1 Reply Latest reply on Dec 17, 2006 8:05 AM by James Newton, ACP
    setpref doesn't work
    uv_h
      hi all!
      for some reason when i use setpref i can't find the text file it is supposed to write (not even in the application path, where it should be, under prefs folder).
      any1 have an idea how to solve this ???
        • 1. Re: setpref doesn't work
          James Newton, ACP Level 3
          It sounds like you are using Director 10.1. In Director 10, the location of the Prefs files were moved to on of the following, depending on platform and runMode:
          "MacHD:Users:<username>:Library:Application Support:Macromedia:Director MX 2004:<projector name>:Prefs:<prefs name>.txt"
          "MacHD:Users:<username>:Library:Application Support:Macromedia:Shockwave Player:Prefs:<randomname>:<prefs name>.txt"
          "C:/Documents and Settings/<username>/Application Data/Macromedia/Director MX 2004/<projector name>/Prefs/<prefs name>.txt"
          "C:/Documents and Settings/<username>/Application Data/Macromedia/Shockwave Player/Prefs/<random name>/<prefs name>.txt"
