3 Replies Latest reply on Jul 30, 2015 12:10 PM by Synkx
    Move graphics and texts to separate layers on multiple opened documents
    Synkx
      Hi everyone,
      My situation is as follows :
      I've got multiple documents to make changes to, and I can't have my script to work out on all those open documents.
      I'm getting an error :
      My script is working on one file, only one, and then stops with this error.
      What I'm trying to do :
      I would like to move all my texts to a certain layer, that is created by the script, and move all my pictures to another layer, also created by the script. (the graphics must be only graphics, not rectangles with a fillColor, but rectangles with graphics inside of them.)
      I'm trying to make this possible on every opened documents.
      I also would like to get rid of all other layers, except the two I'm creating with the script.
      Why am I doing this ?
      Well, I've got documents with images and texts, but also some rectangles filled with colors.
      I'm trying to get rid of these rectangles, but I didn't find any way to get rid of rectangles without getting rid of rectangles that have images inside of them...
      Here's the code I'm working on :
      function moveToLayer(){
       var myDoc = app.documents;
              for (var i = myDoc.length-1; i >= 0; i--) {
      if(!myDoc[i].layers.itemByName("pictureLayer").isValid){myDoc[i].layers.add({name:"pictureLayer" })};
      if(!myDoc[i].layers.itemByName("textLayer").isValid){myDoc[i].layers.add({name:"textLayer"})};
      var textLayer = myDoc[i].layers.itemByName("textLayer");
      textLayer.locked = false;
      var pictureLayer = myDoc[i].layers.itemByName("pictureLayer");
      pictureLayer.locked = false;
      myDoc[i].spreads.everyItem().textFrames.everyItem().locked = false;
      myDoc[i].spreads.everyItem().textFrames.everyItem().itemLayer = textLayer;
      var myPageItems = myDoc[i].pageItems;
      for(var i=0; i<myPageItems.length; i++){
      if(myPageItems[i].allGraphics.length==1){
      myPageItems[i].locked = false;
      myPageItems[i].itemLayer = pictureLayer;
      I've been searching all over the forum, gathering some pieces of code but now I'm stuck, and begging for your help !
      Could someone please explain to me what's going on and what's wrong, and/or could get this script to work as it should ?
      Thanks everyone !
        • 1. Re: Move graphics and texts to separate layers on multiple opened documents
          Synkx Level 1
          Well, found the answer myself !
          I only needed to rename the "var i" in the second "for" of the script.
          if(!myDoc[i].layers.itemByName("pictureLayer").isValid){myDoc[i].layers.add({name:"picture Layer" })};
          if(!myDoc[i].layers.itemByName("textLayer").isValid){myDoc[i].layers.add({name:"textLayer" })};
          for(var k=0; k<myPageItems.length; k++){
          if(myPageItems[k].allGraphics.length==1){
          myPageItems[k].locked = false;
          myPageItems[k].itemLayer = pictureLayer;
          Hope this will help someone else !
          (I now face another problem, but I may investigate a little more before posting another question ! )
          • 2. Re: Move graphics and texts to separate layers on multiple opened documents
            Peter Kahrel Adobe Community Professional & MVP
            The embeddd for-loop uses the same variable for the counter, i. Use a different variable for the embedded loop:
            for(var j=0; j<myPageItems.length; j++){
            and change all i's to j inside that loop.
            Peter
            • 3. Re: Move graphics and texts to separate layers on multiple opened documents
              Synkx Level 1
              Hi Peter,
              Thank you for your answer !
              I've been able to find that out by myself, but I may post another question tomorrow.
              Thanks again !
