5 Replies Latest reply on Jul 29, 2015 12:38 PM by RJ Dougall Branched from an earlier discussion.
    Issue with ACR and CS6
    RJ Dougall
      Thank you for your courtesy - I have been playing with this all evening
      - and I think I have finally activated PSCS6. I was able to install the
      64 and 32 bit version as 30 day trials. I had been having a problem
      using ACR - somehow I had version 9.1 which the chat people told me was
      not really compatible to CS6. In 64bit version, from Bridge I could only
      access ACR when working on a RAW file - not JPG and not TIF - although
      the preference box was set properly. I thought I could download an older
      version of ACR and install it. The effort to reinstall from my original
      DVD from Adobe was really to go back to an older version of ACR. When I
      finally was able to use the trial version of the 64 bit and then the 32
      bit versions, I found myself using ACR Version 7.0 - and I was now able
      to open ACR from BRIDGE working on a JPG or RAW file - still no TIFF.
      This hurts because I have been doing a massive scanning exercise with
      iterally thousands of 110, 126, 120 and 35mm negatives and saving them
      all as TIFFS - and I had been opening batches of these and doing some
      initial processing with ACR, then opening and fine tuning by spotting,
      NIK Viveza etc, then renaming and inserting in appropriate folders - a
      massive job - when suddenly the TIF files would no longer open in ACR.
      Thus this whole exercise in frustration. Just before I received your
      e-mail, I tried the 32bit Photoshop and a dialog box opened trying to
      sell me CC - and it gave me a chance to register my program - I decided
      to try this - and my second try worked - and I seem to be activated. I
      guess I'll know for sure when I close it and try to open it again.
      I found the chat exercise also frustrating last evening as one person
      transferred me to someone else and I had to keep repeating what I had
      said before - and what I said the second time did not seem to register.
      I do not think I will answer the survey.
      Thanks for listening.
      Dick Dougall
        • 1. Re: Issue with ACR and CS6
          Atul_Saini Adobe Employee
          Branched this discussion to Adobe Camera Raw
          • 2. Re: Issue with ACR and CS6
            ssprengel Adobe Community Professional & MVP
            Your chat experience is typical.  They have a script of questions to follow, despite what you tell them or what another CS person has done, already.  They are really just a human interface to an Adobe knowledge base, not people that use PS and know what they are doing from personal experience, other than what issues they might have helped with on the phone/chat before.
            ACR 9.1 is compatible with CS6, but ACR 9.2 and newer versions won't be so maybe that is what the chat people have heard and are slightly mistaken on what the last version of ACR is that works.
            When you say you cannot work with TIFs in ACR what happens when you try and how are you trying to open ACR on the TIFs?  For example, are you right-clicking in Bridge and you don't have the Open in Camera Raw option?
            Can you upload one of these TIFs to www.dropbox.com and others can try to open it, in case there is something amiss with your computer, as opposed to the TIF, itself, being incompatible.
            • 3. Re: Issue with ACR and CS6
              RJ Dougall Level 1
              Thank you for responding to this issue. Since those unhappy postings, a
              knowledgeable friend realized that ACR does not deal with files that
              include layers. I often save TIF files with type layers so that I can
              edit text should I find that needed. ACR on my machine now opens TIF and
              JPG so long as there are no saved layers in TIF. This may help explain
              why ACR does not open PSD files.
              Since I had to re-install PhotoShop in this process, I am now using ACR
              version 7.
              This experience has given me even more reason to work on becoming more
              proficient with the stand-alone possibilities with both TOPAZ and OnOne
              products. The browser alone in Perfect Photo Suite is worth the effort.
              Several years ago I was a product tester for Premiere Pro and found the
              Adobe support team fabulous -especially a contact I dealt with in
              Northern India.
              Again, thank you.
              Dick Dougall
              • 4. Re: Issue with ACR and CS6
                That makes sense.  ACR can open TIFs and PSDs that have a composite preview layer on top, and then only that layers pixels are adjusted.
                • 5. Re: Issue with ACR and CS6
                  RJ Dougall Level 1
                  Thanks - you have just sparked a thought that has been bugging me -
                  before all of this, I would not have thought about ACR opening a TIF or
                  not because most of the time when I have had a complex or multi-layered
                  file, I would do that composite layer on top - and ACR must have been
                  routinely opening for those. What brought this all to a head was a
                  tedious and lengthy bout of scanning old negs of every size - and I
                  would do an adjustment in Nik Viveza or similar to produce a file with
                  reasonable contrast, exposure, and detail in highlights and shadows -
                  and as soon as that quick fix was done, I would save and go on to the
                  next one. So, I am thinking that the inability to access ACR with these
                  files was a problem. Co-incidentally, it is also possible for more than
                  one issue to rear ugly heads about the same time. Not only was I not
                  able to access ACR with a CTRL R from BRIDGE, I was also not able to
                  access PhotoShop with CTRL O for those TIF images. So, re-installing
                  PhotoShop may have been necessary after all - because those issues are
                  history now -- knock on wood.
                  Dick
