2 Replies Latest reply on Dec 22, 2006 7:52 AM by ksmith
    Activating Flash, ActiveX, Java Applets
    sparkyy3 Level 1
      Could someone explain to me "specifically" what do "you" do to remove the IE6 message "Press spacebar to activate or use control" message from a coldFusion "Cfform" or "CFgrid"? I've been successfull at removing the message from a Flash movie in my Javascript. But how do you do that with a whole Coldfusion form.
      With the stand-alone Flash movie in my Javascript we write the "string" that produces the Flash object to a varible, then call a external Javascript file to "document.write" the object out again, but how would you do that with a Flash Coldfusion form or a CFGrid? The Flash Coldfusion form's code is generated dynamically?
      Could someone explain specifically what I need to do to correct this problem?
