2 Replies Latest reply on Aug 1, 2015 8:40 AM by Steve Werner
    backward save cc 2014 to cc
    just none
      I followed the instructions to backward save, Save as InDesign CS4 or later (IDML) and after saving with a new name, thay show Adobe InDesign CC2014 document.
      How do I save to an older version?
        • 1. Re: backward save cc 2014 to cc
          You've done it. It's your OS that determines what the default program to open the file will be when you double-click it, but you will be able to use File > Open... to access the IDML in any version from CS4 forward.
          • 2. Re: backward save cc 2014 to cc
            Steve Werner Adobe Community Professional & MVP
            Regardless of what the name of the file may say, when you save an IDML from CC 2014, it can be opened (File > Open) from InDesign CC, from InDesign CS6, from InDesign CS5.5, from InDesign CS5, and from InDesign CS4.
            You won't be able to double-click on it to open in InDesign CC, you would need to choose File > Open and select the file from within the program.
