I'm trying to add the viewed product history http://docs.businesscatalyst.com/user-manual/e-Commerce/Products/adding-a-viewed-product-history
but I get errors in the code when I place:
{% if globals.cookie.lastVisited %}
{% assign prodIds = globals.cookie.lastVisited | append: "]" | prepend: "[" | split: "%2C" | join: "," %}
{module_data resource="products" version="v3" fields="canonicalUrl, name, smallImage" where="\{'id':\{'$in': {{prodIds}} \}\}" collection="lastProducts" template=""}
<h4>Your last visited products:</h4>
<ul>
{% for item in lastProducts.items %}
<li><a alt="{{item.name}}" href="{{item.canonicalUrl}}"><img alt="{{item.name}}" src="{{item.smallImage}}?Action=thumbnail&Width=50&Height=50"/></a></li>
{% endfor %}
</ul>
{% endif %}
Any help would be appreciated.
OK It looks like I made it after 1000x times attempts the structure is as follow:
STEP 1: create your main template for the pages:
Main Template>
Insert the libraries as follow:
1- Jquery latest (for me working on jQuery v1.11.1)
2 - Jquery.cookies
Inside the container you have your {tag_pagecontent} just past the liquid code provided:
<section>
<div class="main-description">{tag_pagecontent}</div>
<div class="rencet-viewd">
...Copy link to clipboard
Hi there,
You need at least a link or more information about the errors.
Did you include jquery, did you include the jquery cookie plugin? Is it a javascript error or a display/liquid error.
I followed the instructions and tested liquid was activated. When I add that rendering code, the BC page would not save and the editor would not change to visual mode from code mode. Is there a specific wrapper that needs to go around that section of code?
You have to make sure you paste code like this in html mode.
Because you have liquid in there it will never go back to visual editing mode as this can break that code.
You should not really be editing and changing layouts/templates using that visual editor - it is not built for that.
You still not properly indicated the issue Adam.
The code just showing not rendering, it does not work?
You not answered my question about installing the javascript elements to this.
I am pasting the code in html mode. Here is the site URL: Alessi
Be aware that all menu links take you to the original site as this is a duplicate.
You really need to provide a link
http://bradshaws-responsive.businesscatalyst.com/alessi
Product history should appear below the products.
Please be aware that all main menu links go to original site.
You need to fix your javascript errors and address your conflicts, like loading jQuery multiple times doing different syntax.
Copy pasing code from a doc will not just work in most cases as they are only examples to implement in the environment (site) you have..
View your console on the detail page of a product and you will see the errors to address:
Hi I'm still looking for any assistance on how to actually implement this feature as the BC Doc is does not provide enough info.
What are the steps to add this feature to a web page that are missing from the user manual document: Adding a viewed product history
Thanks.
You do not even have anything set up code wise now Adam.
- You need liquid enabled on your site
- You need to have jquery installed on the site and if it is already in the code do not call it again and the cookie plugin
- You need to include the main script being called (if in separate js file) on the detail view of a product or on a detail view of the product
- Step 2 liquid code needs to go in the template/shop layout location you need it to render
You need to ensure no errors and understand your doing Javascript, have enough understanding to follow what is going on and the liquid in place and know what it is rendering. You will then need to style it with CSS.
Please see post #4 screen shots
- You need liquid enabled on your site - Done
- You need to have jquery installed on the site and if it is already in the code do not call it again and the cookie plugin - Done
- You need to include the main script being called (if in separate js file) on the detail view of a product or on a detail view of the product - Done
- Step 2 liquid code needs to go in the template/shop layout location you need it to render - Done
"have enough understanding to follow what is going on and the liquid in place and know what it is rendering" - If I did I wouldn't be on the forum looking for help!
Liam, have you installed this feature before? If so what are the steps missing from the document?
Your saying your done, but I can not find the javascript code running on the product detail view on your site and nor do I see jquery cookie plugin running, I do not see a block in the other layouts for the liquid and there are no script errors but there are also no cookie events firing off because the code is not there.
You need to understand this is not a plugin or anything, just a copy paste anywhere will not make this work.
Right now, I do not see the code on the site like the Javascript that needs to be there for this to work.
I had taken it out since I was not getting anywhere with it.
The code has been put back in to match the screen shots.
The way Muse is generating the jQuery it has two instances of it through a document.write method. The latter loaded jQuery as it is loaded last into memory always takes over. This is at the bottom so if you look at the console you can see two errors.
1. Your cookie plugin can not find jquery - Put it at the bottom after the script code Muse is making
2. the javascript you pasted at the top can not find jQuery so this needs to be after as well at the bottom.
Hey guys, I can see this is getting a bit frustrating for me too, I have put the snippets and made a few corrections as the script given does not the calls as variable I am not sure why but it works but for some reason but the Cookies plugin is not working properly on my site I don't have a single error on my log, but it either is not storing information or fetching the products data, did you have any error with jquery.cookies I am struggling with it as a few functionalities I built to work with BC never worked successfully.
My site is www.bestkilts.com
Thanks for the help if I get any 😜
Hi Ricardo - where did you put the code at step 1? I couldn't find it in the Large product layout.
Mihai
the code is on /MASTER-SHOP.js on the last lines of the script, use your developer's provided tab to access it.
So did you get this working then?
No errors on the console and either the script but the Liquid is not outputting a thing so I presume the liquid has something wrong, or something beyond my understanding.
Hi Ricardo,
Please take the script out of the script and put it inline on the Large product layout. The problem is if you take it out of context the IDs and other Liquid tags won't work.
Adam, let me have a quick description of your setup and I'll have a look.
Mihai
I tried it and I don't know but maybe because I use a template to generate the large product I end up having a small render rather than the large view I use the line: {module_product,297600,{tag_productid} template="/ModuleTemplates/Ecom/{tag_custom1}.tpl"}
I don't think that matters, just put the code at the end of the large product layout.
{module_product,297600,{tag_productid} template="/ModuleTemplates/Ecom/{tag_custom1}.tpl"} will render this bit https://monosnap.com/file/4pupm1YXqrPHY9Au5yhIz4PL5cDzxB.png
Everything you add after that will render below. It is there where you would need to add the script that saves the cookie (step 1 of the guide).
Hope this helps,
Mihai
Hi Mihai, I added the code to the large product layout here: Stonewall Kitchen Jam Tree
We clearly need a new tutorial for implementing this awesome feature. Could someone put that together? Most appreciated.
Your page has 9 errors/conflicts you need to fix them in order to have whatever you want to work actually "work"
