |  |  |  | 584582 | Exit Code: 15 - Media DB Sync failed.
      07/27/15 18:12:02:826 | [INFO] |  | OOBE | DE |  |  |  | 584582 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
      07/27/15 18:12:02:826 | [INFO] |  | OOBE | DE |  |  |  | 584582 | Visit http://www.adobe.com/go/loganalyzer/ for more information
      07/27/15 18:12:02:826 | [INFO] |  | OOBE | DE |  |  |  | 584582 | START - Installer Session
      07/27/15 18:12:02:826 | [INFO] |  | OOBE | DE |  |  |  | 584582 | RIBS version: 9.0.0.23
      07/27/15 18:12:02:826 | [INFO] |  | OOBE | DE |  |  |  | 584582 | -------------------- BEGIN - Updating Media Sources - BEGIN --------------------
      07/27/15 18:12:02:826 | [INFO] |  | OOBE | DE |  |  |  | 584582 | Updated source path: /private/tmp/4C1C985E-0AE5-4C94-A051-0DFB26551D36/Photoshop_16_LS20/Adobe Photoshop CC 2015
      07/27/15 18:12:02:826 | [INFO] |  | OOBE | DE |  |  |  | 584582 | Updating media info for: {036D83B4-B185-438C-A160-A35D5C69F851}
      07/27/15 18:12:02:827 | [INFO] |  | OOBE | DE |  |  |  | 584582 |   Type: 1, Volume Order: 1, Media Name: Adobe Photoshop CC 2015
      07/27/15 18:12:02:827 | [INFO] |  | OOBE | DE |  |  |  | 584582 |   Path: /private/tmp/4C1C985E-0AE5-4C94-A051-0DFB26551D36/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobeExportAssets2.0All/AdobeExportAssets2.0All.zip
      07/27/15 18:12:02:827 | [INFO] |  | OOBE | DE |  |  |  | 584582 | Updating media info for: {04E6495C-B47B-4717-A66B-42464D4587C4}
      07/27/15 18:12:02:827 | [INFO] |  | OOBE | DE |  |  |  | 584582 |   Path: /private/tmp/4C1C985E-0AE5-4C94-A051-0DFB26551D36/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-pt_BR/AdobePhotoshop16-pt_BR.zip
      07/27/15 18:12:02:827 | [INFO] |  | OOBE | DE |  |  |  | 584582 | Updating media info for: {12FB4804-C605-4618-8A5B-1106E079BEA7}
      07/27/15 18:12:02:828 | [INFO] |  | OOBE | DE |  |  |  | 584582 |   Type: 1, Volume Order: 1, Media Name: Adobe Photoshop CC 2015
      07/27/15 18:12:02:828 | [INFO] |  | OOBE | DE |  |  |  | 584582 |   Path: /private/tmp/4C1C985E-0AE5-4C94-A051-0DFB26551D36/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-ja_JP/AdobePhotoshop16-ja_JP.zip
      07/27/15 18:12:02:828 | [INFO] |  | OOBE | DE |  |  |  | 584582 | Updating media info for: {1A25FAAD-B4A7-4BD7-9351-3B0016F82433}
      07/27/15 18:12:02:828 | [INFO] |  | OOBE | DE |  |  |  | 584582 |   Path: /private/tmp/4C1C985E-0AE5-4C94-A051-0DFB26551D36/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-tr_TR/AdobePhotoshop16-tr_TR.zip
      07/27/15 18:12:02:828 | [INFO] |  | OOBE | DE |  |  |  | 584582 | Updating media info for: {1AEB0FE2-94F8-4FB3-B1E3-F249DAD88A54}
      07/27/15 18:12:02:828 | [INFO] |  | OOBE | DE |  |  |  | 584582 |   Path: /private/tmp/4C1C985E-0AE5-4C94-A051-0DFB26551D36/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-nl_NL/AdobePhotoshop16-nl_NL.zip
      07/27/15 18:12:02:828 | [INFO] |  | OOBE | DE |  |  |  | 584582 | Updating media info for: {24575604-BE64-481B-8FA4-386D22E128D8}
      07/27/15 18:12:02:829 | [INFO] |  | OOBE | DE |  |  |  | 584582 |   Type: 1, Volume Order: 1, Media Name: Adobe Photoshop CC 2015
