9 Replies Latest reply on Jul 31, 2015 1:41 AM by Krisztina Imre
    Camera raw bug
    Krisztina Imre
      In Camera Raw window my images look awfully, especially in the dark areas.   I chacked all settings, graphics card is good as well. Any idea?
      Screenshot: http://www.panoramablog.eu/media/cr.png
        • 1. Re: Camera raw bug
          Mandhir Bhatia Adobe Employee
          Krisztina,
          I think your display settings are messed up.
          You can refer the link below to reset the settings.
          Getting the best display on your monitor - Windows Help
          Cheers!
          Mandhir
          • 2. Re: Camera raw bug
            Chuck Uebele Adobe Community Professional & MVP
            Moving to Camera Raw Forum.
            • 3. Re: Camera raw bug
              Krisztina Imre Level 1
              Thanks, Mandhir. I checked all settings on my monitor and all is OK.
              • 4. Re: Camera raw bug
                ssprengel Adobe Community Professional & MVP
                Turn off the GPU, then, in CR / Prefs (Ctrl-K) / Graphics Acceleration (uncheck).
                • 5. Re: Camera raw bug
                  I tried but unfortunately the same situation.
                  • 6. Re: Camera raw bug
                    Can you post a link to your raw file, here?  Upload to dropbox.com and reply with a public share link.
                    This would help determine if the issues are in the file (it looks the same for us) or on your computer system (it works ok for us).
                    My guess, as the first person responded, is that your monitor profile is bad.
                    Keep in mind that this is a public forum so anyone who sees the post can click on the link and download the file, but if you use dropbox, then  you can control when you delete the file and therefore when it will become unavailable, again.
                    • 7. Re: Camera raw bug
                      I gladly send a photo but the dark parts are ugly on all photos in CR. And just in CR. When I open in Photoshop, it is much better. Here is the download link: austria-226.dng - Google Drive
                      and two screenshots, first in CR:
                      and this is in PS
                      • 8. Re: Camera raw bug
                        It looks ok,here, using ACR 9.1.1 that came out, today, so something is messed up on your computer.
                        ACR 9.1.1:
                        Opened into PS CC 2015.0.0 - Windows 7 Professional:
                        One thing I noticed about the DNG is that is has all the default settings used, so if you've made modifications, there, that didn't get saved into the DNG you sent, check what happens if you've reset back to Adobe defaults.  Pay attention to the Tone Curve and make sure it is set to Linear:
                        Here is how things look if the lower tone-curve point isn't at 0,0:
                        Otherwise:  What is the bit-depth of your monitor?  The images you're showing look like they're 8-bit 256 colors or worse.
                        Here is where I can see on Windows 7 that my display bit depth is 32-bits:
                        And what is your monitor profile set to?  Mine is a custom one I made with an i1DisplayPro calibrator.  If yours is just the name of your monitor (and you haven't done a custom calibration) then set the monitor profile to sRGB-whatever and see if the condition clears up:
                        Finally check to see that you're not running PS in some sort of old compatibility mode:
                        • 9. Re: Camera raw bug
                          Thank you ssprengel, I saw all settings thats you showed, and all my settings are good. I tried turn off monitor calibration as well but doesn't solved the problem. I buy a new monitor, but I suspect it will not solve the problem. If the new monitor works, I come with news. Thank you so much for your help.
