2 Replies Latest reply on Dec 17, 2006 10:28 AM by T Rollins
    SWFloader and Embedded Flash 9a SWFs
    T Rollins Level 1
      I have a bunch of Flash movies done in Flash 9 / AS3. These are pretty basic animations, with very simple timeline scripts at the top level - basically just stop() and some trace statements. I also have labels set at various points. All of these animations are designed for basic gotoAndPlay(label) then stop() operations.
      These swfs are compiled without any custom classes... strictly simple code on the root timeline, as I said, stop() and trace().
      I load this stuff up in my more complex Flex app via a SWFloader. Once the load is complete, I assign SWFloader.content to a variable typed as movieclip. Everything loads. My trace statements trace through Flex. My stop() actions work. However, the gotoAndPlay(label) commands do not work, Flex always reports that the movie is on Frame 0, it claims the movie has 0 totalFrames, etc. It can't see any labels or any other details of the file.
      I've looked at the docs and the list archives, but can't seem to get this going. Is there anything special which needs to be done in Flash 9, besides exporting as Flash 9 / AS3? Any other suggestions or examples?
        • 1. Re: SWFloader and Embedded Flash 9a SWFs
          T Rollins Level 1
          I should note that this problem really only occurs if the animation SWF is @embedded. Looking at the loaderInfo.URL is telling me the main movie's URL, which I suppose is fine, but I still don't seem to be able to communicate with it. Accessing the movie as an external file, without embedding, it works correctly. Is there some special difference in how you handle an @embedded SWF compared to one linked via a relative path?
          • 2. SWFloader and Embedded Flash 9a SWFs
            T Rollins Level 1
            What I'm looking for are the steps to use an @embedded FP9/AS3 SWF while retaining the ability to access its properties, and do basic gotoAndPlay("labelName") calls, as I've tried a lot of different ways and haven't been successful yet. Runtime access seems to work just fine. Once embedded, it no longer works correctly as it seems the reference and probably class type of the movie has changed. Any pointers?