      07/27/15 18:12:02:829 | [INFO] |  | OOBE | DE |  |  |  | 584582 |   Path: /private/tmp/4C1C985E-0AE5-4C94-A051-0DFB26551D36/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-pl_PL/AdobePhotoshop16-pl_PL.zip
      07/27/15 18:12:02:829 | [INFO] |  | OOBE | DE |  |  |  | 584582 | Updating media info for: {2470E2BA-0C76-4FB8-9951-6A8C8006E879}
      07/27/15 18:12:02:829 | [INFO] |  | OOBE | DE |  |  |  | 584582 |   Path: /private/tmp/4C1C985E-0AE5-4C94-A051-0DFB26551D36/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-da_DK/AdobePhotoshop16-da_DK.zip
      07/27/15 18:12:02:829 | [INFO] |  | OOBE | DE |  |  |  | 584582 | Updating media info for: {25138CDB-0110-42B4-9210-CCB6382D498F}
      07/27/15 18:12:02:830 | [INFO] |  | OOBE | DE |  |  |  | 584582 |   Type: 1, Volume Order: 1, Media Name: Adobe Photoshop CC 2015
      07/27/15 18:12:02:830 | [INFO] |  | OOBE | DE |  |  |  | 584582 |   Path: /private/tmp/4C1C985E-0AE5-4C94-A051-0DFB26551D36/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-ru_RU/AdobePhotoshop16-ru_RU.zip
      07/27/15 18:12:02:830 | [INFO] |  | OOBE | DE |  |  |  | 584582 | Updating media info for: {2614BC86-757D-4293-9E25-E4E16F370A9E}
      07/27/15 18:12:02:830 | [INFO] |  | OOBE | DE |  |  |  | 584582 |   Path: /private/tmp/4C1C985E-0AE5-4C94-A051-0DFB26551D36/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-Core/AdobePhotoshop16-Core.zip
      07/27/15 18:12:02:830 | [INFO] |  | OOBE | DE |  |  |  | 584582 | Updating media info for: {2A8D5184-32DE-431E-9E75-751D01300349}
      07/27/15 18:12:02:830 | [INFO] |  | OOBE | DE |  |  |  | 584582 |   Path: /private/tmp/4C1C985E-0AE5-4C94-A051-0DFB26551D36/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-en_AE/AdobePhotoshop16-en_AE.zip
      07/27/15 18:12:02:830 | [INFO] |  | OOBE | DE |  |  |  | 584582 | Updating media info for: {2C0EA9DC-EC03-4B9A-8340-9412E1A7C91A}
      07/27/15 18:12:02:831 | [INFO] |  | OOBE | DE |  |  |  | 584582 |   Type: 1, Volume Order: 1, Media Name: Adobe Photoshop CC 2015
      07/27/15 18:12:02:831 | [INFO] |  | OOBE | DE |  |  |  | 584582 |   Path: /private/tmp/4C1C985E-0AE5-4C94-A051-0DFB26551D36/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-es_MX/AdobePhotoshop16-es_MX.zip
      07/27/15 18:12:02:831 | [INFO] |  | OOBE | DE |  |  |  | 584582 | Updating media info for: {2CA9270E-4869-4E28-AC8A-42156340D608}
      07/27/15 18:12:02:831 | [INFO] |  | OOBE | DE |  |  |  | 584582 |   Path: /private/tmp/4C1C985E-0AE5-4C94-A051-0DFB26551D36/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-uk_UA/AdobePhotoshop16-uk_UA.zip
      07/27/15 18:12:02:831 | [INFO] |  | OOBE | DE |  |  |  | 584582 | Updating media info for: {3774910E-19EF-4220-86D1-EC1CBD9AC2E9}
      07/27/15 18:12:02:831 | [INFO] |  | OOBE | DE |  |  |  | 584582 |   Path: /private/tmp/4C1C985E-0AE5-4C94-A051-0DFB26551D36/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-de_DE/AdobePhotoshop16-de_DE.zip
      07/27/15 18:12:02:831 | [INFO] |  | OOBE | DE |  |  |  | 584582 | Updating media info for: {37CDAC6E-35D7-47E4-8463-A7C5553A5ED7}
      07/27/15 18:12:02:832 | [INFO] |  | OOBE | DE |  |  |  | 584582 |   Type: 1, Volume Order: 1, Media Name: Adobe Photoshop CC 2015
