1 Reply Latest reply on Aug 3, 2015 10:44 AM by Jamo
    Reading CMYK jpeg images
    chandra12345 Level 1
      I am unable to read CMYK jpeg images from coldfusion 10. Below are my server configuration.
      Coldfusion 10 (update 14),32 bit and windows 2008 r2 64 bit,jre(1.6)
      i found below code in java and implemented in coldfusion,but the code is working fine in coldfusion 10 64 bit,but not coldfusion 32 bit.
      Shall i get any help on this?
      public class CMYKTiffToJpegConvertor {
        public CMYKTiffToJpegConvertor() {
        // TODO Auto-generated constructor stub
        public static void main(String[] args) throws IOException, Exception
        new CMYKTiffToJpegConvertor().processConvertionImage(ImageConstants.FILE_PATH,ImageConstants. INPUT_FILE_NAME);
        System.out.println("Successfully Completed the conversion!!");
        * @param filePath
        * @param fileName
        * @throws IOException
        * @throws Exception
        public void processConvertionImage(String filePath,String fileName) throws IOException, Exception{
        fileName = filePath+fileName;
        BufferedImage img =  readImage(fileName);
        String milliSec = new String(""+new Date().getTime()+"_");
        String path = filePath+milliSec+ImageConstants.OUTPUT_FILE_NAME;
          ImageIO.write(img,"jpg", new File(path));
        public static final int COLOR_TYPE_RGB = 1;
          public static final int COLOR_TYPE_CMYK = 2;
          public static final int COLOR_TYPE_YCCK = 3;
          private int colorType = COLOR_TYPE_RGB;
          private boolean hasAdobeMarker = false;
           * @param filename
           * @return
           * @throws ImageReadException
          public BufferedImage readImage(String filename) throws IOException, ImageReadException {
              File imgfile = new File(filename);
              ImageInputStream stream = ImageIO.createImageInputStream(imgfile);
              Iterator<ImageReader> iter = ImageIO.getImageReaders(stream);
              while (iter.hasNext()) {
                  ImageReader reader = iter.next();
                  reader.setInput(stream);
                  BufferedImage image;
                  ICC_Profile profile = null;
                  try {
                      image = reader.read(0);
                  } catch (IIOException e) {
                      colorType = COLOR_TYPE_CMYK;
                      checkAdobeMarker(imgfile);
                      profile = Sanselan.getICCProfile(imgfile);
                      WritableRaster raster = (WritableRaster) reader.readRaster(0, null);
                      if (colorType == COLOR_TYPE_YCCK)
                          convertYcckToCmyk(raster);
                      if (hasAdobeMarker)
                          convertInvertedColors(raster);
                      image = convertCmykToRgb(raster, profile);
                  return image;
              return null;
           * @param file
          public void checkAdobeMarker(File file) throws IOException, ImageReadException {
              JpegImageParser parser = new JpegImageParser();
              ByteSource byteSource = new ByteSourceFile(file);
              @SuppressWarnings("rawtypes")
              ArrayList segments = parser.readSegments(byteSource, new int[] { 0xffee }, true);
              if (segments != null && segments.size() >= 1) {
                  UnknownSegment app14Segment = (UnknownSegment) segments.get(0);
                  byte[] data = app14Segment.bytes;
                  if (data.length >= 12 && data[0] == 'A' && data[1] == 'd' && data[2] == 'o' && data[3] == 'b' && data[4] == 'e')
                      hasAdobeMarker = true;
                      int transform = app14Segment.bytes[11] & 0xff;
                      if (transform == 2)
                          colorType = COLOR_TYPE_YCCK;
           * @param raster
          public static void convertYcckToCmyk(WritableRaster raster) {
