0 Replies Latest reply on Jul 28, 2015 1:31 AM by Sarankup
    InDesign bad line break in XML document
    Sarankup Level 1
      I have InDesign document created through XML import. There is a text instance "fields.31,41,42,44,54,58,60,64" All these numbers are corresponds to the footnotes appears at end of the page/document. Please refer the below screenshot taken from InDesign, wherein InDesign breaks the "fields" word badly and even without any hyphenation. How to fix this?
      The same document, I just remove the XML tags associated with the footnote numbers using Untag feature and the result looks correct, please refer the below screen. I can't apply this work-around. Because, this this is the XML first workflow, I should not remove the XML tags.
      Thanks in advance.