      07/27/15 18:12:02:832 | [INFO] |  | OOBE | DE |  |  |  | 584582 |   Path: /private/tmp/4C1C985E-0AE5-4C94-A051-0DFB26551D36/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-zh_CN/AdobePhotoshop16-zh_CN.zip
      07/27/15 18:12:02:832 | [INFO] |  | OOBE | DE |  |  |  | 584582 | Updating media info for: {3971EECB-2A4B-416C-90E1-DF0626B412C8}
      07/27/15 18:12:02:832 | [INFO] |  | OOBE | DE |  |  |  | 584582 |   Path: /private/tmp/4C1C985E-0AE5-4C94-A051-0DFB26551D36/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-fr_MA/AdobePhotoshop16-fr_MA.zip
      07/27/15 18:12:02:832 | [INFO] |  | OOBE | DE |  |  |  | 584582 | Updating media info for: {3C297E82-A8EC-4001-B267-5756C48ACA17}
      07/27/15 18:12:02:833 | [INFO] |  | OOBE | DE |  |  |  | 584582 |   Type: 1, Volume Order: 1, Media Name: Adobe Photoshop CC 2015
      07/27/15 18:12:02:833 | [INFO] |  | OOBE | DE |  |  |  | 584582 |   Path: /private/tmp/4C1C985E-0AE5-4C94-A051-0DFB26551D36/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-fr_CA/AdobePhotoshop16-fr_CA.zip
      07/27/15 18:12:02:833 | [INFO] |  | OOBE | DE |  |  |  | 584582 | Updating media info for: {3E7FC757-D497-4C89-A935-7D38E2164E85}
      07/27/15 18:12:02:833 | [INFO] |  | OOBE | DE |  |  |  | 584582 |   Path: /private/tmp/4C1C985E-0AE5-4C94-A051-0DFB26551D36/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobeCameraRaw8.0All/AdobeCameraRaw8.0All.zip
      07/27/15 18:12:02:833 | [INFO] |  | OOBE | DE |  |  |  | 584582 | Updating media info for: {3FB7A108-368A-4849-A3F3-69571BAAC457}
      07/27/15 18:12:02:833 | [INFO] |  | OOBE | DE |  |  |  | 584582 |   Path: /private/tmp/4C1C985E-0AE5-4C94-A051-0DFB26551D36/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-Support/AdobePhotoshop16-Support.zip
      07/27/15 18:12:02:833 | [INFO] |  | OOBE | DE |  |  |  | 584582 | Updating media info for: {52D57F95-000A-4922-BB31-C6A936F4FD7D}
      07/27/15 18:12:02:834 | [INFO] |  | OOBE | DE |  |  |  | 584582 |   Type: 1, Volume Order: 1, Media Name: Adobe Photoshop CC 2015
      07/27/15 18:12:02:834 | [INFO] |  | OOBE | DE |  |  |  | 584582 |   Path: /private/tmp/4C1C985E-0AE5-4C94-A051-0DFB26551D36/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobeColorJA_Recommended5_0-mul/AdobeColorJA_Recommended5_0-mul.zip
      07/27/15 18:12:02:834 | [INFO] |  | OOBE | DE |  |  |  | 584582 | Updating media info for: {5310A323-84E1-4957-8AF3-454921295D9D}
      07/27/15 18:12:02:834 | [INFO] |  | OOBE | DE |  |  |  | 584582 |   Path: /private/tmp/4C1C985E-0AE5-4C94-A051-0DFB26551D36/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-hu_HU/AdobePhotoshop16-hu_HU.zip
      07/27/15 18:12:02:834 | [INFO] |  | OOBE | DE |  |  |  | 584582 | Updating media info for: {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}
      07/27/15 18:12:02:834 | [INFO] |  | OOBE | DE |  |  |  | 584582 |   Path: /private/tmp/4C1C985E-0AE5-4C94-A051-0DFB26551D36/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobeCameraRawProfile8.0All/AdobeCameraRawProfile8.0All.zip
      07/27/15 18:12:02:834 | [INFO] |  | OOBE | DE |  |  |  | 584582 | Updating media info for: {5C5D62C9-91C6-415E-857E-9130C0F52C66}
