1 Reply Latest reply on May 11, 2006 3:30 PM by rwest
    Parent node of an XML Search
    rwest
      I have been wrecking my brain on this and I am sure that it is possible I am just not sure what the proper search expression is.
      If I have an XML document like this:
      <items>
      <item>
      <linkurl>foo</linkurl>
      <item>
      <linkurl>bar</linkurl>
      </item>
      </item>
      </items>
      Lets say I am looking for the parent of the item element that has a linkurl element with value of "bar" I would expect to write something like this:
      <cfset itemArray = xmlSearch(xmlDoc, "ancestor:://item[linkurl='bar']")>
      I know that for this particular instance I could access it directly but in my case there may be many <item> tags nested so I want it to be dynamic so that I can continue to walk back up the tree.
      Any help will be appreciated
        • 1. Re: Parent node of an XML Search
          rwest Level 1
          This was posted a couple of times because of a bad internet connection, anyways with my trusty XPath Explorer plugin I was able to get the solution:
          <cfset itemArray = xmlSearch(xmlDoc, "//item[linkurl='bar']/parent::item")>
          If you have started to play with XML and XPath in particular and you are using Eclipse the XPath Explorer plugin is invaluable!
