1 Reply Latest reply on Aug 7, 2015 1:04 AM by haxtbh
    drop down menu link
    jamie61880 Level 1
      Hi. I just have a simple drop down menu. I would just like to have one of the options be a link. How do I do that? I thought I found something yesterday that would work, but it doesn't. Here's what I found:
      <select name="Socket_Adapter_Choice" onchange="location = this.options[this.selectedIndex].value;">
        <option selected value=""></option>
          <option value="Add_Socket_App.cfm">Add Socket Application</option>
        <option value="Add_Adapter_App.cfm">Add Adapter Application</option>
        </select>
      Thanks.
      Andy
        • 1. Re: drop down menu link
          haxtbh Level 4
          Google is you friend! There are so many results just for this type of question on stackoverflow.
          Anyway, you will need to do something liek this:
          <select name="Socket_Adapter_Choice" onchange="window.location.href = this.value">
          </select>
          The problem you might have is if someone selects the blank option you have. Ideally you want the onChange event to fire a function that checks its not blank and then changes the url.
          <select name="Socket_Adapter_Choice" onchange="goToPage(this.value);">
          </select>
             function goToPage(url)
                  if(url != '') {
                       window.location.href = url;
          </script>
