Hi
I made a update package for the employers that do not have admin rights.
The installation of the package works on my computers when running the setup. (as admin)
I am now going to deploy the update-pageage for the clients, but I feel the link here are missing information:
https://helpx.adobe.com/creative-cloud/packager/using-remote-update-manager.html
Do I need to copy the "RemoteUpdateManager.exe" to the client and run it one time with admin privileges there first?
How to I tell the client where the new package is?
Can I then run the software from my computer to update the clients later?
Regards
Andreas
Hi Andreas,
Remote update manager enables the update with out setting up AUSST. You can run the RUM with channel IDs for each application and it should update the app silently.
If you do not want the products/components on client machines to directly download the updates without admin intervention, suppress manual updates while creating the package. For more information on how to do this, see the description of the Configure Package screen in the “Creating Deployment Packages” article.
Remote Update Manager will work whether or not you have suppressed manual updates on client machines.
Ashish
I hope you don't mind me asking but how exactly do you install RUM? I am on OS X 10.10
Hi Dave,
You can follow the instruction by following the link below:
Creative Cloud Help | Using Adobe Remote Update Manager
Mandhir
Thanks Mandhir but there is no info in that document that says how to install RUM. Unless I am missing something important. It seems to be about how you use it once installed?
Dave,
When you install the Creative Cloud packager it generally goes into windows at folder location below:
C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\CCP\utilities
Mandhir
I followed below link to update Adobe Updates remotely
Use Adobe Remote Update Manager
But , as described in that KB RemoteUpdateManager folder will be located at "C:\Program Files (x86)\Common Files\Adobe\OOBE_Enterprise\RemoteUpdateManager" location , but it is missing.
Even, Location
is also missing. !
My System is Windows 10 Pro.
Please provide me a solution ASAP.
