2 Replies Latest reply on Dec 12, 2006 12:57 PM by Ravuun
    Embedding Images in a scrolling text box
    Ravuun
      I used the Flash help files to get the dynamic text box set up for scrolling via the Property Inspector. I have Multiline wrapping text and the HTML buttons active. The help files don't tell you where to put the <img src> tag to reference the images I need to embed in the text box. I'm not an ActionScripting expert, though I can do the basics--help!
        • 1. Re: Embedding Images in a scrolling text box
          cinemaguy Level 1
          textField.htmlText = "<img src=\"image.jpg\" />"
          • 2. Re: Embedding Images in a scrolling text box
            Ravuun Level 1
            The code helps a bit, thank you. Where does it go?
            The actionscripting panel says I can't apply actionscript to the text field. Does it attach to the keyframe the text field is located in?
            If I am supposed to put the actionscript in the keyframe the scrolling text field is located in, how can I set the width and height of the image, and tell Flash where the image should be placed in the text field?
            Finally, I need to have a row of three images, same height, different widths, with a line of text above and another line of text below. How would I do this?
            Thanks in advance for your help!