      07/27/15 18:12:02:835 | [INFO] |  | OOBE | DE |  |  |  | 584582 |   Type: 1, Volume Order: 1, Media Name: Adobe Photoshop CC 2015
      07/27/15 18:12:02:835 | [INFO] |  | OOBE | DE |  |  |  | 584582 |   Path: /private/tmp/4C1C985E-0AE5-4C94-A051-0DFB26551D36/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobeColorPhotoshop5_0-mul/AdobeColorPhotoshop5_0-mul.zip
      07/27/15 18:12:02:835 | [INFO] |  | OOBE | DE |  |  |  | 584582 | Updating media info for: {67759AA1-0FD6-47FE-B449-492DC8B26D89}
      07/27/15 18:12:02:835 | [INFO] |  | OOBE | DE |  |  |  | 584582 |   Path: /private/tmp/4C1C985E-0AE5-4C94-A051-0DFB26551D36/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-en_US/AdobePhotoshop16-en_US.zip
      07/27/15 18:12:02:835 | [INFO] |  | OOBE | DE |  |  |  | 584582 | Updating media info for: {6B3589E5-D734-4AF1-9C13-A2D7C67ACE7E}
      07/27/15 18:12:02:836 | [INFO] |  | OOBE | DE |  |  |  | 584582 |   Type: 1, Volume Order: 1, Media Name: Adobe Photoshop CC 2015
      07/27/15 18:12:02:836 | [INFO] |  | OOBE | DE |  |  |  | 584582 |   Path: /private/tmp/4C1C985E-0AE5-4C94-A051-0DFB26551D36/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-fr_FR/AdobePhotoshop16-fr_FR.zip
      07/27/15 18:12:02:836 | [INFO] |  | OOBE | DE |  |  |  | 584582 | Updating media info for: {72405B80-A3DD-4BB2-A8C4-A90BC7BA50FF}
      07/27/15 18:12:02:836 | [INFO] |  | OOBE | DE |  |  |  | 584582 |   Path: /private/tmp/4C1C985E-0AE5-4C94-A051-0DFB26551D36/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobeColorNA_ExtraSettings5_0-mul/AdobeColorNA_ExtraSettings5_0-mul.zip
      07/27/15 18:12:02:836 | [INFO] |  | OOBE | DE |  |  |  | 584582 | Updating media info for: {7421A999-B08C-4A4B-B659-AD752AE330A5}
      07/27/15 18:12:02:836 | [INFO] |  | OOBE | DE |  |  |  | 584582 |   Path: /private/tmp/4C1C985E-0AE5-4C94-A051-0DFB26551D36/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-it_IT/AdobePhotoshop16-it_IT.zip
      07/27/15 18:12:02:836 | [INFO] |  | OOBE | DE |  |  |  | 584582 | Updating media info for: {7F847394-8F78-4A5E-9936-4522CFBA8BD4}
      07/27/15 18:12:02:837 | [INFO] |  | OOBE | DE |  |  |  | 584582 |   Type: 1, Volume Order: 1, Media Name: Adobe Photoshop CC 2015
      07/27/15 18:12:02:837 | [INFO] |  | OOBE | DE |  |  |  | 584582 |   Path: /private/tmp/4C1C985E-0AE5-4C94-A051-0DFB26551D36/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-en_IL/AdobePhotoshop16-en_IL.zip
      07/27/15 18:12:02:837 | [INFO] |  | OOBE | DE |  |  |  | 584582 | Updating media info for: {946BF592-2F57-4810-8D1D-EDAA7F49F1C6}
      07/27/15 18:12:02:837 | [INFO] |  | OOBE | DE |  |  |  | 584582 |   Path: /private/tmp/4C1C985E-0AE5-4C94-A051-0DFB26551D36/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-cs_CZ/AdobePhotoshop16-cs_CZ.zip
      07/27/15 18:12:02:837 | [INFO] |  | OOBE | DE |  |  |  | 584582 | Updating media info for: {9579E86C-CF60-43F3-A2DF-331D411D8270}
      07/27/15 18:12:02:838 | [INFO] |  | OOBE | DE |  |  |  | 584582 |   Type: 1, Volume Order: 1, Media Name: Adobe Photoshop CC 2015
      07/27/15 18:12:02:838 | [INFO] |  | OOBE | DE |  |  |  | 584582 |   Path: /private/tmp/4C1C985E-0AE5-4C94-A051-0DFB26551D36/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-zh_TW/AdobePhotoshop16-zh_TW.zip
