0 Replies Latest reply on May 16, 2006 9:35 AM by JKringen
    ComboBox Cell Renderer
    JKringen Level 1
      I'm using a ComboBoxCell class that I got from the Macromedia website to display a ComboBox inside of a DataGrid component. The problem I'm having, which no one else seems to have, is that the current selected item on the ComboBox will NOT appear on the ComboBox! If you open the ComboBox, you will see the highlight item as you should, but the selected item NEVER appears on the ComboBox itself at all. I have tried everything I can think of, even navigating through the entire component hierarchy to the TextInput component which actually displays the ComboBox's current item, and everything seems like it should be working! The class code is listed here so you can see the class for yourself. I greatly appreciate any help as I am stuck on this. Thanks!
      -Jason Kringen
