• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
1
Generate Copyright from FM File Info to Acrobat
Explorer ,
Jul 30, 2015 Jul 30, 2015
Author, Title, Subject, and Keywords from FrameMaker's File Info are automatically generated into the Acrobat Properties when you create a PDF. We would like to generate the Copyright information as well to avoid having to enter it manually into Additional Metadata each time. Does anyone know a setting or a hack that will accomplish this?
Thanks for any help!
Views
309
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert ,
re: We would like to generate the Copyright information ...
I only have FM7 on hand to test, but I can set that in the Copyright pane of File > File Info, and it is definitely passed into the PDF via the:
Savs-as-PDF (with the Distiller printer model configured), and
Print-to-Ps and Distill path.
It appears in the PDF under Acrobat Reader DC via File > Properties /Custom\
It does not appear to appear in Print-to-PDF.
Votes
Translate
Translate
Report
Report
Advocate ,
LATEST
You can do it with a PostScript text frame:
1. Create a file, possibly named PDFMark.fm, and place it as the first
file in your book. Alternately, you can draw a text frame in the margin
on the first page of your book.
2. Place the following text in the text frame:
/pdfmark where {userdict /pdfmark /cleartomark load put} ifelse
/Copyright ((C) 2015 Author Name. All rights reserved.)
/DOCINFO pdfmark
3. Now Ctrl+click to select the text frame and then right-click. Choose
Object Properties.
4. In the Object Properties dialog, select the PostScript Code checkbox.
Click Set. This will load the copyright info into the PDF when you
create it.
Votes
Translate
Translate
Report
Report