      07/27/15 18:12:02:838 | [INFO] |  | OOBE | DE |  |  |  | 584582 | Updating media info for: {9E9EB9FD-FDE8-487A-A41C-7713DA91AC89}
      07/27/15 18:12:02:838 | [INFO] |  | OOBE | DE |  |  |  | 584582 |   Path: /private/tmp/4C1C985E-0AE5-4C94-A051-0DFB26551D36/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobeColorEU_Recommended5_0-mul/AdobeColorEU_Recommended5_0-mul.zip
      07/27/15 18:12:02:838 | [INFO] |  | OOBE | DE |  |  |  | 584582 | Updating media info for: {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}
      07/27/15 18:12:02:838 | [INFO] |  | OOBE | DE |  |  |  | 584582 |   Path: /private/tmp/4C1C985E-0AE5-4C94-A051-0DFB26551D36/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobeColorJA_ExtraSettings5_0-mul/AdobeColorJA_ExtraSettings5_0-mul.zip
      07/27/15 18:12:02:838 | [INFO] |  | OOBE | DE |  |  |  | 584582 | Updating media info for: {AB955DCF-69CD-4840-B7FB-F318CDD0AE44}
      07/27/15 18:12:02:839 | [INFO] |  | OOBE | DE |  |  |  | 584582 |   Type: 1, Volume Order: 1, Media Name: Adobe Photoshop CC 2015
      07/27/15 18:12:02:839 | [INFO] |  | OOBE | DE |  |  |  | 584582 |   Path: /private/tmp/4C1C985E-0AE5-4C94-A051-0DFB26551D36/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobeColorNA_Recommended5_0-mul/AdobeColorNA_Recommended5_0-mul.zip
      07/27/15 18:12:02:839 | [INFO] |  | OOBE | DE |  |  |  | 584582 | Updating media info for: {ABD0FB37-08A2-4B4F-8AD7-88A6C03330CB}
      07/27/15 18:12:02:839 | [INFO] |  | OOBE | DE |  |  |  | 584582 |   Path: /private/tmp/4C1C985E-0AE5-4C94-A051-0DFB26551D36/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePreview1.0All-osx10/AdobePreview1.0All-osx10.zip
      07/27/15 18:12:02:839 | [INFO] |  | OOBE | DE |  |  |  | 584582 | Updating media info for: {ACC1C515-792E-4CD0-98B7-ED65BB20BC6B}
      07/27/15 18:12:02:839 | [INFO] |  | OOBE | DE |  |  |  | 584582 |   Path: /private/tmp/4C1C985E-0AE5-4C94-A051-0DFB26551D36/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-sv_SE/AdobePhotoshop16-sv_SE.zip
      07/27/15 18:12:02:839 | [INFO] |  | OOBE | DE |  |  |  | 584582 | Updating media info for: {B06BF9B2-FB59-475A-9F9E-1FDFE48E828B}
      07/27/15 18:12:02:840 | [INFO] |  | OOBE | DE |  |  |  | 584582 |   Type: 1, Volume Order: 1, Media Name: Adobe Photoshop CC 2015
      07/27/15 18:12:02:840 | [INFO] |  | OOBE | DE |  |  |  | 584582 |   Path: /private/tmp/4C1C985E-0AE5-4C94-A051-0DFB26551D36/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-fi_FI/AdobePhotoshop16-fi_FI.zip
      07/27/15 18:12:02:840 | [INFO] |  | OOBE | DE |  |  |  | 584582 | Updating media info for: {BCA6D2ED-0ACF-4A36-A617-EDF6B133B732}
      07/27/15 18:12:02:840 | [INFO] |  | OOBE | DE |  |  |  | 584582 |   Path: /private/tmp/4C1C985E-0AE5-4C94-A051-0DFB26551D36/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-nb_NO/AdobePhotoshop16-nb_NO.zip
      07/27/15 18:12:02:840 | [INFO] |  | OOBE | DE |  |  |  | 584582 | Updating media info for: {C22A37BD-D19A-4AEA-BF17-EAD1FA824D62}
      07/27/15 18:12:02:841 | [INFO] |  | OOBE | DE |  |  |  | 584582 |   Type: 1, Volume Order: 1, Media Name: Adobe Photoshop CC 2015
