5 Replies Latest reply on Aug 6, 2015 11:28 AM by cjhensun
    Layer Not Rendering Out
      I created a dancing bull animation with the body on one layer rocking back and forth by using the puppet tool. All other layers are fine and none of the links are broken. However, for some reason when I try to render it out, it renders out everything except for the body's animation. The body is still as if I didn't do anything to it.
      Also, when I check the RAM preview, you only see the body's animation when you're viewing the composition at 50%. If you're viewing the composition at any other percentage, the body is still. When I render the RAM preview at 50%, the body dances how I want it to but the size isn't correct. If I zoom in and try to render the RAM preview, the body is still again.
      I've been trying to look up an answer for the last hour with no luck. Please help me if you can.
