8 Replies Latest reply on Aug 1, 2015 7:57 AM by W_J_T
    Show/Hide guides via JavaScript?
    victorcarbajo Level 1
      With this script I can delete all guides in all open documents:
      for (d = 0; d < app.documents.length; d++) {
        var targetDocument = app.documents[d];
        activeDocument = targetDocument;
        var doc = app.activeDocument;
        for (var i = doc.pathItems.length-1; i >= 0; i--) {
        var p = doc.pathItems[i];
        if (p.guides == true) {
        p.remove();
      But, how can I modify this script for show/hide guides?
      Thanks.
        • 1. Re: Show/Hide guides via JavaScript?
          W_J_T Level 4
          victorcarbajo wrote:  Show/Hide guides via JavaScript? How can I modify this script for show/hide guides?
          The following should work:
          // Replace:
          p.remove();
          // With the following:
          p.hidden = !p.hidden;
          Or, if you have CS6 or above you could consider trying executeMenuCommand:
          // CS6 and above you can try... (not tested)
          app.executeMenuCommand('showguide');
          • 2. Re: Show/Hide guides via JavaScript?
            Thanks W_J_T for your response.
            "app.executeMenuCommand('showguide');" works correctly, but "p.hidden = !p.hidden;" or "p.hidden = true" deletes (?!) the guides.
            Which is the "app.executeMenuCommand" for hidden guides?
            Thanks.
            • 3. Re: Show/Hide guides via JavaScript?
              W_J_T Level 4
              I just tested it with the code you posted, it works fine for me. Did you delete the line: p.remove() and replace it with the one I posted above? p.hidden = !p.hidden;
              As for the executeMenuCommand I would assume each time that its called it would toggle between the present state, but not sure, I don't have CS6+ to test it.
              • 4. Re: Show/Hide guides via JavaScript?
                Thanks W_J_T,
                Effectively, the executeMenuCommand toggle between the show/hide state.
                In my case (I use Ilustrador CC 2015), this code deletes the guides:
                • 5. Re: Show/Hide guides via JavaScript?
                  W_J_T Level 4
                  You're welcome, glad the executeMenuCommand was helpful to your efforts.
                  victorcarbajo wrote: In my case (I use Ilustrador CC 2015), this code deletes the guides:
                  I do not have CC to test it in, but you can try restarting Illustrator, then wrapping the code in a function to be called. See example below:
                  function tG() {
                      var doc, p;
                      for (var d = 0; d < app.documents.length; d++) {
                          doc = app.documents[d];
                          for (var i = doc.pathItems.length - 1; i >= 0; i--) {
                  tG();
                  Aside from those two things, * plus cleaning up the code you posted a little, I'm not sure why it would not be compliant in CC and instead be deleting the guides? That sounds rather strange.
                  • 6. Re: Show/Hide guides via JavaScript?
                    CarlosCanto Adobe Community Professional & MVP
                    your code does work in CC
                    • 7. Re: Show/Hide guides via JavaScript?
                      I don't know what happens in my Illustrator, but your code deletes the guide lines. I restart several times with the same result.
                      I use your other code for hide/show guides:
                      With best regards.
                      • 8. Re: Show/Hide guides via JavaScript?
                        W_J_T Level 4
                        Thanks for checking/confirming CarlosCanto.