      07/27/15 18:12:02:841 | [INFO] |  | OOBE | DE |  |  |  | 584582 |   Path: /private/tmp/4C1C985E-0AE5-4C94-A051-0DFB26551D36/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-ko_KR/AdobePhotoshop16-ko_KR.zip
      07/27/15 18:12:02:841 | [INFO] |  | OOBE | DE |  |  |  | 584582 | Updating media info for: {C4196275-B11A-40A1-8727-3C145C8F7D95}
      07/27/15 18:12:02:841 | [INFO] |  | OOBE | DE |  |  |  | 584582 |   Path: /private/tmp/4C1C985E-0AE5-4C94-A051-0DFB26551D36/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobeColorCommonSetCMYK5_0-mul/AdobeColorCommonSetCMYK5_0-mul.zip
      07/27/15 18:12:02:841 | [INFO] |  | OOBE | DE |  |  |  | 584582 | Updating media info for: {C8DEBB29-3EB0-4B97-B652-4DE482B111BC}
      07/27/15 18:12:02:841 | [INFO] |  | OOBE | DE |  |  |  | 584582 |   Path: /private/tmp/4C1C985E-0AE5-4C94-A051-0DFB26551D36/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobeColorCommonSetRGB5_0-mul/AdobeColorCommonSetRGB5_0-mul.zip
      07/27/15 18:12:02:841 | [INFO] |  | OOBE | DE |  |  |  | 584582 | Updating media info for: {CE9B1B00-0421-4701-9698-1C14646D6D94}
      07/27/15 18:12:02:842 | [INFO] |  | OOBE | DE |  |  |  | 584582 |   Type: 1, Volume Order: 1, Media Name: Adobe Photoshop CC 2015
      07/27/15 18:12:02:842 | [INFO] |  | OOBE | DE |  |  |  | 584582 |   Path: /private/tmp/4C1C985E-0AE5-4C94-A051-0DFB26551D36/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobeVideoProfilesCS5_0-mul/AdobeVideoProfilesCS5_0-mul.zip
      07/27/15 18:12:02:842 | [INFO] |  | OOBE | DE |  |  |  | 584582 | Updating media info for: {DCC00639-486F-45AF-9E32-666B754DB49E}
      07/27/15 18:12:02:842 | [INFO] |  | OOBE | DE |  |  |  | 584582 |   Path: /private/tmp/4C1C985E-0AE5-4C94-A051-0DFB26551D36/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-en_GB/AdobePhotoshop16-en_GB.zip
      07/27/15 18:12:02:842 | [INFO] |  | OOBE | DE |  |  |  | 584582 | Updating media info for: {E01A53CC-3419-4F62-A758-7ACF940BA008}
      07/27/15 18:12:02:842 | [INFO] |  | OOBE | DE |  |  |  | 584582 |   Path: /private/tmp/4C1C985E-0AE5-4C94-A051-0DFB26551D36/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobePhotoshop16-es_ES/AdobePhotoshop16-es_ES.zip
      07/27/15 18:12:02:842 | [INFO] |  | OOBE | DE |  |  |  | 584582 | Updating media info for: {F6DED2DA-1D20-497E-8810-E745B45DCD28}
      07/27/15 18:12:02:843 | [INFO] |  | OOBE | DE |  |  |  | 584582 |   Type: 1, Volume Order: 1, Media Name: Adobe Photoshop CC 2015
      07/27/15 18:12:02:843 | [INFO] |  | OOBE | DE |  |  |  | 584582 |   Path: /private/tmp/4C1C985E-0AE5-4C94-A051-0DFB26551D36/Photoshop_16_LS20/Adobe Photoshop CC 2015/payloads/AdobeColorEU_ExtraSettings5_0-mul/AdobeColorEU_ExtraSettings5_0-mul.zip
      07/27/15 18:12:02:843 | [INFO] |  | OOBE | DE |  |  |  | 584582 | --------------------  END  - Updating Media Sources -  END  --------------------
      07/27/15 18:12:02:855 | [ERROR] |  | OOBE | DE |  |  |  | 584582 | ASU has quit unexpectedly.
      Thanks for your help.
        • 1. Re: exit code 15 / ERROR DW051
          Brucgovn Adobe Community Professional
          Please mention the list of CC apps installed on your computer .