              int height = raster.getHeight();
              int width = raster.getWidth();
              int stride = width * 4;
              int[] pixelRow = new int[stride];
              for (int h = 0; h < height; h++) {
                  raster.getPixels(0, h, width, 1, pixelRow);
                  for (int x = 0; x < stride; x += 4) {
                      int y = pixelRow[x];
                      int cb = pixelRow[x + 1];
                      int cr = pixelRow[x + 2];
                      int c = (int) (y + 1.402 * cr - 178.956);
                      int m = (int) (y - 0.34414 * cb - 0.71414 * cr + 135.95984);
                      y = (int) (y + 1.772 * cb - 226.316);
                      if (c < 0) c = 0; else if (c > 255) c = 255;
                      if (m < 0) m = 0; else if (m > 255) m = 255;
                      if (y < 0) y = 0; else if (y > 255) y = 255;
                      pixelRow[x] = 255 - c;
                      pixelRow[x + 1] = 255 - m;
                      pixelRow[x + 2] = 255 - y;
                  raster.setPixels(0, h, width, 1, pixelRow);
           * @param raster
          public static void convertInvertedColors(WritableRaster raster) {
                  for (int x = 0; x < stride; x++)
                      pixelRow[x] = 255 - pixelRow[x];
           * @param cmykRaster
           * @param cmykProfile
           * @return
          public static BufferedImage convertCmykToRgb(Raster cmykRaster, ICC_Profile cmykProfile) throws IOException {
              if (cmykProfile == null)
                  cmykProfile = ICC_Profile.getInstance(CMYKTiffToJpegConvertor.class.getResourceAsStream("/ISOcoated_v2_ 300_eci.icc"));
              if (cmykProfile.getProfileClass() != ICC_Profile.CLASS_DISPLAY) {
                  byte[] profileData = cmykProfile.getData();
                  if (profileData[ICC_Profile.icHdrRenderingIntent] == ICC_Profile.icPerceptual) {
                      intToBigEndian(ICC_Profile.icSigDisplayClass, profileData, ICC_Profile.icHdrDeviceClass); // Header is first
                      cmykProfile = ICC_Profile.getInstance(profileData);
              ICC_ColorSpace cmykCS = new ICC_ColorSpace(cmykProfile);
              BufferedImage rgbImage = new BufferedImage(cmykRaster.getWidth(), cmykRaster.getHeight(), BufferedImage.TYPE_INT_RGB);
              WritableRaster rgbRaster = rgbImage.getRaster();
              ColorSpace rgbCS = rgbImage.getColorModel().getColorSpace();
              ColorConvertOp cmykToRgb = new ColorConvertOp(cmykCS, rgbCS, null);
              cmykToRgb.filter(cmykRaster, rgbRaster);
              return rgbImage;
      * @param value
      * @param array
      * @param index
          public static void intToBigEndian(int value, byte[] array, int index) {
        array[index] = (byte) (value >> 24);
        array[index + 1] = (byte) (value >> 16);
        array[index + 2] = (byte) (value >> 8);
        array[index + 3] = (byte) (value);
        • 1. Re: Reading CMYK jpeg images
          Jamo Level 2
          I gave up using ColdFusion-related image functions. I've still identified CMYK images that can't consistently be read by ColdFusion 10.  I also still have some apps running on ColdFusion 9 and needed a solution that was backwards compatible.
          I started using CFX_OpenImage, but it hasn't been updated in a while.  I recently wrote a ColdFusion Custom Tag to access GraphicsMagick.  It can be installed on pretty much any 32-bit or 64-bit operating system.  It supports 88 major formats including important formats like DPX, GIF, JPEG, JPEG-2000, PNG, PDF, PNM, and TIFF.  This method is faster than CFImage and often generates much smaller files.
          Here's the link to the custom tag if you are interested.:
          http://gamesover2600.tumblr.com/post/125766251344/graphicsmagick-coldfusion-custom-tag
          Converting any JPG to a non-CMYK JPG can be done by:
          <CF_GraphicsMagick action="Optimize" Infile="#ImageIn#">
