5 Replies Latest reply on Aug 9, 2015 9:28 PM by Qwertyfly...
    Button.onClick does not work when I renamed
    julioc4816867 Level 1
      Hello, I have a little Script, when I renowned "Ok" to "Aceptar" and does not work, I pressed click, Enter, Spacebar, and Does not work
      I have Adobe Illustrator CC2015
      var button = new Window('dialog', '');
      btnName = button.add('button',undefined,'Ok');  //btnName = button.add('button',undefined,'Aceptar');  //
      btnName.onClick = function() {
      alert ("Works!")
      button.show();
          Run Script:
      when I click in "aceptar", Alert does not show and "aceptar" button shows an orange edge
      Help me Pls , Sorry my bad english
        • 1. Re: Button.onClick does not work when I renamed
          Qwertyfly... Level 4
          this worked fine for me.
          double check your code for any spelling mistakes.
          copy this and see if it works for you. just to make sure its not just a missing semicolon or something
          var btnName = button.add('button',undefined,'Aceptar');
          alert ("Works!");
          button.show();
          edit. you could try restarting illustrator just to make sure the JS engine is clean.
          • 2. Re: Button.onClick does not work when I renamed
            no, it does not work, look thats scripts by Carlos
               ////// LINE  54
            win.g100.bu2 = win.g100.add('button',undefined,'Cancel'); /////////////////////////////////////////  Please, try to rename "cancel" to "Cancelar"
            to "cancel"
            works perfect with "cancel", but rename to "cancelar", click does works :S
            Run first with "cancel", second close that script, third, renown "Cancelar" and run script, click does not work , I've tried on another computer :S
            #target illustrator
            main();
            function main(){
                if(!documents.length) return;
                //var allLayers = app.activeDocument.layers;
                var win = new Window( 'dialog', '' );
                g = win.graphics;
                //  var myBrush = g.newBrush(g.BrushType.SOLID_COLOR, [0.99, 0.99, 0.99, 1]); // CS5
                var myBrush = g.newBrush(g.BrushType.SOLID_COLOR, [0.50, 0.50, 0.50, 1]); // CS6
                g.backgroundColor = myBrush;
                win.orientation='stack';
                win.p1= win.add("panel", undefined, undefined, {borderStyle:"black"});
                win.g1 = win.p1.add('group');
                win.g1.orientation = "row";
                win.title = win.g1.add('statictext',undefined,'Rename Visible Layers or Sublayers');
                win.title.alignment="fill";
                var g = win.title.graphics;
                g.font = ScriptUI.newFont("Georgia","BOLDITALIC",22);
                win.g5 =win.p1.add('group');
                win.g5.orientation = "column";
                win.g5.alignChildren='left';
                win.g5.spacing=10;
                win.g5.st1 = win.g5.add('statictext',undefined,'New layer name');
                win.g5.et1 = win.g5.add('edittext');
                win.g5.et1.preferredSize=[250,20];
                win.g10 =win.p1.add('group');
                win.g10.orientation = "row";
                win.g10.alignment='fill';
                win.g10.spacing=10;
                win.g10.st1 = win.g10.add('statictext',undefined,'Serial Number');
                win.g10.et1 = win.g10.add('edittext',undefined,'1');
                win.g10.et1.preferredSize=[50,20];
                win.g10.et1.onChanging = function() {
                  if (this.text.match(/[^\-\.\d]/)) {
                    this.text = this.text.replace(/[^\-\.\d]/g, '');
                win.g10.st1 = win.g10.add('statictext',undefined,'Length');
                var nums=[2,3,4,5];
                win.g10.dl1 = win.g10.add('dropdownlist',undefined,nums);
                win.g10.dl1.selection=0;
                win.g15 =win.p1.add('group');
                win.g15.orientation = "row";
                win.g15.alignment='fill';
                win.g15.cb1 = win.g15.add('checkbox',undefined,'Reverse layer order');
                win.g15.cb2 = win.g15.add('checkbox',undefined,'Rename Sublayers Only');
                win.g100 =win.p1.add('group');
                win.g100.orientation = "row";
                win.g100.alignment='center';
                win.g100.spacing=10;
                win.g100.bu1 = win.g100.add('button',undefined,'Rename');
                win.g100.bu1.preferredSize=[120,30];
                win.g100.bu2 = win.g100.add('button',undefined,'Cancel'); /////////////////////////////////////////  Please, try to rename "cancel" to "cancel"
                win.g100.bu2.preferredSize=[120,30];
                win.g100.bu1.onClick=function(){
                    if(win.g5.et1.text == ''){
                        alert("No layer name has been entered!");
                        return;
                    win.close(0);
                    var sublayersOnly = win.g15.cb2.value;
                    var visibleLayers = [];
                    getVisibleLayers (app.activeDocument, visibleLayers, sublayersOnly);
                    if(win.g15.cb1.value) visibleLayers.reverse();
                    for(b=0; b<visibleLayers.length; b++){
                        var LayerName = win.g5.et1.text + zeroPad((Number(win.g10.et1.text)+Number(b)), Number(win.g10.dl1.selection.text));
                        visibleLayers[b].name = LayerName;
                win.center();
                win.show();
                function getVisibleLayers(container, visibleLayers, sublayersOnly) {
                    for(var a=0; a<container.layers.length; a++){
                        var ilayer = container.layers[a];
                        if (ilayer.visible) {
                            if (sublayersOnly) {
                                getVisibleLayers (ilayer, visibleLayers, false); // false to process only 1 sublayer depth
                            else
                            visibleLayers.push(ilayer);
            function zeroPad(n, s) {
                n = n.toString();
                while (n.length < s) n = '0' + n;
                return n;
            • 3. Re: Button.onClick does not work when I renamed
              I already did, illustrator restart, restart my pc, I tried everything, renowned jsx to js, export it as binary, copy and paste in another txt :S
              • 4. Re: Button.onClick does not work when I renamed
                CarlosCanto Adobe Community Professional & MVP
                your script works with me as well, there's nothing wrong with it.
                • 5. Re: Button.onClick does not work when I renamed
                  in the script by carlos there is no function for the Cancel button.
                  and if I rename it nothing happens as you say.
                  so I added a function for it and it works fine.
                   win.g100.bu2 = win.g100.add('button',undefined,'Cancelar');
                      win.g100.bu2.onClick=function(){
                         win.close(0);
