I'm trying to make a mouse event that return a random number to a dynamic text box...
when i publish the function that generates the number works
but when i call the function with the mouse click it doesn't work.
Could someone help me?
Tnks!!!
var resultado:Number=sorteio();
function sorteio():Number
return Math.round(Math.random() *500);
sorteio();
sorteio_txt.text = String(resultado);
my_btn.addEventListener(MouseEvent.CLICK, onClick);
function onClick(e:MouseEvent):void
sorteio();
To change your original code the least you could replace the sortio function with this. It assigns the new random number to the resultado variable then assigns resultado to the text field.
resultado = Math.round(Math.random() *500);
sorteio_txt.text = resultado.toString();
return resultado;
kglad's solution is also great and works.
In your example you want a string version of the random number. A good design would keep your resultado variable saved as a numbe
...Copy link to clipboard
use:
function sorteio():String
return Math.round(Math.random() *500).toString();
sorteio_txt.text = sorteio();
return resultado;
In your example you want a string version of the random number. A good design would keep your resultado variable saved as a number and convert it to a string only when you need to display it in a text field. In this version you have resultado saved as a number variable and each method does its thing. Everything is a little more decoupled.
var resultado:Number;
sorteio();
displayResultado();
function sorteio():void
function displayResultado():void
sorteio();
displayResultado();
‌thank you guys for The different aproaches To The problem!
it helped me a lot To understand differents Ways of dealing with it!
