2 Replies Latest reply on Aug 8, 2015 5:26 AM by Just Shoot Me
    Problems with import from SD to external HDD
    RasmusU
      Hi
      I have a MacBook Pro (mid 2010) with Yosemite, Lightroom CC and Canon 70D. I have three almost full 64 gb SD cards and usually I have no problems with the import process, but now everything (!!!) is tricky... I will list up the different problems, and hope that some of you can help me:
      • Regularly Finder freezes which I have never experienced before - you may think that it could be due to an almost full harddrive, but it is a quite new 500 gb SSD with 218 gb free space :-)
      • Also Lightroom freezes regularly...
      • When none of them are frozen and the SD card is selected as source in the import dialog, Lr do not show the previews (see picture below).Skærmbillede 2015-08-08 kl. 13.42.30.png
      • Sometimes some of the grey boxes says: "Preview unavailable for this file" while others shows a small icon with CR2 (the RAW-file). If I am lucky a few previews actually is preview pictures.
      • If I try to start the import, the process goes like this: hit the import button -> it seems that it is working but after a while... -> ...nothing happens -> I cancel the import -> Lr gives this message: "No photos or videos were found to import".
      What can I do?
      With regards and thank you in advance,
      Rasmus
        • 1. Re: Problems with import from SD to external HDD
          Just Shoot Me Adobe Community Professional
          If you use Finder to Copy the image to that Prove folder on the external drive does Finder (OS X) Freeze? If it does then you have either a problem with that SD card, a problem with the external drive or a problem with your Mac. Finder should not freeze during the copying of files from on drive (hard drive or memory card) to another drive whether they are internal or external.
          I suspect that memory card is going bad or has some corrupted files on it that can't be read. Just like physical hard drives you shouldn't fill up a SD memory card all the way. Always leave at least 10%, and better 15-20%, free space on all drives of any type.
          • 2. Re: Problems with import from SD to external HDD
            Try using Finder again only this time only select a few images at a time to copy. Like 20-30 files at a time. If it still freezes with some reduce that number to just a few to sort out the files that are causing the freezes. That mean some will need to be copied one by one so you can record and omit the ones that are corrupted.