          • 2. Re: exit code 15 / ERROR DW051
            We might need to rename CAPS folder from System Library > Application Support > Adobe.
            If we rename it , you might need to reinstall all CC apps again .
            So let me know the list of CC apps installed on your comp.
            • 3. Re: exit code 15 / ERROR DW051
              Sheena Kaul Adobe Employee
              Please follow: Exit code 15 installing | Mac OS X | CCM, CS6
              Hope that helps!
              Regards,
              Sheena
              • 4. Re: exit code 15 / ERROR DW051
                As I reviewed log file and checked that , the error is with sync and update of Media.db file which is present inside Caps folder ..
                More over you had already tried with Help document solution , possibilities are there that Media,db file is corrupted .
                Once you rename Caps folder , new folder will be spawned . then try to install CC 2015 app and check.
                • 5. Re: exit code 15 / ERROR DW051
                  stubery Level 1
                  i already followed those instructions before writing this post. didn't help. still the same errors.
                  • 6. Re: exit code 15 / ERROR DW051
                    stubery Level 1
                    Thanks Brucgovn ! You. Are. Good. !
                    • 7. Re: exit code 15 / ERROR DW051
                      stubery Level 1
                      I installed the apps (Ps, Ai, Id) but no there's an issue with User/Restrictions. Check screenshot. It's saying I don't have the necessary rights to access the preset-folder.  Bildschirmfoto 2015-07-28 um 10.12.40.png
                      • 8. Re: exit code 15 / ERROR DW051
                        Can you translate the message in English ?
                        However.
                        We will provide full permissions to Adobe folder under both Libraries and check .
                        Follow below steps :
                        Step 1 :
                        1) Right click on Finder icon and  select "Go-To" Folder option.
                        2) You will get a text box, type-in below command and then hit 'Return' key.( Do not miss ~ symbol)
                        ~/library
                        3)Then navigate to Application Support>Adobe
                        Right click on Adobe folder and select "GetInfo" option.
                        Expand the Sharing & Permissions section.
                        Click the lock icon in the lower-right corner. Enter your administrator user name and password when prompted, and then click OK.
                        Please click on '+' symbol , it will open list of user accounts. Add Currently logged in user name and Administrator option,
                        Then provide "Read & Write" permission to Currently logged in user name and Administrator option,.
                        Click the Gear icon, and select Apply to Enclosed Item. Close the Get Info dialog box.
                        Step 2:
                        /library
                        Then launch CC apps and check.
                        • 9. Re: exit code 15 / ERROR DW051
                          stubery Level 1
                          thanks. it helped.....
                          but:
                          every app is working except indesign cc2015.
                          i un-& re-installed indesign, still the same error.
                          "Adobe Indesign couldn't get started because I don't have the necessary permission to
                          access the preset-folder. Be sure you have the necessary permissions and restart indesign."
                          I even tried to give permission to everyone (to access indesign-folder), didn't help. No clue.
                          You?
                          • 10. Re: exit code 15 / ERROR DW051
                            We will enable Root account once and then try to launch InDesign CC 2015 app .
                            Root User account is Super user account with superior privileges.  You can try launching CC app once.
                            You cannot create Root account , It is an built in user account , you can enable it and disable it as per your choice.
                            Step for enabling Root user account :
                            OS X Mavericks: Enable and disable the root user
                            (Applies for Yosemite as well)
                            How to log in as root
                            1. If you are logged in, choose Log Out from the Apple menu.
                            2. If you are logging in from a list of usernames with pictures, click Other.
                            3. In the Name field, type: root
                            4. In the Password field, type the password you defined when setting up the root user account.
                            Once you logged in to Root Account try to launch InDesign CC 2015 app.
                            • 11. Re: exit code 15 / ERROR DW051
                              stubery Level 1
                              thanks for your help. root account would have helped for sure.
                              because, the last 30minutes i did the following and it worked:
                              - library-cache-adobe-indesign-folder >> permissions changed
                              - library-preferences-adobe-indesign-folder >> permissions changed
                              (same thing as you mentioned earlier with the adobe application support - folder > changing permissions)
                              anyway. thank you very much, you guided me to this solution. have a nice day!
                              • 12. Re: exit code 15 / ERROR DW051
                                Splendid., Glad to hear that the issue has been resolved.
                                You are most welcome .
                                Have a fantastic day .
