• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
need to include coldfusion query as dropdown option
Community Beginner ,
Aug 03, 2015 Aug 03, 2015
<script> function myFunction() { document.getElementById("demo").innerHTML += "<select><option value='1'>option1</option><option value='1'>Option2</option><option value='1'>Option3</option><option value='1'>Option4</option><option value='1'>Option5</option></select>";   var select = document.createElement("select"); //replace this second dropdown with the coldfusion query in below place         var option = document.createElement("option"); option.value = "SubOption1"; option.text = "SubOption"; select.appendChild(option);  document.getElementById("demob").appendChild(select);  return false; } </script>
The above javascript shows dropdown with 5 options, when any of that is selected, the second dropdown shows and list "SubOption1" as the second dropdown options.
My question or where i need further help is, i have a coldfusion query
<cfselect name="NameList" size="1" query="UserRole_q" value="EmpID" display="Name" selected="#temp#"          > <option value="-1"></option> </cfselect>
which pulls all employee names from the database and list as options.
so, to end my question , i need help placing this coldfusion query to replace the second dropdown ("SubOption1") in the javascript above. thank you for your time
Views
385
Translate
Translate
Report
Report
Community guidelines
community guidelines
Engaged ,
Aug 04, 2015 Aug 04, 2015
The forum doesn't seem to be showing your code correctly (runs off the page for me so I can't view it in FF and Chrome).  Any chance you can try to reformat it so we can attempt to answer your question?
Votes
Translate
Translate
Report
Report
<script>
</select>";
return false;
} </script>
<cfselect name="NameList" size="1" query="UserRole_q" value="EmpID" display="Name" selected="#temp#"><option value="-1"></option> </cfselect>
Votes
Translate
Translate
Report
Report
Engaged ,
Aug 06, 2015 Aug 06, 2015
LATEST
If you aren't going to be retrieving the options via Ajax the easiest solution is just to loop over the query within your JS:
<cfoutput>
  <cfloop query="UserRole_q">
    option.value = "#UserRole_q.empId#";
    option.text = "#UserRole_q.name#";
  </cfloop>
</cfoutput>
Something like that should work.  You might have to tidy it up.
Votes
Translate
Translate
Report
Report
Resources
Documentation
