Here is my code .. This is my word search game ...In word list array ...these are my questions to find in grid in the game...my questions how can i type other languages (tamil language)in the array or how can i use the other languages in grids and how can i fill rest of grids with tamil letters manually or randomly
import flash.display.*;
import flash.text.*;
import flash.geom.Point;
import flash.events.*;
import flash.net.FileFilter;
import flash.filters.GlowFilter;
const puzzleSize:uint = 20;
const spacing:Number = 24;
const outlineSize:Number = 20;
const offsetoint = new Point(162.9,179.7);
const offsettoint = new Point(300,265);
const spacingg:Number = 36;
const letterFormat:TextFormat = new TextFormat("Bamini",18,0x000000,true,false,false,null,null,TextFormatAlign.CENTER);
// words and grid
var wordList:Array;
var usedWords:Array;
var grid:Array;
// game state
var dragModetring;
var startPoint,endPointoint;
var numFound:int;
// sprites
var gameSpriteprite;
var outlineSpriteprite;
var oldOutlineSpriteprite;
var letterSpritesprite;
var wordsSpriteprite;
startWordSearch();
function startWordSearch() {
**// word list**
wordList = ("Lion,Tiger,Cheetah,Panther".split(",";
// set up the sprites
gameSprite = new Sprite();
addChild(gameSprite);
oldOutlineSprite = new Sprite();
gameSprite.addChild(oldOutlineSprite);
outlineSprite = new Sprite();
gameSprite.addChild(outlineSprite);
letterSprites = new Sprite();
gameSprite.addChild(letterSprites);
wordsSprite = new Sprite();
gameSprite.addChild(wordsSprite);
// array of letters
var letters:Array = placeLetters();
// array of sprites
grid = new Array();
for(var x:int=0;x<puzzleSize;x++) {
grid[x] = new Array();
for(var y:int=0;y<puzzleSize;y++) {
// create new letter field and sprite
var newLetter:TextField = new TextField();
newLetter.defaultTextFormat = letterFormat;
newLetter.x = x*spacing + offset.x;
newLetter.y = y*spacing + offset.y;
newLetter.width = spacing;
newLetter.height = spacing;
newLetter.text = letters[x][y];
newLetter.selectable = false;
var newLetterSpriteprite = new Sprite();
newLetterSprite.addChild(newLetter);
letterSprites.addChild(newLetterSprite);
grid[x][y] = newLetterSprite;
// add event listeners
newLetterSprite.addEventListener(MouseEvent.MOUSE_DOWN, clickLetter);
newLetterSprite.addEventListener(MouseEvent.MOUSE_OVER, overLetter);
// stage listener
stage.addEventListener(MouseEvent.MOUSE_UP, mouseRelease);
// create word list fields and sprites
for(var i:int=0;i<usedWords.length;i++) {
//var myglow:GlowFilter=new GlowFilter();
//myglow.color = 0x0000FF;
//myglow.blurX=5;
//myglow.blurY=5;
//myglow.strength=200;
var newWord:TextField = new TextField();
newWord.defaultTextFormat = letterFormat;
newWord.x = 700;
newWord.y = i*spacingg+offsett.y;
newWord.width =140;
newWord.height =spacing;
newWord.text = usedWords[i];
//newWord.filters=[myglow];
newWord.selectable = false;
wordsSprite.addChild(newWord);
// set game state
dragMode = "none";
numFound = 0;
// place the words in a grid of letters
function placeLetters():Array {
// create empty grid
var letters:Array = new Array();
letters[x] = new Array();
letters[x][y] = "*";
// make copy of word list
var wordListCopy:Array = wordList.concat();
usedWords = new Array();
// make 1000 attempts to add words
var repeatTimes:int = 1000;
repeatLoop:while (wordListCopy.length > 0) {
if (repeatTimes-- <= 0) break;
// pick a random word, location and direction
var wordNum:int = Math.floor(Math.random()*wordListCopy.length);
var wordtring = wordListCopy[wordNum].toUpperCase();
x = Math.floor(Math.random()*puzzleSize);
y = Math.floor(Math.random()*puzzleSize);
var dx:int = Math.floor(Math.random()*3)-1;
var dy:int = Math.floor(Math.random()*3)-1;
if ((dx == 0) && (dy == 0)) continue repeatLoop;
// check each spot in grid to see if word fits
letterLoop:for (var j:int=0;j<word.length;j++) {
if ((x+dx*j < 0) || (y+dy*j < 0) || (x+dx*j >= puzzleSize) || (y+dy*j >= puzzleSize)) continue repeatLoop;
var thisLettertring = letters[x+dx*j][y+dy*j];
if ((thisLetter != "*" && (thisLetter != word.charAt(j))) continue repeatLoop;
// insert word into grid
insertLoop:for (j=0;j<word.length;j++) {
letters[x+dx*j][y+dy*j] = word.charAt(j);
// remove word from list
wordListCopy.splice(wordNum,1);
usedWords.push(word);
// fill rest of grid with random letters
for(x=0;x<puzzleSize;x++) {
for(y=0;y<puzzleSize;y++) {
if (letters[x][y] == "*" {
letters[x][y] = String.fromCharCode(65+Math.floor(Math.random()*26));
return letters;
// player clicks down on a letter to start
function clickLetter(event:MouseEvent) {
var lettertring = event.currentTarget.getChildAt(0).text;
startPoint = findGridPoint(event.currentTarget);
dragMode = "drag";
// player dragging over letters
function overLetter(event:MouseEvent) {
if (dragMode == "drag" {
endPoint = findGridPoint(event.currentTarget);
// if valid range, show outline
outlineSprite.graphics.clear();
if (isValidRange(startPoint,endPoint)) {
drawOutline(outlineSprite,startPoint,endPoint,0x66CCFF);
// mouse released
