Long story short: is there any way to increment a user's score on a quiz without incrementing the number of points possible?
Long story long:
I would like to create a branched adaptive quiz that is set up so that users are given a question worth 3 points. If they get the question right, they move on to the next 3-point question. If they get the question wrong, I would like to give them 3 1-point questions that give them the chance to "make up" the missing 3 points.
I have the branching working correctly. The logic is there. But I do not seem to be able to manipulate the total score and/or the total points possible manually.
In my sample, which is worth 5 points, here are a couple of scenarios.
Scenario 1:
Q1: User gets 3/3
Q2: User gets 2/2
Final Score: 5/5
Scenario 2:
Q1: User gets 0/3
Q1a: User gets 1/1 I would like this to be 1/0.
Q1b: User gets 1/1
Q1c: User gets 1/1
Q2: User gets 2/2
Final Score: 5/8. I would like this to show 5/5.
I also tried to fake this out with my LMS by having SCORM report just the points the user acquired and forcing the assessment to be worth only 5 points. My thought was that each scenario would return 5 points (the number the user scored) and that would solve the issue. However, in Scenario 1 5 points was reported, but in Scenario 2, 3.13 points were sent to the LMS. It still calculated the ratio of points awarded to points possible.
Thanks.
You cannot manipulate the total score, the quizzing system variables are read only. If you have scored questions/objects for 8 points, the total score will always be 8 points. Only with Branch aware can you have a dynamic total score, but here you do not have two different branches. The user who failed in the first branch will take the second one as well. You could "cheat", will try to explain. A similar situation is explained in more detail here: Report Custom Questions - part 2 - Captivate blog
I have no time to double check, but the idea is to have Branch aware checked. And here is the scenario for the two groups that are opposite: 'good' have both first question correct, bad have none correct. Now you need to create two branches, so that both have exactly the same total score, in this example 10 points.
Not all scenarios are there, I know but do you see the idea? You probably will need two extra scored buttons, one with 2 and one with 3 points.
Yes, that's the path I was going down. Good to have some similar thoughts.
This would get very confusing for a long interaction, but for short quizzes it should work just fine.
Rob
