5 Replies Latest reply on Dec 13, 2006 5:12 AM by Newsgroup_User
    From ASCII txt file to MS SQL with UTF-8 Korean
    atomic
      I am trying to convert korean text ([Àç¹Ì] ¿·Áý ºÎÀÎÀÌ ¾Æ³»º¸´Ù ÁÁÀºÀÌÀ¯? ) which is saved in a tab delimited text file into MS SQL with UTF-8/Unicode characters ([생각] 인생을 즐길 수 있는 좋은 나이는? ).
      I have tried ascii_utf8 and CF_charsetConvert 1.1 and it didn't work.
      Is there any other CF tags that can do the jobs?
        • 1. Re: From ASCII txt file to MS SQL with UTF-8 Korean
          Level 7
          atomic wrote:
          > I am trying to convert korean text ([���] ���� ������ �Ƴ����� ������? )
          > characters ([??] ??? ?? ? ?? ?? ???? ).
          what is the encoding of the text file?
          • 2. Re: From ASCII txt file to MS SQL with UTF-8 Korean
            atomic Level 1
            I am not very sure on the encoding for the text file but its from Masterpask, should be ascii.
            In Excel, if I open the text file Excel will ask for the data type, I would choose 949:Korean and it would display the Korean characters fine but I am using CFMX 6.1 to download the txt file and read its content and write it to MS SQL.
            In MS SQL, it displays the Korean characters as unreadable characters.
            But if I open the text file in a browser with (with UTF-8 encoding), it displays the Korean characters as lots of question marks (????), but if I switch to Korean encoding, the Korean characters displays correctly.
            • 3. Re: From ASCII txt file to MS SQL with UTF-8 Korean
              Level 7
              > should be ascii.
              if it's korean it can't be ASCII has to be some kind of (maybe) windows codepage
              for korean.
              > SQL.
              try adding the charset option to your cffile call w/i guess windows-949
              encoding. then display it in your browser. check what the browser thinks the
              encoding is. if its' still garbage try another encoding for cffile maybe MS949,
              euc-kr, or ISO-2022-KR.
              • 4. Re: From ASCII txt file to MS SQL with UTF-8 Korean
                atomic Level 1
                I have tried it but im getting CFMX error when using
                <cffile action = "read" file = "myPath\myPath.txt" variable = "myVar" charset = "euc-kr">
                sun.io.ByteToCharEUC_KR.getIndex1()[S
                Did I miss out on any ColdFusion Administration settings? Maybe JVM?
                • 5. Re: From ASCII txt file to MS SQL with UTF-8 Korean
                  Level 7
                  > = "euc-kr">
                  not sure about cf6, get the charset cfc from here:
                  http://www.sustainablegis.com/projects/i18n/charsetTB.cfm
                  and see what your system supports. also try one of the others like
                  x-windows-949, etc.
                  no, either that JRE doesn't support EUC-KR (kind of unlikely) or the JRE isn't
                  the international one with the "extra" charsets (my guess). if you can update
                  the JRE (for cf6-7, it has to be 1.4.x family), try that. make sure you get the
                  server version & international one (though i think that's all they d/l these days).
