2 Replies Latest reply on Dec 15, 2006 1:54 PM by >Vee<
    Blank Popups!
    JK Hudson
      I'm not sure if I've got a depth problem or a parent/child problem but the popup generated from the SWF loaded in the shell projector opens to the right size and the title comes up but the contents are empty. The one that opens from the shell directly comes up fine. When I put test the SWF alone in the Flash Player the popups work fine. It's only in the projector as a SWF loaded in a movieclip that they fail. Please advise. Thanks!
        • 1. Re: Blank Popups!
          JK Hudson Level 1
          I have tested various content for the popup and it doesn't work for a graphic or a text string either. I'm in a deadline crunch. Any help would be appreciated.
          • 2. Re: Blank Popups!
            >Vee< Level 1
            could you use something as simple as this:
            getURL("javascript:openNewWindow('https://www.yourSite.com/" + firstVar + "','windowName','width=600,height=400,scrollbars,location,resizable,status')");
            put the following in your html head tag:
            <script language="JavaScript"> function openNewWindow(URLtoOpen, windowName,
            windowFeatures) {newWindow=window.open(URLtoOpen, windowName, windowFeatures); }</script>
            Hope that helps