function mouseRelease(event:MouseEvent) {
dragMode = "none";
// get word and check it
var word = getSelectedWord();
checkWord(word);
// when a letter is clicked, find and return the x and y location
function findGridPoint(letterSpritebject)oint {
// loop through all sprites and find this one
if (grid[x][y] == letterSprite) {
return new Point(x,y);
return null;
// determine if range is in the same row, column, or a 45 degree diagonal
function isValidRange(p1,p2ointšBoolean {
if (p1.x == p2.x) return true;
if (p1.y == p2.y) return true;
if (Math.abs(p2.x-p1.x) == Math.abs(p2.y-p1.y)) return true;
return false;
// draw a thick line from one location to another
function drawOutline(sprite,p1,p2oint,c:Number) {
var offoint = new Point(offset.x+spacing/2, offset.y+spacing/2);
s.graphics.lineStyle(outlineSize,c);
s.graphics.moveTo(p1.x*spacing+off.x ,p1.y*spacing+off.y);
s.graphics.lineTo(p2.x*spacing+off.x ,p2.y*spacing+off.y);
// find selected letters based on start and end points
function getSelectedWord()tring {
// determine dx and dy of selection, and word length
var dx = endPoint.x-startPoint.x;
var dy = endPoint.y-startPoint.y;
var wordLength:Number = Math.max(Math.abs(dx),Math.abs(dy))+1;
// get each character of selection
var wordtring = "";
for(var i:int=0;i<wordLength;i++) {
var x = startPoint.x;
if (dx < 0) x -= i;
if (dx > 0) x += i;
var y = startPoint.y;
if (dy < 0) y -= i;
if (dy > 0) y += i;
word += grid[x][y].getChildAt(0).text;
return word;
// check word against word list
function checkWord(wordtring) {
// loop through words
// compare word
if (word == usedWords[i].toUpperCase()) {
foundWord(word);
// compare word reversed
var reverseWordtring = word.split("".reverse().join("";
if (reverseWord == usedWords[i].toUpperCase()) {
foundWord(reverseWord);
// word found, remove from list, make outline permanent
function foundWord(wordtring) {
// draw outline in permanent sprite
drawOutline(oldOutlineSprite,startPoint,endPoint,0xE01212);
// find text field and set it to gray
for(var i:int=0;i<wordsSprite.numChildren;i++) {
if (TextField(wordsSprite.getChildAt).text.toUpperCase() == word) {
TextField(wordsSprite.getChildAt).textColor = 0xFF0000;
// see if all have been found
numFound++;
if (numFound ==usedWords.length) {
endGame();
function endGame() {
gotoAndStop("gameover";
cleanUp();
Timee.stop();
function cleanUp() {
removeChild(gameSprite);
gameSprite = null;
grid = null;
vv=null;
pls help and thanks
use a font that supports the language you want to use and embed your font.
No i want to use tamil letters in the whole grid .........
i want to create a grid manually like this
[[0, 0, 'ą®µ', 0, 0, 0, 0, 0, 0, 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],
[0, 0, 'ą®£', 0, 0, 0, 0, 0, 0, 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],
[0, 0, 'ą®ąÆ', 0, 0, 0, 0, 0, 0, 'S',0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],
[0, 0, 'ą®', 0, 0, 0, 0, 0, 0, 'E',0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],
[0, 0, 'ą®®ąÆ', 0, 0, 0, 0, 0, 0, 'T',0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],
[0, 0, 0, 0, 0, 0, 0, 0, 'F', 'T',0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],
['D', 'E', 'F', 'A', 'U', 'L', 'T', 0, 'L', 'I',0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],
[0, 0, 0, 0, 0, 0, 0, 0, 'A', 'N',0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],
[0, 0, 0, 0, 0, 0, 0, 0, 'S', 'G',0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],
[0, 0, 'P', 'U', 'B', 'L', 'I', 'S', 'H', 'S',0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],
[0, 0, 0, 0, 0, 0, 0, 0, 0, 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],
[0, 0, 0, 0, 0, 0, 0, 0, 0, 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0]];
the out put will be
and what's the problem?
how can i apply these array in my above first foremost code .......
what happens when you change wordList and the font?
when i try to change the font it shows like this ...its not perfect tamil letters anymore ..........(here one tamil letters converted two or three words )
thats y i tried manully fill the grid with the tamil letters
because tamil is a syllabic and not alphabetic language you probably will need to re-write that script. i didn't realize tamil is so different from the languages with which i am familiar.
Ya thats right .......can pls help me to rewrite the script
that's more work than i do for free.
if you want to hire me to do that, send an email via http://www.kglad.com > contact.
its k thanks ...........i completed this game
Are you asking about a different way to organize your data? Here's one approach using a 2-dimensional object.
var wordList : Object = {
"cheetah" : { "en" : "cheetahEnglish", "tamil" : "cheetahTamil" },
"panther" : { "en" : "pantherEnglish", "tamil" : "pantherTamil" }
trace( wordList[ "cheetah" ][ "en" ] );
trace( wordList[ "cheetah" ][ "tamil" ] );
trace( wordList[ "panther" ][ "en" ] );
trace( wordList[ "panther" ][ "tamil" ] );
/* output:
cheetahEnglish
cheetahTamil
pantherEnglish
pantherTamil
