• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Function that does not function
Participant ,
Jul 30, 2015 Jul 30, 2015
I'm terribly frustrated  the moment. This script worked until it didn't and I have no clue as what is wrong with it. The parts that doesn't work are the one that in bold. it's a basic condition that look for an item on stage and then go to the function should the item exist.  It works fine for a while  but then it stop responding to this condition anymore. I traced the object to make sure that it's on stage and it was on stage at the time of the test but still it just refused to go to this function. It should go to function first7Move3();  when yesh7bomb20 is on stage. all other conditions works just fine. Any clue as what's wrong? My sans is that it remembers a deleted code somehow because at one point I had removeChild (yesh7bomb20); in the first7Move3(); function but I had deleted that code . a bug maybe? how to go around it?
if (add7bigGrayBall4.currentFrame == 30) {
  if (yesh7bomb17.currentFrame == 91) {
    gotoAndPlay(139);
  } else if (stage.contains(yesh7bomb20)) {
    first7Move3();
  } else if (stage.contains(yesh7bomb16)) {
    first7Move2();
  } else {
    first7Move1();
} else {
  add7bigGrayBall4.gotoAndPlay(1);
function first7Move2(): void {
  removeChild(yesh7bomb16);
  addChild(yesh7bomb17);
  yesh7bomb17.x = 321.30;
  yesh7bomb17.y = 109.85;
  yesh7bomb17.gotoAndPlay(1);
  if (stage.contains(yesh7Buket1a)) {
    removeChild(yesh7Buket1a);
  if (stage.contains(yesh7bomb3)) {
    removeChild(yesh7bomb3);
function first7Move1(): void {
  addChild(yesh7bomb16);
  yesh7bomb16.x = 321.30;
  yesh7bomb16.y = 109.85;
  yesh7bomb16.gotoAndPlay(1);
  if (stage.contains(yesh7Bucket_Cover2)) {
    removeChild(yesh7Bucket_Cover2);
  if (stage.contains(yesh7bomb2)) {
    removeChild(yesh7bomb2);
  if (stage.contains(yesh7gBall16)) {
    removeChild(yesh7gBall16);
function first7Move3(): void {
  addChild(yesh7bomb19);
  yesh7bomb19.x = 321.30;
  yesh7bomb19.y = 109.85;
  yesh7bomb19.gotoAndPlay(1);
trace(yesh7bomb20);
TOPICS
ActionScript
Views
368
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND , Jul 30, 2015 Jul 30, 2015
Try using the trace function before that conditional to see if the value you expect for stage.contains(yesh7bomb20)  is what you think it is...  trace(stage.contains(yesh7bomb20));
If it woes what is expected then do similar checking inside the function that it leads to calling
Votes
Translate
Translate
LEGEND ,
Votes
Translate
Translate
Report
Report
Participant ,
Ok got it. turns out there was another similar object to the yesh7bomb20 doing similar but not identical thing and  I had to alter between them both. so I just had to insert another condition to cover the other object.
Thank you for your help. great tip.
Votes
Translate
Translate
Report
Report
LEGEND ,
You're welcome
Votes
Translate
Translate
Report
Report
Participant ,
Jul 31, 2015 Jul 31, 2015
does trace have a wild card to show you every item on stage?
Votes
Translate
Translate
Report
Report
LEGEND ,
No, but you might be able to use it in a loop where you use numChildren as the loop counter and then trace using the getChildAt() method...
for(var i:int=0; i<numChildren; i++){
     trace(getChildAt(i).name)
Votes
Translate
Translate
Report
Report
Participant ,
so I'm getting a lot of these which don't mean a lot to me. how can I get it with the name that I actually gave it.
instance1
instance232
instance236
instance240
instance42
instance50
instance58
instance60
instance66
instance116
instance105
instance119
instance122
instance246
instance248
instance250
instance606
instance607
instance608
instance609
instance610
instance611
instance612
instance613
instance614
instance615
instance616
instance617
instance618
instance619
Votes
Translate
Translate
Report
Report
LEGEND ,
How did you assign the names?
Votes
Translate
Translate
Report
Report
Participant ,
mostly by actionscript linkage class in properties and then in var. some are permanent on the stage but i don't care to now if they are there since obviously i know where they are.
Votes
Translate
Translate
Report
Report
LEGEND ,
Classes are not names.  If you do not assign them names then you will get the default names that you listed.  If you want to see the class names try the following instead...
     trace(getChildAt(i));
Votes
Translate
Translate
Report
Report
Participant ,
This one works. Thank you so much.
Votes
Translate
Translate
Report
Report
LEGEND ,
LATEST
You're welcome
Votes
Translate
Translate
Report
Report
