7 Replies Latest reply on Aug 7, 2015 4:43 AM by A.T. Romano
    error code U41M1C212
    BARNEYROVER
      Trying to update elements 11 and getting above error code.  Anyone any thoughts?
      thanks
        • 1. Re: error code U41M1C212
          A.T. Romano Level 7
          Barneyrover,
          What is it that you are trying to update - a program update or a Camera Raw update. That is all you are going to get.
          1. There is no Premiere Elements 11 program update as there is for 9, 12, and 13.
          2. What version of Camera Raw does your system now have?
          Please check out the details for getting the best possible Camera Raw (last one possible for 11)
          ATR Premiere Elements Troubleshooting: PE11 and 12: Camera Raw Plug-In Version
          Now back to getting the 11's Help Menu/Updates to work to get essentially what you might get with the above consideration.
          1. Does the problem exist with and without the antivirus and firewalls disabled?
          2. Have you read and tried the following? This one has typically been a winner for Help Menu/Updates in many Adobe products including Premiere Elements.
          Photoshop Elements (PSE) knowledge base.
          Please review and consider, and let us know the outcome.
          Thanks.
          ATR
          • 2. Re: error code U41M1C212
            BARNEYROVER Level 1
            Thanks for reply.  Didn’t realise elements 11 cannot be updated.
            Have tried disabling antivirus but still same error message. “Update server not responding  error code xxxx”
            Just trying to keep programme up to date that’s all, no specific problem.
            Thanks anyway
            • 3. Re: error code U41M1C212
              A.T. Romano Level 7
              BARNEYROVER
              Thanks for the reply with further details of your situation.
              Although there is no program update for Premiere Elements 11, the Camera Raw might need updating if you need that feature?
              Just a reminder, when you have installed a version of Camera Raw that is supported by your camera and version of Photoshop Elements/Premiere Elements, you can import raw format images and dng images as source media into your Premiere Elements project. But, you need Photoshop Elements to be able to open the Camera Raw dialog for edits of the raw format images et al.
              Best wishes with your Premiere Elements workflows.
              ATR
              • 4. Re: error code U41M1C212
                BARNEYROVER Level 1
                Being somewhat of a novice, how do I check to see if camera Raw needs updating and how is this done? Thanks
                • 5. Re: error code U41M1C212
                  A.T. Romano Level 7
                  BARNEYROVER
                  Please check out the following, and let me know if you found the Camera Raw version you currently have installed on your computer....assuming you have Photoshop Elements 11 and Premiere Elements 11.
                  If you have a raw file image that will not open in to a Camera Raw dialog or you cannot import raw images or dng files into Premiere Elements Editor, then you need to determine
                  a. that you have a Camera Raw version that supports your camera
                  Camera Raw plug-in | Supported cameras
                  b. If the Camera Raw version that you need is supported by the version of Photoshop Elements Premiere Elements that you have
                  Camera Raw-compatible Adobe applications
                  Several versions back, you could download and manually install the Camera Raw plug-in. But, now it is only via Help Menu/Updates of the opened project.
                  If you have Photoshop Elements, you can easily find the version of Camera Raw that you have...see Photoshop Elements Editor, Help Menu/About Plug-ins/Camera Raw.
                  Thanks.
                  ATR
                  • 6. Re: error code U41M1C212
                    BARNEYROVER Level 1
                    Hi
                    Can use camera raw ok  version 7.1.0.354  with canon eos650d.
                    Have Photoshop elements 11 and premier elements installed.
                    Read that these could be updated but it appears not.
                    • 7. Re: error code U41M1C212
                      A.T. Romano Level 7
                      BARNEYROVER
                      You should be able to take Photoshop Elements 11 and Premiere Elements 11 to Camera  Raw 8.1 by special techniques as described in my blog post which I already mentioned in your thread. You download and manually install Camera Raw 8.1 according to instructions in the blog
                      Please let me know if you have read that yet and have given it a try.
                      Thanks.
                      ATR
