Hello! I've got a problem with the fluency of the zoom. When I want to zoom the image is bouncing. Please help me!
import flash.events.MouseEvent;
stage.addEventListener(MouseEvent.MOUSE_WHEEL, Zoom);
function Zoom(e:MouseEvent):void
var mod:Number = 20;
img_mc.scaleX += e.delta / mod;
img_mc.scaleY += e.delta / mod;
if( img_mc.scaleX<1){
img_mc.scaleX= img_mc.scaleY=1;
img_mc.x = ((mouseX) - (((e.stageX - 683) * img_mc.scaleX)));
img_mc.y = ((mouseY) - (((e.stageY - 280.5) * img_mc.scaleY)));
I would suggest two things - first, if this is an image you're zooming, that smoothing is enabled in it's properties or you're setting it by code. Second, you have 280.5 in your y setting. Things cannot be on half pixels even though Flash, as a vector tool, allows it.Flash shouldn't allow it. Not using whole integers for positioning can make text look ugly, images appear aliased, etc...
Where can i enabled the smoothing? What can i use instead of these numbers?
You enable smoothing either in the images properties, or by code if you're loading by code. Use integers instead of floats is all...
Other question: If i use this zoom code, but i want to zoom to the position of the mouse?
kep2.scaleX += e.delta / mod;
kep2.scaleY += e.delta / mod;
if(kep2.scaleX<1){
kep2.scaleX=kep2.scaleY=1;
kep2.scaleX *= Math.max(scaleY,scaleX);
kep2.scaleY *= Math.max(scaleX,scaleY);
thanks
