I want to add a number of radio buttons to a slide, to be used for navigation. I don't need a widget - in fact, it could even just be an image of a radio button. I can't find that in Captivate 7. Is there a simple radio button?
-Stuart
You can reduce the radiobutton interaction to one button, and you'll have:
Thanks. I'll give that a try. I've got another Advance Actions dilemma now. I'm creating one in CP7 very similar to the one you helped me with in 8. (That was a prototype. The client wants the project created in 7.) The only difference is that when the question is answered correctly and the Answer slide displays, the actions now include showing a caption that was initially not visible, like the incorrect messages were in my CP8 version. No matter what I enter, none of the messages display, and the thing always ends up on the Answer page, even if I submit the wrong answer.
CP7 doesn't have that Preview feature that displays the code, so I can't include that here. Does CP7 handle anything differently in Advanced Actions or invisible captions?
I'm going to call it a night soon, and get back at this in the morning.
Thanks for all your help.
-Stuart
Hi Stuart, you should start a new thread because that is a totally different subject.
As for the radiobutton; the third functionality (resetting) is not working in Captivate 7.
The Preview button for advanced conditional actions was already available in CP7. It is not, even in CP8, available for standard actions. AFAIK the only difference between CP7 and CP8 is the added possibility to define literals and variables as parameters in shared actions. For normal advanced actions, nothing changed; you probably have another issue.
Thanks for more radio button and advanced actions information. You're right, I should have started a new thread. I even thought of that as I was writing that post, but I was feeling desperate - that's no excuse though. In future I'll always start a new thread for a new topic.
A little bit ago I realized the advanced actions step I missed, and fixed it. It's all working fine now.
Thanks much,
-Stuart
Just my opinion, but I'd hesitate to use radio buttons for navigation. I don't think it follows typical usability standards. To me, radio buttons correlate to making a "selection" for a list, form, or data entry. Any reason not to use a button for navigation?
It's a list at the beginning of the course, I'm a new employee," "I've been here 6 months," etc. You pick your status and it takes you to the appropriate starting point. The project head wants to use radio buttons, but I think I'll just use nav buttons - keep it simple.
Thanks.
-Stuart
Why do you want 'one' radio button in that case, instead of using the number you need and use a conditional action to check the value of the variable associated with the radio buttons interaction? That is a lot easier than having many one button radio interactions. I can see why this is wanted, since one choice out of many is asked, radio buttons are a logical choice in that case.
Sorry I didn't reply to this earlier. The project is done, but I'll keep this in mind when I have a similar situation.
