Have Photoshop 2015 CC would like to batch process psd files to pdf files, NOT in bridge, can not get output module to work in bridge tried everything to get bridge to work, it wont.
You could combine the Batch script and a simple Save As PDF action. Open a file and create the action.
Make a new set:
Make new action:
The action should be recording. Now save your file as a PDF and stop the action.
Go to Bridge and select the files you'd like to convert, then go to Tool>Photoshop>Batch. Set as the screen shot shows:
Benjamin
Make a new set:
Make new action:
Benjamin
Thank you so much....IT WORKED. You are a genius....
I have tried for hours trying to google a procedure to
batch psd to pdf with no luck what so ever.
The output module DOES NOT WORK in bridge cc.
I installed output module (not installed from beginning?????)
It just wont show up and
tried all the fixes from the web, the output module will not
show up in bridge cc. Adobe has not fixed it...Why do they
think people don't batch convert from psd to pdf??
Most print houses now want pdf files, not psd.
Adobe has dropped the ball on this. It seems it should
be so simple, but is not. You are the only one that has
given me a solution....Thanks again a lot!!
You're very welcome, glad to help! Also, consider posting a bug report over at feedback.photoshop.com
Benjamin
Absolutely terrific.
Serge
THANK YOU!!! This worked so well!
Still valid 5 years later 🙂
Thank you for this!
