• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Limit to formatted cells in Excel?
Guest
Aug 03, 2015 Aug 03, 2015
Hello,
I'm generating a normal spreadsheet file and formatting a couple of columns with SpreadsheetFormatColumn, to give them a particular date format. If I open the file through OpenOffice, everything works perfectly. However, if I open it through Excel, any cell in the formatted column past the 32nd row does not display the proper format (Cell is displayed as "general") and I need to do it manually.
What could be causing this?
Views
296
Translate
Translate
Report
Report
Community guidelines
community guidelines
Enthusiast ,
Aug 04, 2015 Aug 04, 2015
You didn't indicate which version of ColdFusion you are using.  ColdFusion 10 is better than 9, but I don't think either version is correctly formatting dates.
Ben Nadal's POI Utility does a better job of exporting and retaining the date format (and it's faster & generates smaller Excel files).
https://github.com/bennadel/POIUtility.cfc
I wrote a UDF to export queries using Ben's library. It will detect & properly format dates more reliably than CFSpreadsheet.
http://gamesover2600.tumblr.com/post/116662989199/coldfusion-cfexcelpoi
Votes
Translate
Translate
Report
Report
Guest
LATEST
I'm currently running 9, but you are correct, I ran the test on 10 and it did not properly work either.
Thanks for the utilities, I'll give it a shot and report back.
Votes
Translate
Translate
Report
Report
Resources
Documentation
